10-02-2019, 07:10 PM | #1 |
Rep 13
car wobbles while driving aggressive
had my M235i about a month and a half now... now that im pretty much used to it im starting to drive a lot more aggressive now and im noticing the car wobbling a bit when doing so... googling the problem seems to tell me it's most likely the subframe bushings? is this like an emergency to fix asap? could i lose control bc of it? car is still under the 90 day carmax warranty. think this is something they will fix? if not, how many millions of dollars will this cost me?
10-08-2019, 10:19 PM | #2 |
Rep 104
iI'm actually here researching kind of this same thing.. hit a paving cross cut and busted my wheels and had a suspension inspection today, it's been feeling looser sense (like 5 days ago)..
anyway my mechanic said the front lower front control arms are a very common source and go out with regular driving around 40k.. my car is at 33k but i drive hard and it seems that hit just push it to the point i can really feel it. i would take it in and have them look at the play on the control arms.. i bet ya it's excessive and or they will replace replace at least the front this is what we were looking at but again im here researching https://www.ecstuning.com/b-turner-m...440tms01-02~a/ the rear are the front and rear trail arms and the diff bushing.. i can update as i learn more. all other input is great to. I'll do most or all mine with new tires and alignment buy end of next week |
10-13-2019, 12:38 PM | #3 |
Rep 4,177
Tire pressures. Make sure they are appropriate for the tires you’re running (non runflats vs runflats) mine was at 38 PSI on non runflats and made the car feeling squirreling.
10-13-2019, 09:11 PM | #4 |
Rep 104
wanted to update this thread as to what i found and what i'm doing.
There's an m4 lca (lower control arm) upgrade for our cars RWD m235i list posted by Jondagger here https://www.2addicts.com/forums/show...&postcount=237 i ordered dinan springs and confort kit, rear trail arms and new diff bushings to do it all at the same time hope this helps someone. cheers |
10-19-2019, 02:11 PM | #5 | |
Supreme Allied Commander
3886
Rep 54,510
Drives: F80 M3
10-19-2019, 11:04 PM | #6 |
Rep 68
10-20-2019, 01:03 PM | #7 | |
Rep 352
AmuroRay2316.50 |
10-21-2019, 01:36 PM | #8 |
Rep 4,177
Depends on tire sizes. I have Staggered 18's and run about 32psi cold. The shops keep bumping it up to 38 or so because they think I'm using runflats and it causes the car to feel loose and wobbly.
Mods: Yes.
11-04-2019, 10:46 PM | #9 |
Rep 104
Well, here are my front tension strut bushings at 33k.. the car felt real sloppy with them in before hitting said paving cut, and more loose after.
For one, I'm not going to argue for or with a guy that worked at BMW service for 3 years.. I did not. My experience aligns with his expertise. I have since replaced with M4 lower control arms and tension struts, also upgraded to Dinan springs w/comfort kit.. my car feels Fan Fuk'n Tastic! (This upgrade probably isn't for the timid - probably gonna kill tires) Now a did change a lot, including toe (alignment).. but the only parts that actually look like they need replaced are the bushings. So I stand by my original post with one correction. I said lower control arm where I should have said tension strut, my lower control arm bushings were probably fine, my tension strut bushings are again the one shown in this picture and were done at 33kmiles. Cheers |
11-05-2019, 08:44 AM | #10 | |
Rep 445
Compare those to this set which had 10k miles according to the post below, yours look terrible! https://f30.bimmerpost.com/forums/sh....php?t=1655053 |
dradernh4471.50 nixeighty6119.50 |
