12-10-2023, 12:06 PM | #155 | |
Rep 2,670
https://www.amazon.com/gp/product/B082V1245P I used the medium-sized pins, those slot in fairly easily but are snug enough to not come loose. |
Needsdecaf6739.50 |
12-10-2023, 12:17 PM | #156 | |
Rep 2,052
MirrorTap®, MT-4015, 15" Radar... https://www.amazon.com/dp/B00OQQWHLO...p_mob_ap_share U can push cable back into the mirror if too much slack but 10 could probably work too depending on how u position yours. |
Needsdecaf6739.50 Bryantbjb54.50 |
12-10-2023, 01:07 PM | #157 |
Rep 1,301
Drives: 2024 BMW M4 Base
Needsdecaf6739.50 |
12-18-2023, 07:56 AM | #159 |
Rep 6,757
Was able to install the 15" using the second to largest pins this weekend. My buddy came over and tested it with his radar detector as Santa is delivering my new V1 Gen 2 soon which required sending the old one in for "upgrade" credit.
Thanks Berzerker for the note about using the needle nosed pliers to pull the plug up and out. I probably would have been fumbling around with it forever if I hadn't. I had contemplated doing this the morning after I picked up the car for the long drive home and decided not do deal with it. Turns out I easily could have. Thanks! |
12-22-2023, 11:46 PM | #160 |
Rep 212
Drives: 2024 M3 Comp xDrive
02-19-2024, 07:28 PM | #161 |
Rep 247
I'm having a very hard time separating the two trim pieces. They don't wanna separate. I have all the tech options on the car. None of the videos on YouTube have this specific mirror type.
02-19-2024, 09:50 PM | #162 |
Rep 2,052
02-20-2024, 12:16 AM | #163 | |
Rep 2,670
Edit: Actually looking at your pictures, seems like you got it most of the way. You just need to pry tool them apart in more areas where they meet, at some point they should just fall right off. |
02-26-2024, 04:10 PM | #164 |
Rep 13
Just did this in ~30 minutes on my 2024 M4 MT. No issues.
Hope the photos help.
2024 BMW M3 MT | Frozen Pure Grey II Metallic
12
03-21-2024, 04:57 AM | #166 |
Enthusiast
507
Rep 318
Drives: 2025 M4 Comp xDrive
For those who are having blown fuses what rider did you plug in first.
Did you plug the red in first and then plug the black in next? For those who did it correct is there a correct order so I don’t blow a fuse
2025 M4 Competition xDrive
IG: Automaz_ |
03-21-2024, 08:14 AM | #167 | |
Rep 2,670
Just insert the wires as shown a couple posts above and it'll work fine. |
Needsdecaf6739.50 automaz_507.00 |
04-28-2024, 11:00 PM | #170 |
Enthusiast
507
Rep 318
So I just picked up my 2025 LCI m4
I have the drive recorder or whatever Do I just pry this open? I think there’s a small camera almost touching the windshield
IG: Automaz_ |
04-29-2024, 11:55 AM | #171 | |
Enthusiast
507
Rep 318
Did you pull apart the side pieces and then pull the middle one? Or middle first then the side plastic pieces ? Mine looks like this
IG: Automaz_ |
04-29-2024, 12:26 PM | #172 |
Rep 2,052
04-30-2024, 05:37 PM | #174 |
Enthusiast
507
Rep 318
Haha it’s a 2025 that I just picked up from the dealership 2 days ago 😂😂😂 everything is oem and stock
IG: Automaz_ |
04-30-2024, 05:38 PM | #175 |
Enthusiast
507
Rep 318
Alright guys so I just went ahead and took it apart
It was quite simple because it’s just two pieces Also my radar powers off after 5 mins of shutting the engine I timed it haha 2025 m4 mirror tap can confirm everything works as previous years
IG: Automaz_ |
Needsdecaf6739.50 |
