BMW 3-Series (E90 E92) Forum
Help with coding ma retrofitings e90 EU
07-26-2014, 07:02 AM | #1 |
Rep 15
Hello!
Last time i've retrofitted my car with: -Logic7 top hifi -pdc front -electric roller sun blind for rear window -electric seat with memory -TCU bluetooth -TV unit hybrid -independent park heating(webasto) -electric folding mirrors with elctro chrom -antitheft alarm OEM I think i've not forgotten any thing everythink have installed properly, only think left to do is coding. Some thing like electric seats and folding mirrors i've coded succesfully i guess, but i'bve got problem with other, that's why i'm writting here to ask for your help. Now i'm trying to code L7, i've added VO $677 to CAS and FRM and change some registry in CAPPL ecu, after coded i've gain in Idrive l7 logo witg sorrund settings but still don't have voice from any speaker Ive made self test by inpa and only 6 speakers works;/ what am i doing wrong? I will be very gratefully for every priceless help Best Regards |
07-26-2014, 02:48 PM | #3 |
Rep 15
Each hardware were installed properly, i'm 100% sure, i only need coding adwises. Anyway i've already coded succesfully l7 and it plays briliant, i've just coded 3 ecus by empty .MAN file and everything were set ok.
Another thing: i want to code is 1.antitheft alarm OEM --$303- is it correct VO?? 2.electric roller sun blind for rear window $414 Is it correct VO ? refer to components above i'm getting in NCS this type of issue :"Following feature is invalid for FA......." what does it mean?? 3.TCU bluetooth For TCU when i try to connect with mulf ecu i'll get issue like below |
07-27-2014, 02:22 PM | #4 |
Forced induction for high altitude.
Rep 67
Bit o/t but where did you get the front PDC from? I've only found kits for the rear.
Current: '14 BMW 750XI M-Sport
Current: '16 Tesla Model X Past: '06 BMW M6 | '03 Ferrari 360 | '02 Ferrari 360 | '08 Audi S3 | '06 Porsche Cayenne Turbo | '09 335i X-Drive Coupe | '08 Range Rover Supercharged | '09 Porsche Cayenne | '11 X5M |
07-27-2014, 03:30 PM | #5 | |
Rep 15
Still have problem with coded: TCU--get coapi erorr 2041 oem alarm system- get coapi erorr 2020 when prompt of connecting with DWAS module https://drive.google.com/file/d/0Bzm...it?usp=sharing -Electric roller blind for rear window- i still have a problem with adding $414 or other accordingly FA code Can anyone help me? |
07-28-2014, 11:35 AM | #7 | |
Rep 15
Pdc Works. -refer to alarm oem i still have problem with permission to DWAS module;/i'm getting a same error coapi 2020;/ any idea how to get in?? -refer to electric roller for rear window i've browsed NCEXPER/DATEN/E89AT.000 and properly VO for it is $415 i've aded it and recode every module by empty .MAN file but wiothout any result;/;/ still doesn't work I found in CAPPL this option like below https://drive.google.com/file/d/0Bzm...it?usp=sharing i've tried to change it to aktiv but it always restores to originally value;/;/ i don't know why, maybe i'm doing something wrong when i execute job sg-codieren. |
07-28-2014, 12:45 PM | #8 |
Kind of a big deal
301
Rep 1,674
Drives: an 1M not often enough
Hi Melonidas, that's an impressive list of retrofits!
- OEM alarm VO code for E89 is $302 (K302 also works, this would allow the dealers to recognize that it's a retrofit). - Try the above first, if still no contact with DWAS, then check the power connection (faulty, broken or terminal 15 iso terminal 30) and after that check the full length SW/RT cable IRS_SINE connection between DWAI and DWAS. Good Luck! |
07-28-2014, 01:43 PM | #9 | |
Rep 2,776
time criteria changed via FA editing, remove one, add another |
07-28-2014, 03:43 PM | #10 | ||
Rep 15
Tell me, Does signal come into siren ( via SW/RT) in case of theft a car? refer to Quote:
Is there possibility to get wrong made loop in most? I've already installed amp logic 7( it works properly) and every time i put key into ignition i get message that SOS call failure in yellow color, so i guess that loop is well configured. Refer to roller, do i have to buy new one?? How can i recognize properly JBE which will activate circuit for roller sun blind. Is it necesarry? is it hardware issue or software?? I Last edited by melonidas; 07-28-2014 at 03:55 PM.. Reason: clear mistakes |
07-29-2014, 04:02 AM | #11 |
Rep 2,776
if you get sos call failure then you need to check whole most ring
as to roller sunblind - you can get jbe from the car you've got sunblind, or order new
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
07-29-2014, 04:30 AM | #13 |
Rep 328
What is your manufacture date?
