2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Thoughts on the Dinan Performance Springs
      10-12-2015, 12:40 PM   #1
col4bin
col4bin's Avatar
Drives: 2016 M235i
2008 e92 335xi  [0.00]
I would like to lower my M235 just a enough to get rid of the gap in the wheel well. Does anyone that has these care to comment?
Thinking Dinan as I want to keep my warranty intact.
2016 M235i - Mineral Gray
      10-13-2015, 12:17 AM   #2
BarryJI
BarryJI's Avatar
Drives: 2015 BMW 228i M Sport
I might do the springs on my 228i, although inevitably the labor will be expensive. Two pieces of advice, FWTW: (i) you will be better off doing this through a specialist tuner shop with a well-established Dinan license rather than a dealership, even one authorized to install Dinan products. There was a horror story in these forums recently from a guy whose car was all but ruined when a non-Dinan BMW dealership (also his employer, ouch) installed his springs upside-down. He was $1000 down with a crippled car and no warranty on the work. Always use a high-quality Dinan performance shop. Finally, (ii) make sure you get the ride kit with the springs. Good luck and please keep us posted.
      10-13-2015, 09:40 AM   #3
Steve80bk
Drives: 2015 superman m235i on the way
I had the springs installed on my m235i about 2 months ago.. I definitely recommend the upgrade. I have been using the same high quality shop since I first got my license, (I'm 35 now) so I trusted them to install them properly. In my opinion, this is the way the car should've came. It handles better, the gap is closed giving it a nice even look front to back, recovers from bumps faster, rolls less, and in sport mode isn't harsh at all. To me, it feels just right. Hope this helps.
      10-13-2015, 11:49 AM   #4
col4bin
col4bin's Avatar
Drives: 2016 M235i
Thanks. Anyone have a good rec in the San Diego area?
      10-13-2015, 12:39 PM   #5
Michall
Drives: 15 M235i
Could you post any side shots of your car with those springs installed? Thanks.
      10-13-2015, 01:00 PM   #6
Steve80bk
Here's a few shots of the side.
      10-13-2015, 01:02 PM   #7
col4bin
col4bin's Avatar
Drives: 2016 M235i
Looks great. Thanks for the pics.
      10-13-2015, 01:16 PM   #8
s1uma1
Drives: 2015 M235i
got the springs and supplemental kit. pleased with the drop height and ride. Improved ride with better handling. When i say improved, i mean no more crazy bumpy ride, less roll. seems like dampening is a lot better. No issues with clearing speed bumps or driveways...
18s on dinan springs:
      10-13-2015, 02:23 PM   #9
gasspasser
gasspasser's Avatar
Drives: 2015 M235i
Autohaus Frankfurt in Murrieta
2015 M235i BSM / 2011 X5D AW
      10-13-2015, 02:26 PM   #10
col4bin
col4bin's Avatar
Drives: 2016 M235i
Thanks.
      10-14-2015, 09:57 PM   #11
Mjosh
Drives: E46 M3
Really like the conservative drop of Dinan springs. Has anyone paired them with aftermarket shocks?
      10-16-2015, 10:00 AM   #12
Michall
Drives: 15 M235i
To those who installed Dinan springs. Do those springs come with the hardware or you reused the old, stock hardware?
      10-16-2015, 01:58 PM   #13
MrBimmerM235i
Drives: M235i
Dinan drop with spacers...
      10-19-2015, 06:40 PM   #14
Ace604
Drives: 2019 M2C
How much lower are the dinan springs compared to the m sport suspension?
      10-20-2015, 11:31 AM   #15
Viffermike
Viffermike's Avatar
Drives: '18 black-n-blue 718 Cayman
The M Sport suspension drops both axles 10mm. The Dinan springs drop the front axle 1/2 inch (13mm) and the rear a full inch (25mm). Simple math says the Dinan springs will drop a car with M Sport suspension 3mm in the front and 15mm in the rear.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.--
<<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>>
      10-24-2015, 07:43 PM   #16
TreDirtyFive
Drives: X3 M40i
Here is mine on the Dinan Springs...do not bother with those overpriced E30 M3 bumpstops (which you can just get at a dealership) that Dinan calls a supplemental comfort kit. Just cut your stock ones (no shock disassembly needed) takes 5 min each side and you get the same smooth ride. cheers.
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
      10-25-2015, 01:27 AM   #17
ocN55
ocN55's Avatar
Drives: '15 M235i 6MT/ '16 M3
Then do you need to get new bump stops when going back to stock if you cut them?
FBO M235i r
F80 M3
      10-25-2015, 07:34 PM   #18
TreDirtyFive
Drives: X3 M40i
No, it will not effect the ride quality when you go back to stock.
      10-26-2015, 12:05 AM   #19
ocN55
ocN55's Avatar
I wonder if the same could be done for H&R springs...
FBO M235i r
F80 M3
      10-26-2015, 12:27 PM   #20
TreDirtyFive
Drives: X3 M40i
Yes. I will bet after 10K+ the car will get bouncy...at least that has happened with me on every H&R spring-only setup I've had unless I cut or got shorter bump stops. There simply isn't enough shock movement over time and the shock will surely lose its rebound effectiveness. good luck!
      10-28-2015, 03:27 PM   #21
M235iCA-guy
Drives: 2015 M235ix & X5d
MrBIMMERM235i...I have the front splitter too, did you have problem clearing road bumps after installing the Dinan spring & handling kit?
      10-28-2015, 03:29 PM   #22
M235iCA-guy
S1UMA1...what wheels and setup do you on your car?
2addicts
