2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes 340mm to 370mm rotors without changing calipers?
      02-16-2016, 01:59 PM   #1
BiscottiGelato
BiscottiGelato's Avatar
Drives: 09 135i M Sport 6MT
I looked through this over and over again and it's still not clear. Everyone says that the M Performance Brakes has the same calliper, just different colour, as the stock M Sport Brakes. However M Perf has 370mm rotors where-as M Sport has 340mm rotors.
This means then one can upgrade to 370mm rotors with the stock M-Sport brakes with just a change of the bracket/adapter? True? Is there a part number for just the bracket/adapter?
This is a huge deal as this reduces on track brake fade. at about $450 a pair, these would be the cheapest 370mm rotors available. (360mm Brembo 2 piece rotors can easily cost $1k+) Don't get why this doesn't get more talked about rather than initial brake feel which actually makes no real performance difference.
Ground Control Camber Plates, Ferrodo D2500 w/ E86 MZ4 2 piece rotors, Dunlop Direzza ZII on Apex EC-7s
      02-16-2016, 02:05 PM   #2
Anderw
Anderw's Avatar
Drives: F80 m3
I would definitely be interested in doing a upgrade like that! also interested
      02-16-2016, 07:57 PM   #3
nike001
Drives: 2018 718 Cayman
I'd talk to Turner about this
      02-16-2016, 08:02 PM   #4
BiscottiGelato
I think I figured this out. It requires a completely different calliper. It seems the offset of the calliper is built into the calliper part itself. There is no adapter...
At $700 each to change the callipers, it is just cheaper to go for the full M Performance kit, which includes the front rotors (and redundant rear callipers in a different colour). $700 + $700 + $450 for getting blank 370mm front rotors. $1500 for the full kit in Yellow.
http://www.turnermotorsport.com/p-19...-bmw-part.aspx
http://www.turnermotorsport.com/p-20...28i-435ii.aspx
      02-17-2016, 02:24 PM   #5
rwalker
Drives: the wheels off
Could source the calipers more cheaply:
http://www.ebay.com/itm/Origional-BM...8AAOSwgyxWUtP-
But yeah the M-Perf kit seems like a steal. I wish I liked fancy caliper colors and dimpled rotors more.
      02-18-2016, 08:01 PM   #6
Dylan86
Dylan86's Avatar
Drives: F15d msport, F22 m235i
Just to confirm, guys..
F30 M Sport 370mm Caliper/Rotor setup is the same as the M Performance kit, for the F22, only Blue?
If so, I will definitely go this route, and wait for some used calipers once the 3/4 series guys start going full BBK's. A great OEM+ solution here, if it's "bolt-on"
I personally would run Stoptech slotted rotors front and back over the M perf rotors, with my pad choices, using the 370mm combo from the F30, sounds like a game plan for next season.
D
      02-18-2016, 08:49 PM   #7
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
D
http://www.turnermotorsport.com/t-br...fferences.aspx
      02-20-2016, 07:21 AM   #8
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Dylan,
I have a set of virtually new blue 370mm blue calipers to go onto my car cw SS hoses, large protection plates to suit 370mm rotors, mpbbk rotors F&R and f8x MP pads upfront and f2x mp pads for the rear.
Due to go on in the few weeks so I will have OE blue MPBBK spec with better hoses all round and better OE pads up front
BP
Current '22 X3M LCI..
      02-20-2016, 07:56 AM   #9
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
This is where I sourced my blue f30 msport / blue MPBBK callipers from. Excellent service and product.
      02-20-2016, 09:00 AM   #10
Dylan86
Dylan86's Avatar
Originally Posted by Bee Pee View Post
Dylan,
BP
Great stuff, can't wait to see it. Be sure to update us with pics if possible
D
      02-22-2016, 06:25 PM   #11
BiscottiGelato
So all the F30 rotors, stock or aftermarket fits the M Perf calipers on the F22? No rotor offset issues, haf offset issues, etc, right?
      02-23-2016, 12:35 PM   #12
Dylan86
Dylan86's Avatar
As far as what I can see, yes.
Next, what's the M2 Brake kit going to run vs this route? Worth it? Probably not..
      02-23-2016, 01:04 PM   #13
rwalker
M2 will have knuckles from f8x, so no use to us
      02-23-2016, 01:33 PM   #14
Pparana
Drives: 2015 m235i
I ran the dimpled, slotted rotors on the stock calipers, no mods, just swapped them on. Turner had them on sale last year for $150 a rotor. For what its worth, I have ran them with street/race, and race pads. I noticed no difference in fade, feel or distance when I went back to stock.
      02-23-2016, 06:24 PM   #15
BiscottiGelato
Plain rotors are always the best performance and price. Can start with the MPerf package and then while the dimpled rotors gotta be changed out, go on to F30 plain rotors~
      02-24-2016, 02:43 AM   #16
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
If weights to be believed the plain std 370mm rotors are a lot heavier than MP 370mm rotors.
The MP rotors are slightly heavier than the plain 340mm rotors I'm swapping out today.
dwtbgc3.00
      02-24-2016, 01:54 PM   #17
rwalker
the weights in realoem are not to be believed, if that's what you mean
      02-24-2016, 03:33 PM   #18
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Yes thought as much.
Install complete. Couple of teasers.......
[/quote]
      02-24-2016, 06:04 PM   #19
pikcachu
pikcachu's Avatar
1403
[/QUOTE]
so those are the stock m sport calipers ?
      02-24-2016, 06:34 PM   #20
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Yes
Front - m sport from an F3x with 370/380 markings
Rear - m sport that comes as OE on F2x mx35i
Wheels are OE F3x style 397 18" x 8" x et34mm refurb'd in ferric grey.
      02-25-2016, 01:30 AM   #21
BiscottiGelato
These are much more aggressive wheel offset than the f3x right? Pic of the whole car by any chance??
      02-25-2016, 04:34 AM   #22
quenotte
France
60
Drives: F87N M2 Competition
Dylan,
BP
Hi BP,
Do you have all OEM references of what you changed for this retrofit on your car?
Thanks!
2addicts
