E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Fog lights wiring
Reply
      09-15-2018, 12:12 PM   #1
Welcro
Drives: E90
Fog lights wiring
Hi,
I have E90 320i ’05 without front fog lights and no pre-wired at all. I just installed new bumper that came up with fog lights. So I wonder if anyone knows how to wire it to the car correctly or any wiring diagram? I already have a new light switch button with front fog lights function. I just want to use that button to turn on the fog lights like the original one, not concerning about the adaptive function.
Thanks in advance!
      09-22-2018, 10:27 PM   #2
Welcro
Drives: E90
I just want to update that now I can wire it. Someone post the wiring method for the concerning light kit sold by BMW themselves. I just adapt it since I don't want the concerning light function. So to be information for somebody that wants to do like me, I got an original foglight plug socket from a junkyard with wire stuck in it. Also FRM wire set (from the car that already has foglight) from there (with wire stuck in it too).
- Pulled out the pin from the FRM wire set (two 51PIN sockets) that I got from the junkyard. It will be PIN37 from the grey plug and PIN3 from the black plug. Both of them are yellow/brown color.
- Put it in the same position in my car FRM socket.
- Connect the foglight plug to the foglight, wire the negative to the car's negative junction terminal.
- Wire the positive from right foglight into the car and connect with the cable from PIN37 from the grey plug.
- Wire the positive from left foglight into the car and connect with the cable from PIN3 from the black plug.
Now the problem is I can use INPA, go to the activate menu, and turn on the foglight from there but I can't use the light switch to turn it on. I think the FRM need to be code in order to get it work by the switch
Reply
e90post
