2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Are M Sport brakes worth it?
      08-30-2014, 05:15 AM   #1
moldcad
moldcad's Avatar
Poland
262
Drives: M235i
Well - in the perfect world I'd know the answer as I am a spirited driver, but with todays lowered BMW standards my question is this:
- what exactly is the difference between the regular brakes as available in 228i (or 220i and diesel models in EU), and the nice blue ones (standard in M235i or optional in the others)? Is it only the nice blue color of the calipers, or do we get a truly upgraded braking system with this option?
PS. In my F10, the regular brake calipers are rusting so I guess having them painted blue (or whatever) from the factory would have been nice, but of course the painting alone I can do myself in my future 2-series, and from the M-Sport brakes I would expect more for all these $$$
previous: 2003 E46 330i SMG
just sold: 2013 F10 528i xDrive
my AWD beater: 2015 Golf R mk7 DSG
my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD
      08-30-2014, 07:54 AM   #2
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
M Sport brakes: fixed calipers, four-piston front, two-piston rear, large brake discs. Made by Brembo.
The regular bmw brakes are floating calipers with 1 large piston.
Is it worth it..yes, its a bargain to upgrade thru options. In real world street driving, the msport brakes are alot smoother. On track, more resistant to fade. Another benefit is that the floating caliper has a sliding pin (to float the caliper) and if not lubricated correctly will make sqeak noise.
Some Info on Fix vs Floating Calipers (im just copy/paste from someone)
The more even the pressure on the pads, the smaller the risk of the pads chattering and the better control you have over the pads.
Most brakes today are floating caliper, single-piston designs, though a few use floating caliper dual piston designs.
On a floating caliper setup, the piston is on only one side of the caliper and the caliper itself slides slightly side to side on pins. Fixed caliper setups have pistons on both sides of the caliper and the caliper does not slide at all. Fixed caliper setups provide more even brake pad wear than floating calipers and also provide more consistent pressure between the two sides of the caliper because this setup does not rely on the caliper's sliding.
Fixed caliper designs, of course, require at least two pistons; one for each side.
Larger pads provide a greater swept area which means a greater area over which heat is generated. Because the total heat for a given stopping force is always the same, greater swept area means better heat dissipation and less brake fade. Having multiple pistons per side helps apply more consistent pressure over the entire surface of the pad which not only allows the larger pads, but also reduces chatter and flex, both of which generate additional heat as well as reducing overall brake feel.
So, while a one-time emergency stop will not show much difference between a single piston sliding caliper and a 6-piston fixed caliper, the multi-piston fixed-caliper design will be more resistant to fade over several hard stops in quick succession.
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      08-30-2014, 08:29 AM   #3
mike@tpc
Drives: white M235i
for street use, the only benefit is visual. For tracking, it would be a big worthwhile upgrade.
      08-30-2014, 09:05 AM   #4
Ian_Mark
United Kingdom
14
Drives: '14 228i MSport
2014 BMW 228i  [0.00]
2005 Subaru Sti  [0.00]
IMO very worth it . Coming from subaru sti ( still owned) saved me many times. In different weather conditions . For safety it's a must for me. Didn't hesitate when I added it to my 2014 build
      08-31-2014, 04:43 AM   #5
moldcad
moldcad's Avatar
Poland
262
Drives: M235i
Thanks guys - no more speculation, just hard facts:
2-pistons front
all fixed calipers
elegant looks and color
- these certainly make this option a no-brainer for me, should I ever configure any 2-series other than M235i (or M2, for that matter)
      08-31-2014, 11:09 AM   #6
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
It's actually 4 piston front. There are 2 pistons on each side of the caliper and 2 piston total on the rear, 1 on each side
      08-31-2014, 08:29 PM   #7
c1pher
Primo Generalissimo
c1pher's Avatar
Drives: All of them
How much sooner will the M Sport brakes need to be replaced compared to standard ones under normal driving?
      08-31-2014, 08:49 PM   #8
mike@tpc
Drives: white M235i
since there is more pad material, they should last a little longer
BM235iW97.00
      08-31-2014, 08:53 PM   #9
2msport
Drives: '14 228 MT
I would think they would last longer. Larger pads and discs, dissipate heat better and stay cooler. They are more powerful brakes therefore less wear for a given stop. Just a guess though..
