2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes KW Suspension | V1 V2 V3 ClubSport | F22 M235i
      08-12-2015, 05:20 PM   #1
AutoTalent
AutoTalent's Avatar
2312
Drives: e92 M3 6mt | e60 M5 6mt
Please PM or email: Golan@AutoTalent.com with any questions!
KW Coilover Kit - Variant 1 (V1) - F22 M235i
Part #: 1022000F Without EDC / 1022000G With EDC
Factory Pre-set Damping
The Variant 1 is KW's basic simple and effective coil over kit that is still packed with lots of features -
Pre-set damping optimized for a blend of ride comfort and handling with less bodyroll than the standard suspension,
Stainless steel strut/shock bodies and composite spring perches for superior corrossion resistance,
Individually height-adjustable - Front = 25-50mm lowering; Rear = 30-55mm lowering,
TUV approved lowering range and operation,
Expert engineering and design for ease-of-use and long durability,
This is the ideal coil over kit for a F22 owner who does not plan on tracking or autocrossing the car and just wants a lower, more aggressive stance and better handling. KW has set the shock damping rates to be an excellent balance for a smooth yet taut ride, and to resist bodyroll motions for better handling. The Variant 1 differs from the Street Comfort set in that it has stiffer springs and revised shock settings. If you want a sportier ride and better handling than stock the Variant 1 is an excellent choice.
Coil over suspensions are better engineered suspension options compared to a standard shock + spring package. Since the springs and shocks in a coil over are designed by a team of engineers to work together, there is much better suspension travel and more precisely tuned specifications for spring and shock rates. Using separate shock and spring specs may result in premature coil bind or shock bottoming. And most coil over kits offer more features than the traditional packages. Coil overs are also more useful when larger wheels/tires are used because you can precisely set the ride heights to clear the new tires.
KW Coilover Kit - Variant 2 (V2) - F22 M235i
Part #: 1522000F Without EDC / 1522000G With EDC
Adjustable Rebound Damping
The KW Variant 2 gives shock rebound control to give you more options in fine-tuning the handling of the car. The V2 includes the same features of the V1 kit, including -
Adjustable Rebound with fixed compression settings - optimal ride comfort then dial in more grip and a better balance with less bodyroll than the standard suspension,
This kit is an excellent compromise between a fully-adjustable V3 suspension and the basic V1 street kit. It's great for someone who does not want to make complicated and time-consuming shock adjustments. Just dial in the rebound for more grip and less body motions. Set it back for a compliant street ride.
KW Coilover Kit - Variant 3 (V3) - F22 M235i
Part #: 3522000F Without EDC / 3522000G With EDC
Adjustable Rebound & Compression Damping
Want full control? The KW V3 gives you multiple settings for both rebound and compression. You have full access over ride comfort and handling to dial in that perfect setup. Race teams rely on adjustments to get that perfect lap time and having shock controls at your fingertips is key. KW V3 features -
Separate adjustments for compression (14 positions) and rebound (infinite settings),
Stiffer springs over stock for less bodyroll than the standard suspension,
Whether you track the car often or only use it for backroad carving the V3 will give you the tools to set up an ideal handling condition. You can crank it up for smooth and fast surfaces or soften it for city or rough roads. Since each shock is 2-way adjustable you can alter the front-rear balance to account for brake dive or squat during power application coming out of the corner. You are in total control!
      09-02-2015, 04:36 PM   #2
AutoTalent
AutoTalent's Avatar
2312
Bump!
      09-29-2015, 01:21 PM   #3
AutoTalent
AutoTalent's Avatar
2312
Bump!
      09-29-2015, 10:16 PM   #4
JibHonk
Drives: 15 m235i
I've got a 15 m235i. Do mostly drag racing, roll racing with about 8 road course track days a year. My car has EDC would you recommend the v2 as being enough for me? I Findmyself wishing for more stiffness even on sport+ with factory struts and h&r Springs.
      09-30-2015, 01:21 PM   #5
AutoTalent
AutoTalent's Avatar
2312
Sending you a PM...
      11-20-2015, 01:38 PM   #6
AutoTalent
AutoTalent's Avatar
2312
Bump!
      11-22-2015, 08:20 PM   #7
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
Can you PM me the V3 without EDC shipped to 29223 please?
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project
http://www.instagram.com/steve_inf31
      11-23-2015, 03:33 PM   #8
AutoTalent
AutoTalent's Avatar
2312
PM coming with Black Friday option as well...
      11-24-2015, 07:24 AM   #9
SteveInfante
Thanks. Send you a PM back with wheel questions as well.
      11-24-2015, 12:48 PM   #10
AutoTalent
AutoTalent's Avatar
2312
PM SENT!
      12-14-2015, 08:09 PM   #11
AutoTalent
AutoTalent's Avatar
2312
Bump!
      12-29-2015, 07:10 PM   #12
AutoTalent
AutoTalent's Avatar
2312
End of the year specials! PM for more info!
      01-06-2016, 08:13 PM   #13
AutoTalent
AutoTalent's Avatar
2312
Bump!
      01-09-2016, 12:57 PM   #14
Cloud IX
Drives: Quickest Stock Turbo F8X
Price for v2 please with and without EDC
      01-11-2016, 12:24 PM   #15
AutoTalent
AutoTalent's Avatar
2312
PM Coming!
      03-07-2016, 01:12 PM   #16
AutoTalent
AutoTalent's Avatar
2312
Bump!
      04-04-2016, 02:04 PM   #17
AutoTalent
AutoTalent's Avatar
2312
Bump!
      04-19-2016, 04:06 AM   #18
Shuo123
Drives: 435i
With EDC option, do I still notice the difference when I switch to sport+? also PM V3 with EDC.
      04-25-2016, 10:05 PM   #19
Chris_B
Chris_B's Avatar
Drives: Melbourne Red 2016 M235i
2010 BMW 128i  [0.00]
If I am correct, the EDC module is a bypass module. AKA It will automatically clear the code thrown because of a "malfunction" (Which will lock your car in comfort mode) and/or completely bypass the EDC itself, and allow you to "switch" modes as normal without actually changing any suspension settings.
So theoretically, no. There is no dampening adjustment because these coil overs are tuned by you, not the car's coding.
I believe?!? Don't quote me on that.
Past: 2008 BSM BMW 128i 6sp w/ EU spec interior.
Past: 2010 BSM BMW 128i 6sp +Msport
2016 MR BMW M235i
Instagram @project_kristi
      04-26-2016, 02:53 PM   #20
AutoTalent
AutoTalent's Avatar
2312
PM Sent.
Correct.
      04-29-2016, 05:40 PM   #21
Chris_B
Chris_B's Avatar
Correct.
I did my homework
2016 MR BMW M235i
      05-01-2016, 04:05 PM   #22
BD_F22
BD_e92
Drives: 2015 m235i xDrive
Can I have a quote for v3 with EDC module and also if you carry the KW DDC kit. Thank you!
2addicts
