08-25-2018, 06:26 AM | #1 |
Rep 74
Drives: BMW 330i G20 2019 Sportline
tiny jolt 2nd to 3rd gear on cold
Hi guys,
in contact again to see if someone can help me. I am experiencing a tiny jolt when shifting from 2nd gear to 3rd on cold. Once the car has warmed up ( drive at least 5 kms ) , it works perfectly. My concern is this behavoiur was not present when the car was new. Now it has 23.000 kms ( 14 000 miles aprox ). This small jerk is present when temp outside is 5 to 10 C ( 40 to 50 F ) or less. I have read various post saying this is normal on cold, but to be honest I remember the car didnīt do it when it was 0km. Iīve done a reset with ista for adaptation values and run the relearn procedure but after some kms (miles) it started again. Car is under warranty so unless there is quick fix, I am planning to take it to the dealer. Thanks in advance for your help. Sorry: I forgot to mention my car is a 330 Sport Line year model 2016 |
08-25-2018, 06:48 AM | #2 | |
Rep 3,680
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
08-25-2018, 06:54 AM | #3 |
Rep 74
Many thanks your quick answer. Yes, my car has the 8AT and it doesnīt do it once warmed up. It shifts like butter. Since I have to go to dealer for other minor issues I will comment this. Thanks again.
08-25-2018, 07:31 AM | #4 |
Rep 3,680
Might as well while you're there. I'm leaning towards non-issue, but let us know what the dealer says
08-25-2018, 11:20 AM | #6 |
Colonol Forbin
208
Rep 338
all the more reason to take the 3 minutes and let the car warm up. Mine does this as well if I do not let it warm.
08-25-2018, 09:25 PM | #7 |
Rep 270
just adding data point: mine does the same unless I let it warm up (usually when im rushing out the door...)
2013 328i xDrive | M Performance Exhaust | Injen Intake | DEPO Headlights |
2019 440i xDrive | Muffler Delete | |
08-26-2018, 08:40 AM | #8 |
Rep 325
Drives: 2016 F36
What driving mode are you in, is the jolt the same in all modes? If not what are the differences between modes? I'd say when cold for me, I notice a longer lag for smoother shifts in comfort mode. If we're talking about the same jolt....I'm almost always in sport+ mode and like the jolt during shifts. I have always experienced it since new. I notice, the harder the acceleration the harder the jolt for me. I'd actually prefer the shift is hard enough to chirp the tires between shifts. I'd guess your fine and nothing is wrong. Usually when AT starting to have problems, the symptoms will be worse once warmed up.
◊ 2016 F36 xDrive N26 ◊ Black Sapphire Metallic ⁞ Dakota Black ◊
║ VRSF HD FMIC ║ ER DP custom paint ║ AWE cat back Exhaust Suite ║ NGK Plugs ║Bootmod3 Stage 1 93 ║ GFB DV+ ║ BMS 10mm Front ⁞ 12mm Rear Spacers ║ P Style BSM Rear Spoiler ║ Smoked Front Reflectors ║ Madico Onyx 20 Tint ║ LCI Lighted Trim Bezel ║ Opti-Coat Pro+ ║ |
08-27-2018, 12:06 PM | #9 | |
Rep 74
09-03-2018, 11:05 AM | #10 |
Rep 74
Continue reporting on this. Today car went to the local BMW dealer and they said they were going to make a complet check with the computer to see if any faults were present. Transmission on cold continues to be sluggish, and I am assuming it is normal.
But will see what BMW has to say. |
09-04-2018, 09:44 AM | #11 |
Rep 74
Dealer technician has recently phoned me and told they had updated something in the software. Will see what happen. Hope in the middle they have not destroyed something else.......
09-04-2018, 03:42 PM | #12 |
Rep 74
Dealer today updated my car to I level to F20-18-07-531. I could see it through ista. All the memeory fo the car were erased, radio, prferences, etc...
I assume they reprogrammed everything to this new I level. But I cannot perceive any difference for the moment. However gearbox is much more smooth at least when I left the dealer to my home. I will have to check it tomorrow on cold to see if this change has been efective to the gearbox issue. Last edited by ferbmw; 09-06-2018 at 10:08 AM.. |
09-04-2018, 06:18 PM | #13 |
Rep 657
This happens to me only on cold starts like you guys say but mine is 1-2 and sometimes its a hard jolt but when I really let the car warm up like for 10-15 minutes it doesn't do it lol.
Current: 2017 Bmw 540i M sport bluestone metallic
Previous:F30 328i 2012 PWG: FBO Vrsf 6 stepped fmic, Afe intake, Catless DP ER, FTP CP's, FTP turbo inlet, GFB DV+, Gplus oil cooler, BM3 stg 2 tune, Cary Jordan E50 tuned stock fuel system. |
09-06-2018, 06:24 AM | #14 |
Rep 74
update: Car is sitill with little jolt when engaging 2nd to 3rd mainly. But it disappear once I drive a few kms. As it was before the i level update
With this update, it is happening that when the car is warmed up, if turn off the car and then I turn on after a few seconds, the engine revs up as if it were cold and then, after a few seconds , it regain the normal iddle speed. I will have to run the car a few days more to see if this continues and eventually ask the dealer if it is normal. I forgot to mention the dealer said the the jolt, jerkiness, slugish engagement on cold was normal. |
09-06-2018, 11:59 AM | #15 | |
Rep 325
Drives: 2016 F36
I should mention I've been in a friends Acura with a Aisin 7 speed AT that was failing and there is NO mistaking it. When it was time to auto shift the car would rev high like it was slipping then slam...and I mean slam into gear. The harder he was on acceleration the higher the revs and harder the slam. From outside the car it sounded like a manual that was redlined with the clutch in the let out.
║ VRSF HD FMIC ║ ER DP custom paint ║ AWE cat back Exhaust Suite ║ NGK Plugs ║Bootmod3 Stage 1 93 ║ GFB DV+ ║ BMS 10mm Front ⁞ 12mm Rear Spacers ║ P Style BSM Rear Spoiler ║ Smoked Front Reflectors ║ Madico Onyx 20 Tint ║ LCI Lighted Trim Bezel ║ Opti-Coat Pro+ ║ Last edited by Noelified; 09-06-2018 at 12:09 PM.. Reason: adding note: |
09-06-2018, 12:02 PM | #16 | |
Rep 3,680
09-06-2018, 12:37 PM | #17 |
Rep 74
Thanks for you responses and to be honest, I rely much more on your comments / opinions than in the dealerīs experience. For them everything is normal......
Diegov209164.50 |
09-07-2018, 03:50 PM | #18 |
Rep 270
https://f30.bimmerpost.com/forums/sh....php?t=1511226
interesting thread. I might give this a go some time next week since it easy enough EDIT: for those that might not want to click. its just a suggestion/video to clean the MAF with some CRC cleaner
