E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Please help 2Rad not codable via NCS
Reply
      10-02-2014, 07:10 PM   #1
laurentProd
Drives: E93
Hi guys!
Need some help here please
I'm trying to code my second car (e87 from 2006)
I have upgraded my business CD HU to Professional HU + USB + BT built-in.
(no ULF / MULF)
Everything is working fine :
I have recoded the Kombi to get the old gong replaced by the new one coming from the speakers.
I have recoded the PDC so that I removed the double bips/gongs and I have the L / R differenciation.
BT is working fine / USB mp3 also...
BUT I need to code the HU to HIFI as the sound level is way to high!
The new HU is from 04/2014, my car is from 2006.
I have changed the VO $662 (business CD) to $663 (pro HU)
I can now list the car modules : 1rad was changed to 2rad.
(Shouldn't it be 2URAD instead???)
I tried to change the VO #0306 to #0311 but still get the 2rad.
FRM has changed to NFRM ...
When accessing the 2rad I still got "Wrong ECU coding index A_E65R: CODIERINDEX = 34h"
I tried to update the SP-DATEN to v50.2 but still no luck...
It must be something with 2rad vs 2urad no ????
To code Hifi I have to FA_WRITE in 2rad the VO $676 but how to do that without being able to read the module? FA_WRITE returns an error and fa is def. not saved.
Soooo guys.... helpppppppppppp please !
      10-02-2014, 07:13 PM   #2
laurentProd
Drives: E93
I guess 2Urad is for US only, EU spec cars have 2Rad ...
And SG_RESET reboot the HU but still no change ...
My HU and my car don't have MOST (no optical fiber connection)
my current VO :
E87_#0305&AFAT%0A35*UF51$1CA$205$249$255$2CT$321$4 11$431$441$442$450$473$4AG$507$520$521$530$540$548 $563$620$663$676$7RP$7RS$854$863$886-B046
I read somewhere that I need to update the VIN in the 2Rad using winkfp ???
      10-03-2014, 08:02 AM   #3
Dtype
Drives: BMW F30 320d
Change VIN on new HU.... WINKFP or TOOL32.
      10-03-2014, 09:01 AM   #4
laurentProd
Drives: E93
Ok! thx for the answer!
could you plz tell me how to do exactly?
I can read the UIF via INPA and get the Zusb
then what to do in winkfp?
Sorry but I never played with winkfp ...
      10-03-2014, 09:07 AM   #5
laurentProd
Drives: E93
ok found a thread
http://forums.bimmerforums.com/forum...-in-DSC-or-DME
I'll give it a try
      10-04-2014, 06:43 AM   #6
laurentProd
Drives: E93
so it does not work either.
I have successfully updated the vin using winkfp. It took 45 min and all went fine. So I can def. connect the HU ecu.
Using INPA I can now read the vin in the UIF
63 MASK/CCC OKAY 9343206 JT44368 04.10.2014
but I got also
62 MOSTGW OKAY 9343222 yyyyyyy 01.09.2013
I do not have mostgw right ????
the error using ncsexpert is :
bad coding ecu index : 34h
seems like I'm missing a file??? I'm using the latest SP-Daten 53.3 from 08.2014 ...
please any idea???
      10-04-2014, 11:25 AM   #7
laurentProd
Drives: E93
Success !!!
I have coded the vin in the mostgw and now I can access the 2rad module !!
yeppeeeeeeeeeeeeeeeeeeeeeee !!
Reply
e90post
