03-03-2016, 11:22 AM | #1 |
Rep 1,184
Camber plates vs M4 LCA
Hey guys,
I have read that the M4 LCA's can you you roughly -1.7 front camber. They also push the wheel forward about an inch. My question is what would the performance/feel difference between -1.7 degrees from M4 LCA and a camber plate set to -1.7 degrees? I ask because I have heard the wheel fitment I want to run will rub with LCA's because of the 1" bump forward. Any insight? |
03-03-2016, 01:51 PM | #2 |
Rep 1,503
I would also like to know. Currently running a 235/40/18 front, wondering if the m4 lca may cause rubbing issues.
FBO M235i r
F80 M3 |
03-03-2016, 05:24 PM | #3 |
Rep 957
there is more to the lcas, bushings are better, wider track, lower height and pushing the wheels forward is better for handling. I run both lcas and camber plates.
03-03-2016, 06:53 PM | #4 |
Rep 1,184
03-03-2016, 06:55 PM | #5 | |
Rep 1,184
Maybe a rolled fender would be enough to fit the LCA. I'd be willing to do that mod, but nothing else |
03-03-2016, 07:43 PM | #6 | |
Rep 5,262
Camber plates might make noise and also not sure if there is a reliable camber plate for the F22 yet... I just keep hearing they fail prematurely but it does give you adjustability |
03-04-2016, 09:19 AM | #7 | |
Rep 1,184
And if you don't mind me asking what is s your front setup? As far as offsets and mods? I plan on having 18x8.5 235/40 mpss. Id like to add the m4 LCA if possible and after that would consider the Dinan drop if it didn't rub. |
03-04-2016, 09:25 AM | #8 | |
Rep 5,262
03-04-2016, 10:03 AM | #9 |
Rep 1,184
03-04-2016, 10:31 AM | #10 |
Rep 5,262
03-04-2016, 10:40 AM | #11 |
Rep 4,518
My LCA's c/w minimal drop stiffer front springs = -2deg camber at the front
Current '22 X3M LCI.. |
03-05-2016, 02:47 AM | #13 |
Rep 4,518
No I'm running OE MPSS tyres but with F30 style 397 18" alloys which are 8" x et34mm.
There are folks here in the UK using LCAS, 18" et40mm with 245/35/18 without issue.
03-05-2016, 09:42 AM | #14 |
Rep 444
I got -1.9 with my LCAs. Thinking of going back to stock with a camber kit though since my set up rubs now. Waiting on a review of the new dinan ones.
Quickest Stock Turbo F8x In The World
03-05-2016, 10:26 AM | #15 |
Rep 137
03-07-2016, 08:17 AM | #16 |
Rep 243
Cloud 9 you mentioned rubbing, rubbing in the front or at the top? I was looking to get some wider 18s in the front with M4 LCAs, want to make sure I don't rub.
03-07-2016, 08:25 AM | #17 |
Rep 127
Are there pics of the LCAs installed on an otherwise stock M235 somewhere on the forum that shows the wheel opening, I couldn't find any?
03-08-2016, 02:53 PM | #18 | |
Rep 444
http://www.2addicts.com/forums/showthread.php?t=1225277
Advant Garde M510s 19x8.5F +35ET 235/35/19 19x9.5R +40ET 265/30/19 Quote:
I'm running 19s, so you might have better luck with your 18s.
