BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    TPM question
      04-16-2019, 02:54 PM   #1
weingarm
weingarm's Avatar
857
Drives: M3
TPM question
I just got my base M5 April 5th. I have a question about the Tire pressure monitor.
It keeps warning me that tire pressure is low even though all tires are at or above 32-33psi which is the recommended pressure on the door frame sticker and as listed in the owners manual. I have it set for the correct size rear 20 inch summer tires for travel <100mph. The iDrive displays recommends the pressure be 42 psi or higher!
Why? I can't seem to reset this. Any thoughts? See pictures.
2023 M3: Isle of Man Green
2021 X7 40i: Phytonic Blue
      04-16-2019, 03:26 PM   #2
x5man
Drives: 2024 M8 Gran Coupe
I had the same problem. Tried changing different settings but the light kept coming up. When I dropped a car off for 1000 mile service, they fixed it.
      04-16-2019, 03:48 PM   #3
Simon H
Simon H's Avatar
876
Drives: M5 Competition
Are you setting the pressures when the tyres are cold ?.
      04-16-2019, 04:06 PM   #4
Pimpsy
Drives: 2019 M5C
Dealership set my tire pressure to 42psi to resolve...
Retired 2016 BMW 550i xDrive MSport | 2013 BMW 550i xDrive MSport | 2012 BMW 535i xDrive | 1988 BMW 325ic | 1984 BMW 318i
      04-16-2019, 07:55 PM   #5
MysticBlue
Drives: '20 M5C, '09 M3 DCT Coupe
32-30 is the normal pressure that they warn you they are low. Pressure should be higher.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra.
      04-16-2019, 08:06 PM   #6
dardeca
dardeca's Avatar
Drives: 2019 M5 Competition
+1
E92 M3 Supplemental manual p.38: "The laws of physics cannot be repealed, even with DSC."
      04-16-2019, 09:20 PM   #7
limeypride
limeypride's Avatar
Drives: 2022 M8 Competition GC
The recommendations now take heat into account. First thing in the morning here in WA at say 49F ambient, the car will suggest 36psi front and rear. As the temperature increases, it changes accordingly. I try to get it with 1 or 2 psi of the recommendation.
At 60F ambient (90F+ in the tire), it's suggesting 38psi front and 39psi rear.
Important note that just occurred to me: I have custom tires on standard Comp wheels and configured the car as such--I'm running Michelin Pilot SuperSports 295/30/20 rears and 285/35/20.
      04-16-2019, 10:46 PM   #8
weingarm
weingarm's Avatar
857
Drives: M3
Yes, these are the cold tire pressures on my iDrive (32-33psi). Sounds like the consensus is the cold pressure in the tires should be set to the recommend iDrive pressures - I guess around 42 psi even though that seems pretty high to me (and higher than the door frame sticker and owners manual suggest).
      04-16-2019, 10:57 PM   #9
NYG
NYG's Avatar
Drives: Audi R8
Yep, sounds like a BMW dealership.
      04-16-2019, 11:52 PM   #10
dalixz25
Drives: 991.2 GT3 RS, Tesla M3P
After you adjust the tire pressures, confirm the tire settings and you'll want to allow the TPM to reset itself before the notification disappears.
      04-17-2019, 02:45 AM   #11
Simon H
Simon H's Avatar
876
This should be correct then. If you set them cold, then the heat and pressures should rise accordingly, and the TPM should be fine. Ive set my pressures to the quoted numbers on the door sticker, and they have been fine, no problems.
      05-02-2019, 07:17 PM   #12
NASTY-M5
Drives: 2019 M% Competition
Came here for the same thing. Switched from my winters to my summers and the warning light won't go out. Keeps asking for 45psi. Door sticker and tires say 32.
BMW newbie, please be kind and patient
2019 M5 Competition.
      05-02-2019, 07:22 PM   #13
limeypride
limeypride's Avatar
Have you told it what tires you're running--there's a setting in the same screen you view the tire temp/pressure.
      05-02-2019, 07:23 PM   #14
NASTY-M5
Yes. I might try the "other tire" option tomorrow.
      05-02-2019, 07:32 PM   #15
limeypride
limeypride's Avatar
Here's what mine is set to actually running different tires than what I've selected (I have MPSS 295R and 285F) but this was the closest.
PS: I love that your car is a typo. Hahahaha.
      05-02-2019, 07:40 PM   #16
CanadianF90M5
Drives: 2019 BMW F90 M5
I just changed my idrive to "other tire" option which solved the problem.
Previous: 2005 BMW E60 545
      05-03-2019, 10:12 AM   #17
devondragon
devondragon's Avatar
Is anyone running the 100+ MPH pressures (44/46? or whatever)? How's the ride? My F13 M6 had higher pressures for 100+ but if I remember right the jump wasn't as big. While I"m not going 100+ all the time, I've been known to venture up there on occasion and I'm thinking it might be nice to have the added safety of the recommended higher pressures. Does it make normal DD driving overly firm as far as bump transmission?
      05-03-2019, 12:02 PM   #18
limeypride
limeypride's Avatar
Man, the recommendations seem to vary wildly from car to car. You can see the recommendations I'm getting in my earlier post and I'm set for >100mph. It only gets into the low 40s as the temperature really gets up there.
//EDIT: actually, I didn't post a pic of the recommendations. It starts at 37psi I believe in 50F ambient.
m5post
