08-01-2014, 12:11 PM | #1 |
Rep 41
Spring and Coilover Options
I'm looking for more options for the M235i.. I'd imagine there are more companies that make suspension for this vehicle, I'm curious on what you guys are running.
These are the only ones I've run into from reputable companies:
I'm looking for coilovers specifically since I'm fairly particular on ride height, however, the V3's don't go low enough in the rear. Though I probably will go a few millimeters lower, I'd still like the option to be there, especially with coilovers. Edit: Recently heard that F30 suspension may work. Can anyone chime in and verify? Last edited by ll1l2l1l2lll; 08-29-2014 at 01:21 AM.. |
08-01-2014, 04:54 PM | #2 |
Rep 319
how low are you trying to go and what is wheel size? Lowest setting on KW V3 will be rubbing your wheels if you run a 19x9.5 or 19x9 with aggressive offsets.
08-01-2014, 06:12 PM | #3 | |
Rep 661
08-01-2014, 07:03 PM | #4 |
Rep 319
just fyi.. any of the spring drops out there will be higher than KW's max drop (I want to say ALL coilovers out there drop lower than springs but can't speak for everyone).
ps. OP, are you kevin lai's friend? haha.. i'm from rowland and your user id sounds familiar |
08-02-2014, 07:32 AM | #5 | ||
Rep 82
Dinan just introduced new springs -I have been very impressed with them in the past
08-02-2014, 07:36 AM | #6 |
***** noob
1370
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
08-03-2014, 05:53 AM | #7 | ||
Rep 41
Thanks! I'll definitely look into these, though I'll probably go with KW's coilovers over a set of springs. Quote:
08-03-2014, 04:19 PM | #8 |
Rep 4,528
Drives: M2 CS
Bilstein lists their PSS10 as a fit for the F22, 30-50mm drop
http://cart.bilsteinus.com/product/48-217170/416230/RWD |
08-04-2014, 11:10 AM | #9 | |
Rep 319
08-06-2014, 02:58 PM | #10 |
Rep 71
I'm looking to get the Dinan springs installed. Do most of you guys go to the BMW dealer for this? Dealer quoted me $1000 for install. A tuner shop in town quoted me a $300 flat-fee they charge for spring install. Do you get what you pay for in this case?
08-06-2014, 05:09 PM | #11 | |
Rep 5
Make sure to get the car aligned afterwards because all your angles will be off. |
08-06-2014, 05:42 PM | #12 |
Rep 319
Shops here in Los Angeles charge $175 - 250
08-14-2014, 10:02 AM | #14 |
Rep 62
Dinan lowers the rear more than the front. I think this would look much better than the H&R drop that leaves the back sitting up high. Wish there were some pics out already.
08-14-2014, 02:43 PM | #15 | |
Rep 4,518
I have H&R sport springs on mine. Love the level stance (see iPhone photo below), a drop of about 1"/axle. Ride is stiffer but not silly (important here in uk where roads aren't the smoothest) and it handles like it should from the factory! PD |
08-14-2014, 03:10 PM | #16 |
Rep 6,934
Drives: 2018 M2 AW DCT
Great looking car. To bad we can't get one.
08-14-2014, 03:52 PM | #17 |
Rep 4,518
Dan- Cheers. These have been available in Europe for last 2 years. Good cars but being challenged by offerings from Audi, VW and M-B. None of them have a straight 6 or RWD !!!! Pave.
08-21-2014, 10:42 PM | #18 |
General
2042
Rep 25,989
Spoke with a KW rep the other day and found out the F30 coils and F22 coils share the same part numbers. That being said, it's possible that other suspension alternatives that fit the F30 (CKS coils etc) will be a direct bolt-on for the F22.
All things considered, I'd assume spring rates would still differ with the F30 chassis vs F22
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
08-28-2014, 01:27 AM | #19 | |
Rep 41
08-28-2014, 02:51 AM | #20 |
Rep 4,518
Bilstein also do their b16 ride control coil overs.
Lichfield imports in UK have system fitted to their m235i and say lots of positives about it http://www.litchfieldimports.co.uk/BMW/M235i
Current '22 X3M LCI.. |
08-28-2014, 02:21 PM | #21 |
General
2042
Rep 25,989
Theoretically, I'd assume so. Didn't verify though
08-28-2014, 05:42 PM | #22 |
Rep 2,364
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
Im extremely happy with my H&R sport springs. about an inch drop front and rear. Adaptive suspension still perfectly functional and the ride is almost exactly like stock. Plus IMO it looks badass.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
