M2 Technical Topics > Cosmetic Modifications > Installed the BMW M Performance brake and throttle pedals / covers
      08-18-2016, 04:19 PM   #1
MR.
MR.'s Avatar
Drives: BMW M2 CSL Turbomeister
Today Manhart Performance installed the M Performance brake and throttle pedals / covers. The aluminum pedals /covers are available as a set for manual and automatic cars, but the automatic kit does not fit on the BMW M2. The brake pedal / cover which is in the kit is too big!
So instead you buy the kit for the manual gearbox and do not use the pedal / cover for the clutch, since of course there is no clutch. The installation is not that hard. You need to drill three holes in the brake pedal to attach the cover on that pedal. There is a rubber patch followed by an aluminum cover over the rubber patch. No difficulties there.
The throttle pedal is glued to the existing pedal and two screws hold it in place even further. Total time required, maximum 20 minutes nothing more. Final result can be seen on the photo.
It took a while to find the correct part number and the correct set up, but in the end it was all installed easily and it looks wonderful. Much better than stock, and it feels complete now.
MR
Bosozoku693.50
      08-18-2016, 04:45 PM   #2
confusion
confusion's Avatar
Drives: 2016 M2
Agree that it looks nice but I do not understand why you would want slippery-when-wet pedals. Am I missing something?
2016 Long Beach Blue F87 M2 | DCT | Executive Package
XPEL Stealth Wrap | Tint 35%
HRE R101 in Brushed Dark Clear | 19x9.5 265/35/19 | 19x11 295/30/19
M Performance Steering Wheel | CF Rear Spoiler | Gloss Black Grilles & Side Gills
Build Thread
      08-18-2016, 07:43 PM   #3
gmzanatta
gmzanatta's Avatar
Drives: LBB 6MT M2 # 660/713
Way less slippery than stock actually. The rubber is much "stickier" than stock.
      08-18-2016, 08:39 PM   #4
Ex-MINI
BMW Newb
Ex-MINI's Avatar
Drives: 2016 LBB M2 DCT
It doesn't show up very in the pictures, but the pedals include rubber inserts under the steel portion. Sticks out of those vertical cut outs in the steel
      08-18-2016, 09:45 PM   #5
BD_F22
BD_e92
Drives: 2015 m235i xDrive
Looks great man! These are sitting in my garage waiting to take delivery of my car.. SS pedals are awesome, I loved them on my old Audi S4 I had.
      08-19-2016, 10:40 AM   #6
confusion
confusion's Avatar
Drives: 2016 M2
Cool, thanks guys.
Build Thread
      08-28-2016, 01:42 AM   #7
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Can you share the part number? Thank you.
Lemania 2320
      08-30-2016, 04:21 PM   #8
MR.
MR.'s Avatar
#35002232276
      12-19-2016, 09:10 AM   #9
domriley
Drives: M2
MR
I have mine in order. Should arrive tomorrow. Are there instructions in the kit or is it a case of figuring it out for myself (hope not).
Drilling is not my forte tbh...
      12-19-2016, 10:54 AM   #10
quikM2
Drives: 2017 Jahre M3
I have these. They look great for sure but the big win is they are actually very sticky and feel great over the stock pedals. IMO these should be the stock pedals.
Prollig118.00
      12-19-2016, 11:05 AM   #11
CommitConfirm
United Kingdom
475
Drives: The Bus
Do they make you go faster?
Robban267.00
ried791.50
      12-21-2016, 03:33 PM   #12
Tralfaz
Drives: 2017 Long Beach Blue M2
The fact that the black areas are raised rubber does give good "traction" for the foot when it's on the pedal. My RX-8 had the stock "fake" drilled aluminum pedals, but I think the ridges on these pedals feel like they give better traction than the raised rubber bumps the RX-8 pedals had. These certainly provide better traction than the stock pedals my 135 had.
      12-22-2016, 09:21 AM   #13
quikM2
One of those eh...
