12-16-2014, 08:13 PM | #1 |
Rep 124
Wtb f30 Brembo 4 front piston caliper.
I have an e90 335 and going to swap my front calipers to f30 calipers and don't mind a used set. I can't fit the rears and can't use f30 rotors so purely looking for f30 4 Pistons. Can be grey blue or any color. If I'm correct they are all the same except the type of pads and rotor size and since I can't use the rotor ideally a grey unfinished set would work. If u have a complete set I don't mind dealing with oarting out the rears. Lmk what u have looking to pay pal asap. |
01-13-2015, 08:47 PM | #2 | |
30
Rep 399
01-13-2015, 09:53 PM | #3 |
284
Rep 1,961
Calipers are the same for the fronts. M-Sport ones are just painted. Rotors are bigger.
Original Brakes on "high power" models (335i) Front rotor: 340mm brake rotor with 4 piston caliper Rear rotor: 330mm brake rotor with 1 piston caliper Original Brakes on "low power" models (320i/328i) Front rotor: 312mm brake rotor with 1 piston caliper Rear rotor: 300mm brake rotor with 1 piston caliper M-Sport Brake Option (2NH) (Blue “M” calipers) Front rotor: 370mm Brake Rotor with 4 pistons (for on "high power" models) Front rotor: 340mm Brake Caliper with 4 pistons (for "low power" models) Rear rotor: 345mm Brake Caliper with 2 pistons (on all models) M-Performance Brake Kit (Yellow, Orange or Red “M” calipers) For a "high power" car (all that have 4 piston front brake calipers as factory standard): Sizes are the same as M-Sport 2NH option but all rotors are dimpled and slotted For a "low power" car (all that have 1 piston front brake calipers as factory standard): 370mm front rotors, 345mm rear rotors - all dimpled and slotted |
02-08-2015, 12:18 PM | #5 |
I want to drive a Zamboni
1132
Rep 5,557
Drives: 13 E93 M3 18 F80 M3 16 K71
Since your car is an E90 335i this is the best option for the upgrade you can buy this kit for under $2K and it's a six pistons for the front and 2 on the rear.
http://www.getbmwparts.com/partlocat...catalogid=4462
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
02-12-2015, 12:05 PM | #6 | |
Rep 1,752
