02-20-2017, 06:26 PM | #1 |
Rep 1,660
Hard wiring radar detector question
I followed some information I found on the web referring to Fxx cars about this. However, the conductor colors called out are not in fact 12v switched. After testing every combo I could not find a suitable power supply. There is one there but it is not switched.
All I accomplished by following these was to trigger the passenger airbag light (not to worry I already reset it). So if anyone has done hardwiring on the F87 perhaps you could share where you located a suitable power supply. Tx |
02-20-2017, 09:45 PM | #3 |
Rep 278
DIY: MirrorTap & BlendMount http://www.2addicts.com/forums/showthread.php?t=998321
spellbmw58.00 |
03-18-2017, 09:45 PM | #4 |
Da Baus
283
Rep 259
check link in my sig
M2 LBB/6MT/VFstg2/V1 stealth/JRC valve delete/Dinan/
Fabspeed/Wagner/ER/Eibach/UCP/RTD RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID E46 330ci --> S54 M3 xplant vzv 3bananas (retired) |
02-11-2018, 08:34 AM | #5 |
Rep 1,927
where do you tap the mirror tap into? I read the 2 addicts post. However another forum member said the M2 has different connectors?
Already bought the mirror tap... now just need to go out and do it
Current: 17 OG M2 / R8 Performance
Past Performance Cars: 01 M3, 05 M3, 06 M5, 08 M6, 08 M3, 11 M3, 13 M3, 15 M3, 911 C4S, 911 GTS, 17 M2,R8 V8, R8 RWS |
02-11-2018, 10:20 AM | #6 |
Rep 8,942
Pre LCI black goes to brown, red goes to green. Post LCI I can neither confirm nor deny that it's the same.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
02-11-2018, 11:47 AM | #7 |
Rep 1,927
Thanks. About to go out and give it a shot.
02-11-2018, 11:51 AM | #8 |
Rep 8,942
This is my car if it helps
2022 Macan S
02-11-2018, 12:33 PM | #9 | |
Former P-Car Owner
272
Rep 237
2018 BMW M2, Orange wrapped!, Journal
1999 BMW M3, Cosmos Black, S54 swapped |
02-11-2018, 03:20 PM | #11 |
Rep 583
Completed mirror tap on two previous 3 series however I have not been able to get my LCI to work.
2003 328i
2006 330i 2014 328i 2015 435 GC 2015 X1 2016 X1 2018 ///M2 2020 M340i |
02-11-2018, 03:22 PM | #12 |
Rep 1,083
I typically had a better connection when using the front passenger footwell fuse box in my prior E90, F10 and current G01.
Does the F87 have a fuse box up front? |
02-11-2018, 11:35 PM | #13 | |
Rep 2,367
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
02-12-2018, 03:37 AM | #14 |
Rep 4,203
LCI is the same colors. The harness wires are pretty much the same. Plug in on the same colors on the F80/82/87. When I installed mine it worked perfectly and I used the same blend mount that i used on the F82
voyagergab633.00 abirmaher843.50 |
02-12-2018, 03:41 AM | #15 |
Rep 1,083
02-14-2018, 01:46 AM | #16 |
HawaiiM2
31
Rep 88
make sure u get the mount with the thick neck for the mirror.... I got the third version and the stalk was a bit too thick... the piviot point didnt come together close enough.
but I just clamped it down and it holds. |
02-14-2018, 03:29 AM | #17 |
Rep 4,203
voyagergab633.00 |
02-14-2018, 06:12 PM | #18 |
Rep 1,927
Why use the mirror mount? I just used the suction cups included w my V1. Mounted right under the headliner. Out of sight, and no extra cost. Plus I'm not advertising that I have a radar. Not doggin in the blendmount, just stating an option.
03-10-2018, 11:29 AM | #20 |
Rep 43
I have a real dumb question. I am going to use the mirror tap, and blendmount solution. but, I want to remove that stupid nipple on the mirror so the detector sir flush to the bottom of the mirror. is that just the security led or is the a sensor inside it?
Life is not about arriving peacefully in the casket at the end. It is about arriving side-ways with the engine at redline and the stereo blasting.
03-10-2018, 12:06 PM | #21 | |
Rep 1,083
Curious about that too. Some bmw models have a move flush version of it. |
03-10-2018, 12:12 PM | #22 |
Rep 43
Yes, the clown nose. All my BMW's have had it, but other than blinking security, not sure what it does. Or if it is removable.
