06-29-2014, 01:45 PM | #1 |
Lucky13
212
Rep 1,762
TPC Warning Today
Got a low pressure warning while driving and the display showed all 4 wheels in yellow. When I got home I checked the pressure with the tires warm and the front two were 36.5 and the back two were 42.5. Recommended is 32/38 cold so I am near suggested cold. Anyone know why this might happen?
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
06-29-2014, 02:57 PM | #3 |
Rep 1,040
This happen to me when I reduced the tire pressures from the over inflated numbers from delivery. If the tire pressure changes from the stored value by a certain percent/value it triggers the warning light.
Set the tire pressures all the way around to the correct tire pressure and reset the TPM system and you will be good. |
06-29-2014, 04:48 PM | #4 |
***** noob
1370
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Mine is at 35 - 39 cold
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
06-29-2014, 04:54 PM | #5 |
Lucky13
212
Rep 1,762
Mine cold were 34/40, so about 2.5 higher when warm. I got it reset in idrive just couldn't figure out why it came on. I know if one side is 3 less than the other it registers as low or at least that's how my E93 was but the fronts matched and the backs matched. I did adjust them so but that was two weeks ago.
06-29-2014, 05:49 PM | #6 |
Rep 389
When the tires are cold..just go for a drive and perform a reset. The car will remember the current psi and next time it will warn you when it get too low under that.
