M2 Technical Topics > Cosmetic Modifications > Better PPF coverage for Rear fenders
      04-02-2017, 10:51 PM   #1
gregzimm
gregzimm's Avatar
85
Drives: 2017 M2
1973 Pantera  [0.00]
1967 Corvette  [0.00]
2005 BMW ZHP  [0.00]
2017 BMW M2  [0.00]
Has anyone removed the OEM PPF on the rear wheel fenders and replaced them with better coverage PPF?
I think they should cover more area to limit damage.
      04-02-2017, 11:53 PM   #2
pruettfan
Drives: 2017 M2, LBB, DCT, Exec
I saw some of the press cars and cars at the BMW performance center and all of them had damage beyond the area that is covered by the factory so I had my Xpel guy remove the factory piece and put a much larger piece of xpel on. He covered from the door back and up from the bottom seam to where the curve is above the wheel. Xpel is far more transparent so its not obvious how large the piece is. I also suggest doing the entire lower rockers because the way they are curved small rocks off the street beat them pretty bad. I ended up doing them after it was clear that they were taking a beating, had I known I would have done this initially like the rest of the car.
      04-03-2017, 05:44 AM   #3
Semi-Poor
Semi-Poor's Avatar
Drives: 2017 M2 Coupe
I had it removed and replaced with XPEL when the front end etc was done. The OEM piece is small and not the same quality as XPEL. Did my best with phone shot, you get the idea.
2017 M2 Coupe Black Sapphire Metallic
mssVT98141.50
      04-03-2017, 10:47 AM   #4
mssVT98
mssVT98's Avatar
142
Drives: 2017 M2
2017 BMW M2  [9.67]
Thanks for posting this. I was curious as to where they would run a larger piece on the fender without it looking funky. This looks pretty good and seems like it would cover the full area where I've been picking up rock chips.
      04-04-2017, 01:38 AM   #5
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
Tbh it would probably look better than the stock piece due to the fact you can run one edge under the rear wheel arch so it's hidden away, unlike the factor piece which is not hidden at all.
I unfortunately didn't get this piece changed when i had PPF installed so have copped a few chips around where the film doesn't cover, i did however get the rear bumper done behind the rear wheels as i noticed this area was getting a beating.
      04-04-2017, 03:18 PM   #6
mssVT98
mssVT98's Avatar
142
Drives: 2017 M2
2017 BMW M2  [9.67]
This is true... fewer lines to be noticed. I was worried more about the upper edge of it being higher on the fender and therefore more obvious. Doesn't seem like that would be the case, though, especially if it's a higher quality film.
I haven't had any issues with the rear bumper yet, but definitely something to consider.
      04-05-2017, 10:21 PM   #7
Tag
this is the way
Tag's Avatar
18160
Drives: N-1 starfighter
The rear is called a quarter panel, not fender.
m2