      12-23-2016, 04:41 PM   #14
MR.
MR.'s Avatar
No instruction! All comes to yourself finding it out. It is not difficult at all!
MR
      12-23-2016, 04:42 PM   #15
MR.
MR.'s Avatar
I got one symbolic extra horsepower after installing them!
MR
Flunx4.50
      01-08-2017, 12:17 PM   #16
saint3448
Drives: 2019 Sunset Orange M2C
Anyone know if a DIY exists for this? Got a set shipped to me, but no instructions.
Thanks
      01-08-2017, 06:01 PM   #17
nd2002
nd2002's Avatar
179
Drives: 2017 M2
Thanks
Straightforward... Place a towel or something to collect the shavings.
1. Remove OEM rubber covers
2. Put on SS pedal rubber covers.
3. Drill pilot holes into the pedals (brake pedal probably needs a nice Ti drill bit since it's steel). Take rubber cap off again.
4. Brake/clutch: Start with 1/8 and finish at 5/32 drill bit...you can add another intermediate size in between if you like.
5. File the backs of the holes to smooth things out.
6. Put on the rubber cover, then steel one, then tighten it with the provided torx hardware.
7. Go pedal: clean it up to prep for the 3M adhesive backing on the steel pedal.
8. Stick it on and drill 3/32 holes in the plastic.
9. Tighten the gas pedal bolts in (no nuts for this one). Don't over tighten this since it's plastic.
10. Vacuum and clean up.
M2OG400.00
BAN_M2C4185.00
gphung193.50
Kikuchiyo114.50
      01-08-2017, 10:27 PM   #18
Lucho13
Peru
64
Drives: BMW M2 (F87)
Thanks
I used this one.
http://f30.bimmerpost.com/forums/sho...d.php?t=833321
Hope it helps!
      01-09-2017, 08:21 AM   #19
mssVT98
mssVT98's Avatar
142
Drives: 2017 M2
2017 BMW M2  [9.67]
Originally Posted by Lucho13 View Post
I used the same guide, and actually found a couple of the later posts even more helpful. Overall it was very easy, other than the fact that I sliced my finger wide open on the edge of the brake pedal cover. Those things are thin, and apparently pretty sharp!
What I found most interesting, though, is that my brake pedal wasn't at all like all the ones I've seen pictured. They all appear to be thick, flat, hardened steel, which everyone says is fairly hard to drill through. Mine was a relatively thin steel, but it was ridged, almost corrugated, for strength. It was actually easy to drill through, and it just happened that all of the bolt holes were in the "valleys", which made it easy to get the nuts attached on the back. Not sure it would have been possible if they'd been in the "ridges". I wish I'd taken a picture when I had the cover off, since it's a pretty interesting difference.
Just something to keep in mind.
      01-12-2017, 10:00 PM   #20
saint3448
Anyone have straight on pictures from the seat bottom of a 6mt set installed? I installed mine and they seem to be a bit crooked? Can't see how that's possible since the rubber mold goes on snug and doesn't seem to have much ability to twist.....
      01-12-2017, 10:28 PM   #21
BAN_M2C
BAN_M2C's Avatar
4185
Drives: 991.2 Porsche GT3, BMW E46 M3
1987 BMW 325is  [10.00]
2004 BMW X3  [6.50]
2018 Porsche 911 GT3  [10.00]
1974 BMW 2002tii  [10.00]
2004 BMW M3  [10.00]
Going to look thru my phone, might have one. Post the one you have to compare!
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii
      01-13-2017, 08:14 AM   #22
mssVT98
mssVT98's Avatar
142
Drives: 2017 M2
2017 BMW M2  [9.67]
I thought the same thing, but looking at it further I think it's just a trick of how the curved lines of the grooves draw your eye. I think you're right in that it would be pretty hard to actually install them crooked. Don't have a pic on me now but will try to remember to take one when I get back to my car.
m2
