BMW 3-Series (E90 E92) Forum
new professional head unit , what is needed to get it to work
02-15-2015, 06:25 AM | #1 |
Rep 268
Hey guys
I got a new head unit for my car since the LCD screen is shot on mine. I understand I need to programme it to work with the car. Any DYIs on this ? I got the the inpa cable coming from eBay I'm hoping this can handle it Any help is appreciated Thanks |
02-15-2015, 11:21 AM | #3 | |
Rep 268
I'm suppose to have blue tooth but idoes not work when I try to pair my phone Where do I get this NCSexpert I'm assuming its software ? How can I get it to communicate with the unit ? |
02-15-2015, 11:52 AM | #4 |
Rep 13,122
You need to to a VIN Check
You need to to a VIN Check .
There are many free BMW vin checkers on line they will list your options. Do you have the phone symbol when you press the menu button if you do you have bluetooth phone. Get familiar with your coding setup by doing something simple like programming the kefob to shut the windows as a check you are doing things correctly . Unfortunately some of the downloads in files above no longer exist. would have been easier to change the screen. Inpa ebidas and ncsexpert come in a software package you use to be able to download them easily they are not huge files. I bought them with my cable but you may have to update the daten files . ebay has it sometimes but I would do an Internet wide search. Go to bmwcoders.com or the coding subforum here for more info. Last edited by ctuna; 02-15-2015 at 03:37 PM.. |
02-15-2015, 03:29 PM | #5 |
Rep 5,120
Depending on the year you might not be able to code it with ncs expert. After you get ncs expert working(read the stickies in the coding section) try the following to reset the headunit based on the vo.
1. Load NCSExpert. 2. Load Profile and select Expertmode 3. F1 (VIN/ZCS/FA) 4. F3 (ZCS/FA f .ECU) 5. Choose E89 (for the E9X) 6. Select CAS 7. F6 (BACK) 8. F4 (Process ECU) 9. Select the Module you want to Revert back to Stock. (2urad) 10. F2->Choose "SG_Codieren->ok 11. F3->to start coding the ecu with factory settings according to the vehicle VO. |
02-15-2015, 06:27 PM | #7 |
Rep 13,122
Its not that bad if it works the first time.
To be good with NCSexpert does require some study but there are a lot of canned procedures now. |
02-15-2015, 06:36 PM | #8 |
Rep 268
OK I'm pretty technical I should be able to figure it out with some help.. BTW I checked the vin and below is all I can find in the list that refers to the radio. I do have the phone symbols on my deck and the steering wheel but I can't add a phone for the life of me. I followed the instructions on the youtube no dice may its broken on the old deck.
S645A BMW US Radio BMW US Radio S663A Radio BMW Professional Radio BMW Professional |
02-15-2015, 10:04 PM | #10 |
Rep 268
So I have the button on the head unit I'm not sure what options it gives me its been a while.. I'm in the hospital for the next day or two ill check it out when I'm out and see
