BMW 3-Series (E90 E92) Forum
Polyurethane bushings?
03-11-2006, 02:46 PM | #2 |
MAUI BUILT
486
Rep 7,781
Drives: 2006 330i MT
I believe they are rubber. Poly dries up really fast and squeeks if not lubed on a regular basis.
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
03-11-2006, 03:06 PM | #3 | |
Rep 6,381
Nikki
03-11-2006, 03:37 PM | #4 |
Rep 6,158
I had poly bushings on my aftermarket sway's on my old E30 and after a couple of years they did start to squeak pretty bad.
Some of the nicer kits have a fitting to lube the bushings though (my RD bars didn't though) |
03-11-2006, 04:26 PM | #5 | |
MAUI BUILT
486
Rep 7,781
Danny
03-11-2006, 08:00 PM | #6 |
Rep 10,176
The stock swaybar bushings are a rubber compound. Aftermarket are generally polyurethane. I've had UUC and RD Sport sways on previous bimmers, and they always needed an annual relubing. I think some are getting better, with grease fittings, but they still need regular maintenance.
The end-links also made noise after a while. I had to replace one set of UUC end links after they got contaminants in the ball sleeve (I think it was sand) and nearly seized. I would service them annually as well. Even with the maintenance, they are totally worth it, if you track or autox your car. |
