2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes M3/M4 lower control arms.
      09-20-2015, 10:51 AM   #1
jordantii
Drives: M2 Sea
So I ordered these parts and will install them this week. Looks pretty straight forward. What I am wondering is if anyone else on the forum has installed them and what the results were? I have been through the threads but there is very little talk about the results forum members have had.
This is not a track car, just looking to get a little more camber up front.
      09-20-2015, 11:44 AM   #2
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Jordan,
Have a read of this thread
http://f30.bimmerpost.com/forums/sho...ght=Lca&page=2
BP
Current '22 X3M LCI..
      09-20-2015, 11:51 AM   #3
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
yes they work great
http://www.2addicts.com/forums/showthread.php?t=1079766
      09-20-2015, 01:58 PM   #4
jordantii
Drives: M2 Sea
Thanks Gents. I have read those threads a while back so it was nice to re-read them. Looks like it will add a few degree's of castor which I have no problem with and the camber gain looks perferct for the street. I have Xenons and will also install the M3/M4 bits for them as well.
      09-20-2015, 02:40 PM   #5
pikcachu
pikcachu's Avatar
1403
make sure to reuse your stock rod with the M4 ball joint http://www.2addicts.com/forums/showp...2&postcount=67
      09-26-2015, 03:25 PM   #6
jordantii
Drives: M2 Sea
It's been 24 hours since the install and alignment and the car does feel better over all. I'm sure some is due to the alignment I spec'd and of course the control arms. Steering feel is pretty much the same maybe a tad stiffer. Turn in is where I notice it the most. Very immediate and more controlled. Worth the money especially since I won't shred tires in 13,xxx miles again.
      09-26-2015, 07:43 PM   #7
JibHonk
Drives: 15 m235i
How much if you don't mind me asking
      09-26-2015, 07:48 PM   #8
pikcachu
pikcachu's Avatar
1403
http://store.gsrautosport.com/F8xflc...2284529-30.htm
      09-27-2015, 05:50 AM   #9
jordantii
Drives: M2 Sea
I actually bought them from Turner Motorsports. They had them in stock. I wouldn't buy from GSR, they never returned my calls or emails when I was looking to purchase. Zero customer service.
      09-27-2015, 08:00 PM   #10
i8ur911
Drives: F22 228i MSport
      09-28-2015, 11:14 PM   #11
abirmaher
abirmaher's Avatar
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
  [0.00]
2018 BMW M2  [10.00]
Sorry if this is a noob-ish question but can someone explain the light leveling and what I would need for that? I am a bit confused.
Essentially it sounds like its the control arms and 2 other parts I would need. Can you break down what exactly I would need to make this work?
Thanks!
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010
The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35
      09-28-2015, 11:30 PM   #12
pikcachu
pikcachu's Avatar
1403
Thanks!
light leveling is a sensor that connects to the suspension and lets the adaptive light know when to move up and down...
explanation of what you need with a picture of the final product is here http://www.2addicts.com/forums/showp...2&postcount=67
basically you reuse your stock leveling rod and just use one of the ball joints from the kit that comes with the arms
      09-29-2015, 07:42 AM   #13
jordantii
Drives: M2 Sea
You could save a little money if you just order the arm and use the longer ball end. There is no need for the bracket to relocate the sensor. You will have to adjust the lights but that is pretty simple. There is a link on here somewhere. Search is your friend.
      10-08-2015, 08:30 PM   #14
G4Z808
G4Z808's Avatar
30
Drives: not yet
any other tips for install ? I plan on putting them on tomorrow, haven't messed with suspension parts much.
also was my let's supposed to come with the leveling rods ? mine didn't come with any. I should be able to reuse the stock one right ?
      10-08-2015, 08:48 PM   #15
pikcachu
pikcachu's Avatar
1403
you need the ball ends else you won't be able to attach the rod
      10-08-2015, 09:09 PM   #16
G4Z808
G4Z808's Avatar
30
Drives: not yet
I ordered the LCA'S from gsr, we're they supposed to come with the rods ? where can I order the rods by themselves
      10-08-2015, 09:40 PM   #17
pikcachu
pikcachu's Avatar
1403
you don't really need the rod, just the ball end as the M4 LCA attaches with a bolt and nut instead of the clamp the stock LCA uses
      10-08-2015, 09:41 PM   #18
G4Z808
G4Z808's Avatar
30
Drives: not yet
were they supposed to come with the lca from gsr ?
      10-08-2015, 09:45 PM   #19
pikcachu
pikcachu's Avatar
1403
depends if you bought the one for xenons or the regular one... the xenon one has the hole to attach the rod
http://www.turnermotorsport.com/p-21...trol-arms.aspx
      10-08-2015, 09:47 PM   #20
G4Z808
G4Z808's Avatar
30
Drives: not yet
gsr is only selling one kit, and it comes with the lca with the hole on it for the rod, but it didn't come with the rod. guess I have to order my own. sucks, I wanted to put them on tomorrow
      10-08-2015, 09:51 PM   #21
pikcachu
pikcachu's Avatar
1403
didn't it come with the ball end?
you don't need the rod.... just the ball end with the bolt on the other side... so you pop out the stock ball end that comes with the clamp and put the ball end with the bolt....
I guess you could try to adapt the clamp to work with the M4 LCA but it won't look pretty
This is how it looks with the stock rod and the M4 ball end
      10-12-2015, 08:30 PM   #22
i8ur911
Just an FYI, if you're not familiar with this stuff, if recommend someone doing this install. Not because it's difficult by any means, but it's going to throw your alignment of BIG TIME......major toe in. Unless you have toe plates or an alignment shop next door, it will need to be done somewhere that is capable of getting your toe settings somewhat close.
Again, just an FYI.
2addicts
