BMW 3-Series (E90 E92) Forum
What amp for Focal ps 130f & JBL p560c ?
03-18-2015, 04:57 AM | #1 |
Rep 241
I am in the process of buying new aftermarket audio and replacing the radio and the logic 7 audio in my e92.
After doing some research, I ordered a pair of New Focal ps 130f ($255), JBL p560c ($87) and 2 x sws-8x ($221) What 5 channel D amp would be great for this setup that could fit in the oem amp location ? All the options i know of, like Alpine pdx-v9 pdr-v75 JL 700/5 are either too expensive or hard to find in used condition. Alpine mrx-v70 seems nice and affordable but it won't fit. What about arc audio xdi 805 ? Last edited by constantin_md; 03-18-2015 at 05:05 AM.. |
03-18-2015, 08:59 AM | #2 | |
Rep 13,018
So you are going to cut your door panels and have about 1/2" of the speaker coming out?
03-18-2015, 11:22 AM | #3 |
Rep 13,122
There is a speakers that fit section in the following thread
http://www.e90post.com/forums/showthread.php?t=641323 |
03-18-2015, 12:22 PM | #4 | ||
Rep 3,969
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
03-18-2015, 01:00 PM | #5 |
Rep 994
do a Helix PP82 dsp/amp combo
iPhone 6 Plus (iTunes library/iTunes radio/Waze, etc) to Airport Express via AirPlay. Toslink out of Airport Express to Helix P-Six DSP. PHD AF 1.C tweeters, PHD FB 4.1 midranges. Jehnert Door Cards and mid-bass'.
03-18-2015, 04:04 PM | #6 | |
Rep 241
I really hoped they wouldn't stick out. I've seen a guy on this forum install alpine spr-50c in e92 without them sticking out. The focals are only 0.12' more, top mounting depth. |
03-18-2015, 04:06 PM | #7 | |
Rep 241
03-18-2015, 04:10 PM | #8 |
Rep 241
03-18-2015, 04:27 PM | #9 |
Rep 241
Is arcaudio xdi805 or ppi p900.5 a good option for my speakers?
I think both amps are around 80db s/n and both speakers are 91db s/n Would this choice of amps affect sound quality? Last edited by constantin_md; 03-18-2015 at 06:26 PM.. |
03-18-2015, 08:37 PM | #10 |
Rep 241
i finally found locally a mint jl xd700/5 for $300 . The hertz hdp5 i also found was over my budget at $370
so far i bought metra 95-9306B double din kit - $21.98 Parts Express 12 VDC 5-Pin Relay Socket - $3.10 Absolute RLS125 12-VCD Automotive Relay SPDT 30/40A - $3.89 GTMAT 10sqft 50mil - $18.99 knukonceptz kit + knukonceptz 20ft 4 channgel rca - $67.47 Pioneer AVH-x5700bhs - $339 steering adapter metra aswc-1 - $45 hand brake video bypass - $10.48 trunk handle reverse camera - $29 Metra 40-EU10 antenna adapter - $4.50 earthquake subwoofers adapters - $6.46 (used) monoprice 6ft 3.5mm - $3.50 earthquake sws-8x x2 - $221.27 fuse tap mini - $4.29 Metra 70-9003 harness - $4.25 Focal ps 130f - $255 JBL P560C - $87 JL XD700/5 - $300 (used) $1417 I hope i can sell later the stock speakers, amp , radio , bluetooth, brackets , grills... for about $1200 |
03-18-2015, 09:15 PM | #11 |
Rep 994
you keep mentioning speaker s/n figures and that doesn't make sense. are you talking about speaker sensitivity? while we are at it, 80dB s/n ratio on an amp is horrible.
03-18-2015, 09:53 PM | #12 |
Rep 241
You are right, i got confused.
I thought the speakers have also s/n like on the amp. Last edited by constantin_md; 03-18-2015 at 09:59 PM.. |
03-18-2015, 10:01 PM | #13 |
Rep 994
the dB number for an amp measures signal to noise ratio...a measure of sound quality. the speaker's sensitivity just tells you how much more output you'd get between similar drivers with different sensitivity numbers. 3dB represents 1/2 power. so a speaker at 50 watts with 91db efficiency will sound twice as loud as a speaker with 50 watts that has 88dB efficiency.
03-18-2015, 11:17 PM | #14 |
Rep 94
Keep in mind you will need to sell the Focal ps 130f unless spend some money and time to custom build some new door panels. You will have hard time to fit these Focals in E92 Coupe front doors
2017 F82 M4 CP - Black Sapphire Metallic - drive it like you stole it
2014 F10 550xi M Sport - Jet Black - gone 2010 E92 335i Coupe - Black Sapphire Metallic - gone 2004 E46 330xi Sedan - Black Sapphire Metallic - gone |
03-18-2015, 11:23 PM | #15 | |
Rep 241
I didn't know the speaker sensitivity makes such a difference. Thanks! |
03-18-2015, 11:27 PM | #16 | |
Rep 241
focal have only 0.12'' more top mounting depth I know it doesn't look great, but it should sound awesome. If my car was new i would have never done such install http://www.e90post.com/forums/showthread.php?t=757290 This is my old, sold e90 install: Last edited by constantin_md; 03-18-2015 at 11:33 PM.. |
03-18-2015, 11:47 PM | #17 | |
Rep 94
The Alpine SPR-50c 5 1/4 in the picture are 57mm (2.25in) top mount depth. Your PS 130F are 61.5mm top mount dept. We are talking about an extra 4.5mm. Check the list ctuna added. And I believe that guy with Alpine speakers has hard time to move the windows.
03-19-2015, 12:07 AM | #18 | |
Rep 241
What if i add a spacer? Also, do you know a easy way of cutting the door panels cut out diameter for 5.25'' speakers ? Last time i did it on e90 with a hacksaw blade and it was a pain... |
03-19-2015, 12:13 AM | #19 |
Rep 13,122
There are now a lot more BMW direct fit no hassle three ways
There are now a lot more BMW direct fit no hassle three ways.
(Under seat and door combo's) There are no really cheap ones though . Jehnert , Gladen/Helix , MBquart, and Focal . People use to use diamond audio and DLS (I think) I don't see those come up much anymore must have been discontinued. The point is the Focals are not the only thing that fits. |
03-19-2015, 12:32 AM | #20 |
Rep 94
E92 doors are 5-7mm shallower than E90 so it will be harder this time. Spacers will solve the mounting issue but will look really bad.
03-19-2015, 12:35 AM | #21 | |
Rep 241
On the link you gave me i found: "Reportedly, e92 & e93 front doors have only about 43 mm mounting depth, measured from the grille side of the speaker adapter. E90 doors have roughly 50 mm depth." I top mounted the spr-50c with 57mm depth on e90 with no windows open close issues. I'm wondering if the measurements were made up to the foam padding or to the window ? There was about 10-15mm more depth when foam padding was removed on e90 |
03-19-2015, 12:50 AM | #22 | |
Rep 241
The diameter between door handle and dashboard seems to be bigger on the right door of e92 compared to e90, so hopefully won't have this issue now. |
