09-15-2014, 06:40 PM | #1 |
Rep 786
Low tire pressure?
Anyone ever had an issue with a low tire pressure warning going off in the dash board??
I've had the tires checked at my local gas station and they said they were perfect. Figured I would ask before I go to BMW.
MG on CR M235i, mods to come...
(gone but not forgotten) 2011 e90 M Sport - M-Tech Carbon Diffuser, OEM Carbon Trunk Spoiler, 20% tint, black reflectors, black OEM grille, LUX white Angel Eyes. |
09-15-2014, 07:05 PM | #2 |
Rep 1,852
TPMS prompts you to reset tyre pressure in system if you have had any work/changes to your tyre. Unfortunately the prompt is the same sign as the tyre warning sign. Could this be issue?
09-15-2014, 07:08 PM | #3 |
Rep 6,934
Drives: 2018 M2 AW DCT
Reset the TPMS system and see if the problem goes away. You must drive the car a few miles before the reset works.
I had mine go off when the dealer washed my car. I reset it and it never went off again. |
09-15-2014, 08:17 PM | #4 |
Rep 427
I got the same issue - the tires are fine, but once in a while I would get a low tire warning. After resetting the TPMS all is well for another couple of weeks.
09-15-2014, 08:21 PM | #5 |
Rep 438
Yup mine went off. Went home, seemed ok. I did loose about 6-7 psi then filled, drove and blew the tire. I'd check the tires and their pressures closely
09-15-2014, 10:26 PM | #6 |
Rep 862
Drives: '19 M2 '21 X5
I think this is the reason the car comes with ftm in certain markets...
09-16-2014, 09:33 AM | #8 |
Rep 587
Drives: 2020 M2C
The TPMS sensor will go on with colder weather. I've also had them go off by having a tire sitting in a puddle, and parking on a hill. The easiest thing to do is reset it and if it doesn't come back on you know you don't have a problem.
09-16-2014, 09:58 AM | #9 |
Rep 786
So how do you reset it?
09-16-2014, 12:31 PM | #10 | |
Rep 786
09-16-2014, 05:08 PM | #12 |
Rep 1,852
