BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    NEW RELEASE: Dinan Tension Strut Ball Joint Kit for the F90 M5 (Monoball Kit)
      04-02-2019, 08:34 AM   #1
Dinan_Engineering
Dinan_Engineering's Avatar
Drives: Any BMW
Dinan Tension Strut Ball Joint Kit For the BMW F90 M5 G30 M550i G12 750i & More! (Monoball Kit)
An underrated component of a proper drivers suspension, the monoball kit (tension strut ball joint kit in today's terminology), is a remnant of an era when road feel was something desirable and sought after. Drivers desired the visceral feel of being connected to the road as the road racing heritage of BMW M demanded. Dinan embraced this and over the years mastered its craft into a kit that not only satisfied the desire for proper road feel but also made it livable for everyday driving. While stock suspension properties may have swayed from its golden era lineage to more mainstream ideals, Dinan is here to correct those mistakes for those that want a more M-passioned BMW experience.
Part Number(s): D280-0018 & D280-0019
Applications:
D280-0018: 2018 G30 M550i xDrive, 2018 G32 640i xDrive, 2016-19 G12 740i xDrive, 2016-19 G11/G12 750i xDrive, 2018-19 G12 Alpina B7 and 2017-19 G12 M760i xDrive
D280-0019: 2018-19 F90 M5
Product Page(s) / Pricing:
D280-0018: http://bit.ly/TSBJ-M550
D280-0019: http://bit.ly/TSBJ-M5
Recommended Install Time(s):
D280-0018: 2 hours
D280-0019: 4 hours
Release Date: Available Now!
Description: The Dinan Tension Strut Ball Joint Kit provides responsiveness you can feel by replacing the rubber bushings in the thrust arms with precision ball joints and machined aluminum housings. Improves responsiveness by eliminating the deflection inherent in the stock rubber bushings while also reducing brake shimmy. The quietest bearings on the market are virtually noise free so you can live with them every day. These are the only bearings on the market that are sealed using a rubber boot to keep out dirt and road grime stopping them from wearing out prematurely.
Features/Benefits:
  • Improved Steering Responsiveness
  • Reduces Brake Shimmy
  • Nylon-lined Bearings for Quiet Operation
  • Machined Aluminum Housings
  • Sealed Bearings
Holset274.00
      04-02-2019, 09:52 AM   #2
trev230
trev230's Avatar
351
Drives: 2022 M5C
How about a tune sheesh
      04-02-2019, 10:26 AM   #3
Dinan_Engineering
Drives: Any BMW
When products are done, they are released. Monoballs happened to be the first to come to fruition. Rear arms and a HAS kit are probably the next to be released given where kibble vendors / production are in the process. The tune, intake, mid-pipe, etc are all simply farther down the pipeline.
      04-03-2019, 12:40 AM   #4
VeNoM__M5
Drives: F90 M5 Competition
Assuming these are for non comp models?
      04-03-2019, 10:36 AM   #5
Dinan_Engineering
Drives: Any BMW
The monoballs are for either. No change on stock pieces there. Same goes for the other parts listed outside of the exhaust/mid-pipe (exhaust should be fine but mid-pipe is always a question mark until its actually fitted) and potentially the rear links (in the process of verifying those now but so far it looks like those would work on either a comp or non-comp).
VeNoM__M5383.00
      04-03-2019, 01:49 PM   #6
Realnyc8
Drives: 2019 M5
just ordered! excited to try them out
      04-03-2019, 03:21 PM   #7
Steeve19M5CP
Drives: 2019 MBB Blue M5 Competition
These monoballs made loud noises when turning steering after install on my F10 M5.......had to return them.....maybe install issue but I had switched to Powerflex bushings
2019 F90 M5 Comp-Marina Bay Blue-B&W,HRE 21" FF04,BMC,CarbonPro wing,H&R,ZW5
2017 BMW 330i - Estoril Blue - M Sport Package
2013 Lamborghini Aventador-Pearl Green-Modified
2004 Lamborghini Gallardo-Manual 6spd -Giallo Midas Pearl Yellow-Modified
2018 Range Rover Velar S-White
      04-03-2019, 03:25 PM   #8
Realnyc8
Drives: 2019 M5
oh thats not good. anyone else have that issue?
      04-04-2019, 07:51 AM   #9
Dinan_Engineering
Drives: Any BMW
That is exactly what they should not be doing so I have to imagine something else was at play (installation, bad part, etc). I'd be curious to know what the support folks said if anything or did you not go that route opting to just remove them?
      04-04-2019, 02:30 PM   #10
Realnyc8
Drives: 2019 M5
i have ordered them, if any issues i'll be messaging you Dinan
      04-10-2019, 11:06 PM   #11
Realnyc8
Drives: 2019 M5
installed these today. its a nice and noticeable upgrade. at speed theres more feedback from the road, turn ins are more direct. nice job Dinan
      11-15-2021, 10:00 PM   #12
Jambo1
Drives: 2022 M5C /// 2023 XDrive40i
  [0.00]
I’m presuming these are correct for the 2022 M5C LCI as well? As in, this hasn’t changed?
      11-15-2021, 10:35 PM   #13
Dinan_Engineering
Drives: Any BMW
Would be the same.
      11-16-2021, 12:49 PM   #14
M5 F90 (2018)
Drives: M5
So will this tension strut ball joint kit help with much more feel on country roads with better turn in to include roundabouts? Sometimes this thing just doesn't want to turn in as quick as i would like. I have a base M5 (2018).
Attachment 2023158
Applications:
D280-0018: 2 hours
D280-0019: 4 hours
Features/Benefits:
  • Sealed Bearings
      11-16-2021, 12:58 PM   #15
Dinan_Engineering
Drives: Any BMW
Short answer, yes. Driver input with the monoballs is more direct and immediate with added braking and turn-in response.
m5post
