BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    For those with steel brakes
      04-03-2018, 11:46 AM   #1
Quickburn7
Drives: 2018 Bmw M5
My brakes are squeeling and making a weird grinding noise when in traffic and in normal driving when coming to a stop. It happens if they are hot or cold. Anyone else experiencing this? I only have 350 Miles on the car.
The squeeling does not bother me since I am used to CCB but the grinding noise does. Any thoughts?
      04-03-2018, 11:54 AM   #2
onfireX5
Drives: F90M5,F85X5M
The brakes on my X5M and M5 are identical. M5 has been quiet so far. X5M always starts to squeal between washes. Brake dust does it. Wash it and is quiet for a while. Never grinding on either. Try spraying off the calipers when cold with a water hose and see if it goes away.
      04-03-2018, 01:23 PM   #3
BwoodBMW
BwoodBMW's Avatar
1861
Drives: EFFEIGHTY
hopefully the f90 doesn't have the same issue the M3/4 have with getting small rocks stuck in the brake shields.... If I go over any rough gravel roads I can bet that I'll get a grind or two in the following days
      04-03-2018, 01:59 PM   #4
stbm5
Drives: 2018 M5 DG
if its a pebble in the heat shield it should be really loud and likely coming from just one caliper. if that seems like it then try driving a bit in reverse or pressing the heat shield back with your fingers and see if a little pebble falls out.
      04-03-2018, 02:04 PM   #5
trackday96
trackday96's Avatar
155
Drives: BMW M5 CS, Porsche 911 GT3 RS
2022 BMW M5 CS  [0.00]
2016 BMW M4  [0.00]
No issues like this thus far with my M5 (at ~1,100 miles); good luck!
instagram: trackday.fanatic
      04-04-2018, 03:59 AM   #6
Spara
Drives: 2018 M5
My brakes were squeaking the day I rolled off the lot. They go away under use, but come back occasionally. Interior also rattled on some of
Our back canyon roads though on the highway, it’s super silent.
      04-04-2018, 08:15 AM   #7
Quickburn7
Drives: 2018 Bmw M5
Washed the brakes down last night and checked the heat shield for pebbles. It was squeezing but no grinding on a short drive. Thanks guys!
      04-04-2018, 09:07 AM   #8
onfireX5
Brake dust is the devil. Glad it worked.
m5post
