04-20-2016, 12:43 PM | #1 |
Rep 796
Hey guys, sorry for the tease. I'm going In at three to have this thing measured. What are some specs you guys would like to know.
I may even have a few test fitment pics you guys and gals before the day is over. |
04-20-2016, 02:08 PM | #2 |
Rep 1,922
Drives: 2011 e91
Exact clearance to the inner, outer and full lock front and rear of the front wheels. Take a measurement of the actual fender lip too. And then do the same for the rear minus the turn radius bit
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
04-20-2016, 03:35 PM | #3 | |
Rep 796
Some rough estimates so far Conservative/big tire safe - 9.5"fr 10.5"rear Aggressive-ish - 10"fr 11" rear |
04-20-2016, 03:53 PM | #4 |
Rep 2,560
Drives: Rapidly from A to B
Would love to get strut to tire/wheel clearance. Plus inner fender to tire/wheel. I've use a string with a nut on the end held on the inner fender edge as a reference. Same measurements needed in the back.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
04-30-2016, 03:53 PM | #5 | ||
7909
Rep 11,785
You give up a little bit of tire width in the rear but your tires will be happier and your wallet will thank you |
05-01-2016, 02:07 PM | #7 | |
Rep 796
05-18-2016, 07:26 PM | #8 |
Rep 76
curious -- will a square setup change the balance? heard that a few of the performance driving school instructors recommended staggered
05-18-2016, 08:36 PM | #9 |
Rep 128
05-18-2016, 09:25 PM | #10 | |
Rep 796
The slight staggered setup is safer for BMW, the front axle will warn you before someone visits a ditch. |
05-19-2016, 06:14 PM | #11 |
Rep 365
Are you only looking into 19"? I would love to have numbers so I can work out a square 18x10 set.
05-19-2016, 06:16 PM | #12 | |
Rep 796
05-19-2016, 11:30 PM | #13 |
Rep 1,963
275/35 or 275/30? 35 seems pretty tall doesn't it? For 19" wheels?
Current
AW BMW M2 Past VO BMW 1M |
05-19-2016, 11:48 PM | #14 | |
Rep 796
I'm not a fan of super small sidewalls anymore. As this will spend 99% of its life on the road. I don't think a 35 sidewall with a 265 is too much tire, for some reason 275/35 sounds worse to me. I think without proper camber adjustment and stiffer spring rates we would run into rubbing problems if dropped. As always this is just speculation until I throw something on here. |
05-20-2016, 08:36 PM | #15 |
Rep 76
05-22-2016, 10:05 PM | #16 |
Rep 796
Yep. That's the stock basic setup for great tire options. Pretty much setup to run a Pirelli World Challenge slick if your heart desires. I know turner did
05-23-2016, 12:50 PM | #17 |
Rep 76
So what's the straight dope on offset and tyre fitment? I'm hearing that the M2 is a totally different animal from f30 M3's.
I'm wanting to run A7-R7's and getting wheel fitment before June jam at Road A is proving difficult. Last edited by Fullofdays; 05-23-2016 at 01:23 PM.. |
05-23-2016, 12:57 PM | #18 | |
Rep 796
Higher numbers for larger tires and less camber. Lower is more aggressive. |
05-25-2016, 01:16 PM | #19 | |
Rep 820
So 18x10 et25 square with a 10-12mm spacer up front should do the trick? |
05-27-2016, 12:00 PM | #20 |
Rep 1,963
So you can run a 10" et 37 wheel up front without hitting the suspension? I wonder if the stock rears will fit up front.
Current
05-27-2016, 07:16 PM | #21 | |
Rep 796
05-27-2016, 07:18 PM | #22 | ||
Rep 796
