2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Help needed with ZGW module on F10
      10-12-2017, 12:08 PM   #1
koanga
Drives: F10 & F15
Unhappy Help needed with ZGW module on F10
Long story short....
Flooded car, someone monkey with it an make it run by swapping totally different parts till the car started:
modules that they throw at it till they got the car running are:
1. ZGW-High (metal box) - car came with ZWG2-4SK
2. JBBF and the entire fuse panel
3. SZL
4. FRM
All back to original modules, new from the dealer, minus the FRM module
When I`m plugging in the ZGW-02 8SK that I receive from the dealer (FA & vin coded & flex-ray initiate) the car looses EPS, TBX, and left & right headlights modules. If I`ll plug back the "monkey ZGW-High" EPS comes to life.
I did try to flash the ZWG but after SVT_soll and Tal calculation, the ZGW is not in the list. Only 7 or 8 modules are available for flashing
(using e-sys 2.81 & 3.30 & 3.31 with the latest psdz data)
Car is F10 build 08/2015, I-step factory F010-15-07-504.
      01-10-2019, 02:05 PM   #2
platinum6
Drives: F10 510i
hi,
i have the same problem.
i have replace ZGW and loose EPS.
how You solved a problem
      01-10-2019, 04:15 PM   #3
koanga
Drives: F10 & F15
Originally Posted by platinum6 View Post
hi,
Was the wrong zgw module, wrong flash (newer). I end up getting an old zgw module of eBay and code it.
Tags
esys, flashing, module, zgw
5post