You have installed a tcu with bluetooth? (first generation) Do you have a us or europe spec car? Btw do you also have pics of installing the 7 logic system? Last edited by Teq; 07-29-2014 at 04:36 AM.. |
07-29-2014, 05:53 AM | #14 | |||
Rep 15
1.I can't accept number to phone in dial number menu in idrive, i can only choose contacts from my mobile and start calling from mobile 2. Telephone button on my wheel doesn't work- do i have to add bmw assist VO to CAS and FRM? 3. Is there possibility to browse contacts from my mobile via IDRIVE? 4. when my mobile is connected to my car it shows me different vin number of my car(TCU was bought used and from different car- IS this situation may occurs some problem with bluetooth? 5. Does SOS failure system may be conected with eject box situated inside of the central armrest? If yes i've to check pins, mybe i've made some mistakes there Refer to roller- i can't get jbe from car i bought roller, i won't buy new as well, i want to by use, but need more info how recognize properly JBE, i mean numbers or sequences of codes on the box there must some information how to get compatible module;/. Quote:
My Car is EU version left hand TCU that i've installed in my car you can see below https://drive.google.com/file/d/0Bzm...it?usp=sharing Unfortunately i didn't take a pics of installing L7 system, but if you need information or help just ask |
07-29-2014, 08:46 AM | #15 | ||||
Rep 328
That bluetooth is available in the settings menu is just coding. Even if you haven't got bluetooth you can still enable it.
If you also installed the external speaker on the drivers side you should also add bmw assist. First make sure everything works than you can remove it if you want to. Quote:
If that is your bluetooth problem I don't think so. You don't need to change your production date. You can leave it as it is. Quote:
In the future I would like to upgrade from stock to L7. Did you bought the wiring from the dealer? Last edited by Teq; 07-29-2014 at 09:22 AM.. |
07-29-2014, 12:30 PM | #17 | |
Rep 2,776
07-29-2014, 05:14 PM | #18 | ||||
Rep 15
You don't need to change your production date. You can leave it as it is. How do you know that? Are you sure 100%? Because i remember that i bought EU version Quote:
http://www.e90post.com/forums/showthread.php?t=918608 to instal ncs exper and INPA. last time i've update sp-daten to v51.3 Refer to alarm system, i solve problem, i don't know how but i put into slot F19 broken fuse, after replacing it i had permission to dwas module, i recode it and alarm will work properly |
07-30-2014, 05:41 AM | #19 |
Rep 328
Send me the vin (last 7 numbers) of the car which the tcu was removed from.
I'm not 100% sure but all my customers have an everest tcu in their trunk. My latest car which I bought also has an everest ecu. What does ista-d says when you do a quick test of the car? Does the tcu answer and is green? Use Winkfp to change the vin. |
07-31-2014, 05:54 PM | #20 | |
Rep 15
Do i need ISTA -D to do quick test? TCU works as fairly normal bluetooth, i mean i can connect my mobile to it and phone to everyone, but other features of TCU weren't configured;/ Could you tell me how to do that to change VIN, i am new in WINKFP i need some support, i don't want to broke down something refer to SOS failure system it turn out that i had wrong conection beetwen eject bo in central armrest and TCU unit below is my diagram, could anyone help me with this? |
07-31-2014, 08:47 PM | #21 |
264
Rep 749
question - why do you want to retrofit TCU in Poland? I dont think this service is available unless something has changed recently.
As to TCU update, do you have Icom or coding cable only? if you have coding cable only dont update software in TCU or MULF, unless you are asking for trouble. |
