06-26-2017, 08:26 AM | #1 |
Rep 260
Comparing camber plate options for stock springs
I am in desperate need of camber plates. From my research that I've done, it looks like every option available comes with its flaws. From what I can tell it seems like Vorshlag may be the best of the bunch. Can the folks who are running camber plates weigh in? From my research, a lot of my findings are at least several months old and I'm not sure if there has been any improvements since.
Vorshlag - Robust design, but clearance for the spring isolator boot is virtually nonexistent and will rip the boot within a few miles; no change to design by Vorshlag citing they do not want to mill down the spring seat any smaller. Dinan - Last I read, they have updated their design but haven't found any further update since. Also quite pricey. Ground Control - poor bearing design. Has it been updated? KMAC - the spring seat acts as a funnel for dirt and road debris to get into the bearing. rwalker reported that his failed (iirc) at around 2k miles. I had a set of these on order (Turner had these on sale for $370), but that was before reading about the fatal flaw of the spring seat plate. Have since cancelled the order. TC Kline - didn't do much research on this. Pretty expensive.... Millway - Cheap price; not much reviews. Are there any other that I've missed? Any different experience of any of the plates than what I've found above? |
06-27-2017, 01:37 AM | #2 |
Rep 986
I've been running GCv2's for over 40,000 miles. No issue with them. I recently installed Dinan springs, checked the bearings and they were perfect.. The GCv3's are out now and have a really nice top plate design, but overall are still the same design and they work.
06-29-2017, 12:03 AM | #4 | |
Rep 29
06-29-2017, 09:51 AM | #5 | |
Rep 356
Drives: 2014 m235i
06-29-2017, 03:04 PM | #6 |
Rep 986
Camber plates are only a requirement if your tracking your M235 and don't want to spend tons of money replacing front tires from tearing up the edges.
Front -2 Deg 1/32 in Toe per Side 1/16 in Toe total Rear -1.8 Deg 1/16 in Toe per side 1/8 in Toe total |
07-01-2017, 11:37 PM | #7 | |
Rep 58
Anyone know if the vorshlag plates still cause the spring boots to rip? |
07-01-2017, 11:50 PM | #8 | |
Rep 260
Skycaptain21.00 |
07-02-2017, 05:02 AM | #9 |
Rep 58
Spent the last 3 hours reading the suspension threads. I haven't come across any ground control threads as yet. Do they allow the standard spring boot when fitting, and do they have any isssues? Seems every other camber plate isn't worth the noise as a road car.
10-23-2017, 09:25 AM | #11 |
Rep 1,184
Not to deviate too far from o.o, but I have a related question.
I am also looking for camber plates, and maybe coil overs down the road. Do any coil overs kits for the f22 offer a camber adjustment, or does that come specifically from the camber plates. I know a lot of camber plates give stock suspension an issue. Do any camber plates work better with coil overs? Or is it just the entire f22 geometry that raises issues. Fyi I am m4 lca and ts with dinan springs. I believe I need a small amount more negative camber to clear to fender fully. |
