2Addicts
2Addicts
2Addicts | BMW 2-Series forum Classifieds Commercial Classifieds Engine / Drivetrain / Exhaust / Bolt-ons ▀▄ eas | Macht Schnell - Exhaust Valve Control (EVC) Module
      01-19-2015, 05:48 PM   #1
kevin @ eas
General
kevin @ eas's Avatar
Drives: 2015 BMW M4
Compatible with all exhaust systems (OEM or aftermarket) that retain the factory EVC control, the Macht Schnell Exhaust Valve Control (EVC) Module allows FULL user control of your exhaust system at the touch of a button. No clumsy key FOBs or additional equipment is needed - this is a 100% integrated solution and the first of its kind for current BMW models.
BMW's Exhaust Control Valve is integrated at the exhaust system end pipe of the muffler. The exhaust flap reduces the noise level when the engine is idle and when the engine speed is close to idle. This reduces the outlet noise to improve comfort to the driver. The reduction on a stock exhaust system is ~8dB on the stock exhaust system.
The Macht Schnell EVC Module supports the following features:
- FULL control over Exhaust Valve Control at the touch of a button - on the fly or while stationary
- Open/Close Exhaust Valve at YOUR command, or use BMW's factory profile for Exhaust Valve Control
- Optional User-defined Valve Control Setting at startup (Open/Closed) or default to OEM operation
- Quiet Cold Start in mornings compared to OEM operation
- Easy 20-minute installation process with no wire cutting
- No dealer visits or coding required after installation
- Completely removable at any time
Simply press the BC stalk for +2 seconds to change EVC modes. This is the feature that should have been standard from BMW.
The Macht EVC module utilizes the instrument turn signal indicators to give a visual confirmation of what particular mode you are in. Outside turn signals are not affected during operation and operate normally.
EVC Settings
Left Turn Indicator (single flash) = Exhaust Valve Open
Right Turn Indicator (single flash) = Exhaust Valve Open
Both Turn Indicators (single flash) = Auto/OEM Mode (factory behavior)
User Configurable Settings
Feature Enabled: Resets EVC to default operaiton at vehicle startup
User-Defined: Remembers last used setting at vehicle startup
Additional Features
The Macht Schnell EVC module also has a user-configurable Check Engine Light Suppressor model for those running Catless downpipes.
Passive / Invisible mode
Auto passive mode will allow factory electronic test equipment or other aftermarket devices to be utilized without causing irregularities in readouts or operation
USB Port for easy setup / updates
Module can be configured and updated using via PC
Unique design features only to be found in Macht Schnell EVC Module
Fully E13 tested and certified: E13 10R-02 4133
Ultra-low power standby mode (less than 0.1mA)
InstallAID LED shows correct installation and status
Intuitive Setup menu for easy customization
Models Supported:
2014+ F2X 2-Series with electronic valve control
2013+ F3X 3-Series with electronic valve control
2014+ F3X 4-Series with electronic valve control
2015+ F8X M3/M4 (all models)
WARNING: Please note that certain aftermarket exhaust systems and/or accessories may not comply with applicable US (including California) laws and regulations, and may therefore be prohibited for use on highways or roads, or on roads or vehicles otherwise subject to emissions control requirements. California prohibits the use of any aftermarket exhaust system that modifies, removes or replaces original equipment catalysts, unless CARB has issued an Executive Order as to such part or system.
Ordering:
Phone:
You can reach us directly by calling 866.669.0705 to place your order over the phone.
Payment:
Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone)
Other Payments:
Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods.
Tax:
All CA customers will be charged 8.0% CA Sales tax.
Shipping:
All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees.
Hours of Operations:
Monday - Friday from 9AM to 5PM PST
Saturday/Sunday - Closed
Retail Location/ Installation Center:
Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell.
Contact Info:
Phone: 866.669.0705 x31
Email: kevin@europeanautosource.com
Website: http://www.europeanautosource.com
Feel free to contact me via PM, email, or phone if you have any questions.
