BMW 3-Series (E90 E92) Forum
09-25-2014, 08:22 AM | #2 | |
Rep 41
Then you must install the files in to the proper folders. Use this tool (bmw coding tool) http://goo.gl/2Nb35K to fill your coding folders (ncs expert, etc) Also a must have/read ncsdummy http://goo.gl/zDLjky Lado Last edited by herrlado; 09-25-2014 at 08:35 AM.. |
09-25-2014, 08:24 AM | #3 |
525
Rep 1,527
I would recommend you get BMW Coding Tool 2.5. It will allow you to edit the files NCS Expert uses to code your car. It will also allow you to import your Daten files into the correct folder.
You will need the "work" folder under the NCSEXPERT folder in order for it to work. That's where all you TRC and MAN files are generated for coding. |
09-25-2014, 08:36 AM | #4 | |
Rep 41
09-25-2014, 08:45 AM | #6 |
525
Rep 1,527
Pretty sure your programs are not set up to work on all BMW models up to 2014. The F series require esys (coding), enet cable (replaces KDCAN) and updated version of INPA.
I'm pretty sure the "work" folder will need to be under NCSEXPERT. Just keep that in mind if you run into problems. |
09-25-2014, 10:23 AM | #11 |
Rep 2,399
09-25-2014, 12:49 PM | #12 | |
525
Rep 1,527
Once you get more familiar with what exact modules you have, you can do more In depth troubleshooting by selecting the module instead of functional jobs. |
