06-17-2016, 03:45 PM | #1 |
1768
Rep 7,652
IND | BMW M Performance Carbon Interior Kit DIY
Available for purchase on our site here: http://ind-distribution.com/ind/bran...erior-trim-set Tools required: T8 Torx Bit Bondo Spreader Cutters DCT Shift Surround Step 1: Insert bondo spreader between cupholder trim and the stock DCT trim. Start to pry the console trim up to where you can grab it with your fingers. The trim will pop out easily and remove it over the shift knob. Step 2: Place the new console trim in position and snap it into place. DCT Shift Knob Step 1: The key to removal of the shift knob is the removal of the gear selector sticker. We remove this piece with a Nylon pry tool to not damage the stock knob cover. Step 2: With the emblem removed the Torx 8 screw will be exposed. Take the Torx 8 driver and remove the screw. Step 4: Now remove the cover from the shift knob and install the BMW Performance cover. Step 5: The BMW Performance cover comes with a new Torx 8 screw, but you can also utilize the old screw. After the set screw is reinstalled apply the new shift emblem. E-Brake Handle Step 1: Pull the E-brake handle off the mechanism, this will take some force. Step 2: Squeeze the upper part of the alcantara boot to release the e-brake boot from the console. As you squeeze pull up on the boot to remove it. Step 3: Pull the entire E-brake boot and handle off the mechanism. Step 4: Fold the boot inside out to expose the cable tie securing the stock handbrake handle. Cut the cable tie carefully not to damage the boot. Step 5: Install the boot onto the new E-brake handle in the reverse as you took it off. (Inside out and secure the boot with the supplied cable tie, cut the excess off) Step 6: Slide the brake handle onto the E-brake mechanism to where it clicks into place. Step 7: Reinstall the alcantara boot back into the center console by snapping it into place.
06-18-2016, 09:36 PM | #6 |
Rep 1,298
06-21-2016, 04:57 PM | #7 |
Rep 2,505
Awesome write up!
I will be purchasing the 6MT kit when it become available!
2019 M2 Competition- October 2, 2018 ED
2011 BMW M3 Sedan Alpine White Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD** |
06-22-2016, 01:30 AM | #8 | |
Rep 542
-c EDIT: hate to hijack the thread, but there's a sticky on the forum that lists ALL MP parts for the ///M2, with part numbers; I contacted my dealer, they could get the 6MT kit. It would come from Germany and take about three weeks. BTW, here is a pic of my knob
2016 BMW M2/LBB/6MT/Exec Pkg
2009 Acura MDX-stock 2008 Acura RDX-stock 2005 Honda S2000-mostly stock 1994 Nissan 300ZX Twin Turbo-barely stock Last edited by pup73; 06-22-2016 at 02:04 AM.. |
07-17-2016, 01:18 PM | #9 |
Rep 22
Just did this on my car. Strongly recommend sneaking couple threads under the gear selector sticker to pull it off instead of pry tool, way easier and no damage to the original parts.
2016 M2
2014 981 Cayman S 2006 GTI 2.0T |
omasou2089.00 |
07-18-2016, 11:26 AM | #11 |
Rep 22
I didn't try, sorry I couldn't help.
2016 M2
08-07-2016, 11:42 AM | #12 |
Rep 616
Drives: M2, X2 M35i, X6,328i,230i
Garage List 2017 BMW 230i [0.00]
2022 BMW X2 M35i [0.00] 2015 BMW 328i [0.00] 2008 Jeep Commander ... [0.00] 2017 BMW M2 [0.00] 1997 BMW Z3 1.9 Roa ... [0.00] 2014 BMW X6 xDrive35i [0.00] |
Is this kit really that much of an upgrade over the stock interior?
09-01-2016, 06:20 AM | #14 |
Rep 58
Damn, I didn't read down far enough about the use of thread under the gear selector sticker to pull it off.
I call BS on the use of a plastic prybar tool to get it off. There is no way plastic could loosen it. I used a butter knife and of course it slightly damaged the old 1. But the carbon is on there to stay so who cares. |
omasou2089.00 |
10-06-2016, 11:58 PM | #16 |
Rep 216
Drives: 2017 BMW M2
Can i buy just the ebrake handle? I have a manual and can't use the rest of the kit.
2016 750i X-drive
2017 GMC Sierra Denali 1997 MB SL500, 19"AMG replicas Past BMWs: E30 323i, E36 325is, E36 M3, E46 M3, E39 M5, E46 325i, E90 335i, F80 M3, F87 M2 |
10-17-2016, 08:32 PM | #17 | |
Rep 3,006
10-29-2016, 11:48 PM | #18 |
Rep 290
I got the carbon fiber and alcantara interior kit from my dealer and my shifter/shifter plate/e-brake are NOT carbon. Did they just forget to install those? My dash near the glove box is alcantara and the door handles are carbon fiber (and bottom of the steering wheels). Did I get the wrong kit, or did the dealer forget to install the parts?
11-01-2016, 06:55 AM | #20 | |
Rep 1,681
Current: ///M2C
G01 X3 xDrive30i Past: ///M2 997.1 Turbo ///M3 E92 |
11-02-2016, 01:58 PM | #22 |
Rep 1,406
Drives: 2020 SO - M2C
Anyone selling this kit used pm me?