      09-01-2014, 02:58 PM   #10
daisy16905
Drives: 2014 M235i
My feedback - M Sport brakes with much higher boiling point DOT 4 brake fluid = TRACK READY!!!!
M235i (Black) Auto, JB 4 (Stage 2 / Map 7 with EWG & FF wires) ER DP, resonator delete, running E35, BMW Performance LSD, Hankook Ventus R-S3's (255/35/18 & 235/40/18) ATE Super Blue Racing brake fluid, 35% tint, black grills!
      09-24-2014, 06:01 PM   #11
tbc417
Drives: 2018 M2
I'm assuming they wouldn't be covered for replacement rotate/pads under the 4 year warrantee...?
      10-12-2014, 01:11 AM   #12
BMW13x
BMW13x's Avatar
Drives: 1, 3, X3
The supposed M-Sport brakes on my M235 are a complete disappointment with less performance than standard BMW brakes on my 335i.
one of the selling points of the M235 was is comes standard with M-Sport brakes. However, I'm not sure what that really is. since the car is different than the 3 series, BMW most likely designed a total different brake system and called it M-Sport. they are no way a comparable brake system to Brembo.
Performance. The pedal travel is very mushy. there are several reviews stating the brakes are mushy. What is really disappointing is the Brake Fade when I step on the brakes hard. The car is very fast and brakes (stopping a fast car) are so important. When the car can't stop, it is scary.
my 335i normal brakes out performs the M235 hands down. the pedal pressure required is low compared to M235. I have even compared it to M3 brake testing that is superior to both.
if you are considering the M235, test the brakes and test them hard from at least 80 mph to 10 mph or so. you will be amazed at how poorly it slows.
      10-12-2014, 09:21 AM   #13
mike@tpc
Drives: white M235i
They are brembo brakes. better brake fluid and better pads are all they need if you want more performance out of them. They worked really great for me at the track until they got hot, but I was running the stock brake fluid
      10-12-2014, 10:17 AM   #14
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Break feel and brake performance is two different things, the msport (rebrand brembos) does have a soft feel but they perform well, the 335 floating caliper does have a faster bite feel but is not smooth
2006 325xi (Sold)
      10-12-2014, 06:02 PM   #15
david.orr
Australia
123
Drives: Cars
according to Chris Harris who was provided with all MP bits and pieces, the MP brakes are basically the same as stock but slotted and not worth the $$
      10-12-2014, 06:44 PM   #16
overcoil
Drives: M235i 6spd
Haven't driven the upgraded MP brakes, I think even small increments in braking performance have large benefits on the road. I do like the initial bite of slotted brakes. 235 really pulls above 80-mph and the standard brakes (Michelin PSS) can give you a scare when you really need to scrub off triple-digit speeds.
      10-13-2014, 12:44 AM   #17
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Get your brakes checked.
I have m135i f20 as my DD in the UK. Same m sport brakes as m235i. Had n54 3 series before this for 5 years.
Have tracked both and f2x m sport brakes are on par or better than the n54 335i brakes.
      10-13-2014, 04:30 AM   #18
overcoil
Drives: M235i 6spd
Pave Dew - I'm sure my brakes are fine at 2500 miles.
I do think the 235 is very fast and with those very high speeds any amount of brake improvement is something to consider.
      10-13-2014, 03:09 PM   #19
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Do the cheap stuff first then rather than mpbbk
Dot 4 fluid and steel hoses
      10-13-2014, 07:45 PM   #20
pikcachu
pikcachu's Avatar
1403
yes, they are the same brakes just painted red, orange or yellow with slight bigger rotor with slots and dimples
I suppose the pads are the same too..
      10-13-2014, 08:10 PM   #21
tbc417
Drives: 2018 M2
Can we get a confirmation on this, it's pretty rediculous if they are essentially the same brakes given that they cost a couple thousand.
      10-13-2014, 09:21 PM   #22
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Bigger better rotor and better pads
2006 325xi (Sold)
2addicts
