BMW 3-Series (E90 E92) Forum
Brand new lower rad hose leaking. Question about radiator
11-26-2018, 07:52 PM | #1 |
Rep 15
Just replaced the radiator in our 06 325i. Decided to also change the upper and lower hoses. Needed to do the job today so I purchased the parts in stock from the locals... The lower radiator hose, which came from O'Reilly leaks like crazy from the sensor port and the connection to the radiator while bleeding the system. Changed out the o ring seal with another new one and still the same issue. I'm assuming the O'Reilly hose is not perfectly built to spec but was just curious if anyone else experienced this before with a non-bmw hose on an e90? Have no problem spending the extra coin on OE but as I said was just trying to finish this today. Only other thing I can figure is that maybe I have wrong fill plug on pass side of the radiator bottom and it is blocking flow???? The radiator came with 2 types of plugs for the openings at the bottom of both sides of the radiator. Thx in advance for any ideas-
11-26-2018, 08:08 PM | #2 |
General
17491
Rep 18,832
I used BMW OE hoses and had the same issue; the old sensor leaked. Just get a new sensor and replace it. Do it fast enough and you'll not lose much coolant.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
11-27-2018, 09:11 AM | #3 | |
Rep 318
11-27-2018, 09:42 PM | #5 |
Rep 15
So I replaced the sensor and all looked dry during the bleeding phase, but after running the car the lower hose started to leak at the quick connect fitting at the radiator. I guess this hose is definitely not going to work. Ordering a BMW brand hose and will report back.