___________________________________________
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31
      01-20-2015, 06:26 PM   #2
kevin @ eas
General
Drives: 2015 BMW M4
Thanks for the inquiries! Call or PM today to get our Macht Schnell EVC!!
      03-05-2015, 05:57 PM   #3
kevin @ eas
General
Drives: 2015 BMW M4
Originally Posted by govad View Post
Does this work with the GTHAUS exhaust for the M235?
The Meisterchaft is actually on a different valve system from OEM valve control
Macht Schnell EVC modules back in stock
Call or PM to get yours
      08-18-2015, 06:59 PM   #4
stefan @ eas
Drives: BMW E60 M5
Call or PM to get your Macht Schnell EVC module from eas today!
We have plenty in stock.
      09-14-2015, 03:35 PM   #5
stefan @ eas
Drives: BMW E60 M5
The Macht Schnell EVC module utilizes the instrument turn signal indicators and tachometer needle to give a visual confirmation of what particular mode you are in. Outside turn signals are not affected during operation and operate normally.
Exhaust Valve Settings
- “On Demand” Exhaust Valve Control. Exhaust valves can be operated while parked or while driving in following modes:
Exhaust Valve open at all times
Exhaust Valve Closed at all times
Auto/OEM Mode (factory operation)
EVC Memory Recall
- Exhaust Valve can be set to remember last used position or revert to closed position upon engine start
Active Sound Configuration
- The option to configure the Active Sound is available in a variety of options for suit one’s needs. User has the option to deactivate Active Sound permanently, or only to operate within certain modes: for instance, while with the valve flap open, or only with valve flap closed.
1-Touch Comfort Window/Mirror Closing Upon Vehicle Locking
- Comfort Closing will allow the windows and/or mirrors to 1-touch close upon locking automatically. This option can be configured to only close windows, only fold mirrors or close windows/fold mirrors together automatically.
OBD2 Cycling
- OBD2 Cycling is helpful when performing diagnostics or clearing engine codes on a programmable timed cycle. Also useful for those running off-road track setups.
Increased Halo Brightness
- For those equipped with LED headlamps, the brightness level can be increased by approximately 40% for maximum intensity while driving
Models Supported:
2013+ F2X 1-Series/M135
2014+ F2X 2-Series/M235i
2012+ F3X 3-Series models
2014+ F3X 4-Series models
2015+ F8X M3 & M4
2013+ F1X X5/X6
2015+ F85/F86 X5M/X6M
      10-10-2015, 10:27 AM   #6
13beamer
Drives: 328i XDrive
Has anybody bought this? I'm interested to see if it was worth it to you. You can PM me if neeeded! Thanks
      10-20-2015, 12:19 PM   #7
stefan @ eas
Drives: BMW E60 M5
Call or PM to get your Macht Schnell EVC Module from eas today!
      12-03-2015, 07:52 PM   #8
stefan @ eas
Drives: BMW E60 M5
      12-10-2015, 07:37 PM   #9
stefan @ eas
Drives: BMW E60 M5
      12-17-2015, 03:06 PM   #10
stefan @ eas
Drives: BMW E60 M5
      12-24-2015, 01:20 PM   #11
stefan @ eas
Drives: BMW E60 M5
      12-30-2015, 01:48 PM   #12
kevin @ eas
General
Drives: 2015 BMW M4
Macht Schnell EVC modules in stock and ready to ship
PM today for pricing and details
      01-06-2016, 11:26 AM   #13
stefan @ eas
Drives: BMW E60 M5
      01-13-2016, 06:12 PM   #14
stefan @ eas
Drives: BMW E60 M5
      01-20-2016, 01:12 PM   #15
stefan @ eas
Drives: BMW E60 M5
      01-25-2016, 11:57 AM   #16
stefan @ eas
Drives: BMW E60 M5
2addicts
