01-29-2018, 07:05 AM | #3 |
Rep 15
Space Saver Spare Info
I made up my own kit here in the UK based on info kindly supplied by andrettifan in the "wheels & tyres" USA section of this forum:
http://f87.bimmerpost.com/forums/sho...1&postcount=16 From my Dealership: Wheel Part Number: 36 11 6 768 861 - £64.94 Jack Part Number: 71 12 6 866 211 - £65.87 From Local Tyre Supplier: Bridgestone 145/70R18 - £57 Plus you'll need a 5mm spacer to clear the front brake caliper (front only). The wheel does actually clear, just, but the 5mm spacer makes certain. It's not needed at the rear, there is plenty of clearance. Everywhere I looked would only supply a pair (got mine from Rudimods £23 the pair) so I do have a spare one........ Don't forget a socket & bar or wheelbrace for the wheel nuts! Had front & rear wheels off so it's all been tested & fits fine. A wheel cover from e-Bay & it all sits lashed down in the boot leaving plenty of room for one large & one small suitcase - Perfect! Hope this helps |
illingworth2231.50 |
