09-10-2022, 04:13 PM | #1 |
Rep 92
Surprised no one else posted about this, but my car automatically rolls up the windows and tightens the seatbelt during hard braking on track. I called BMW about this and they tell me it's the active protection system that kicks in when the car thinks you are about to crash, and there isn't a way to turn it off.
And yes, I had all safety systems was fully off, car in full track mode. Had to resort to pulling the fuses for the windows before every track day. Here is a pic for reference, it's under the passenger side dash. If anyone finds a different solution please update this thread. |
09-10-2022, 06:45 PM | #2 | |
Rep 924
2023 F90 M5
09-26-2022, 11:31 AM | #3 |
Rep 242
It's weird - my G80C didn't do any of that this weekend @ COTA. I had many situations where I was threshold braking from well over 100 MPH with other cars in front of me and the windows didn't move & seatbelts didn't tighten up.
For what it's worth, my seatbelts don't "hug" like other BMWs when starting to drive - did something get removed in the chip shortage? |
09-26-2022, 08:43 PM | #4 | |
Rep 92
09-26-2022, 08:59 PM | #5 | ||
Rep 242
I know it's a bunch of random stats but ya never know why it's different… |
09-27-2022, 04:11 PM | #6 |
Rep 99
Same here, my car has never once tightened the seatbelts and/or rolled up the windows. 3 track days and 3 autocross days so far and have been in plenty of 'pre crash' scenarios but still nothing yet. My car also does not have the seatbelt tightening function when you enter the car. I'm in a 2022 6MT.
09-28-2022, 03:10 PM | #8 | |
Rep 92
Mine does not, I wonder that's what disables it. Mine also has Active Driving Assistance, which I suspected could be what causes this. |
10-24-2022, 08:41 AM | #11 |
Rep 110
Just got back from a track day and confirming that I haven't experienced any window closing issues. Was braking hard from 132mph down to like 40. My car does have the m drivers package, the one that enables the 10 way traction control and the drift analyzer, not the one that raises the speed limit. If that even matters? Anyways just wanted to share my experience.
10-24-2022, 05:47 PM | #12 |
Beware of cheap bait!
709
Rep 715
I have found that a brake slam will cause the car to go into crash mitigation but if you load the pedal up it won't do it.
Don't shock the brakes and you'll be fine |
10-24-2022, 06:16 PM | #13 |
Rep 92
Not sure if you saw this was posted in the track thread, but not slamming the brakes on track isn't really a choice I have haha
10-24-2022, 06:21 PM | #14 |
709
Rep 715
I'm not talking about that. There is an aggressive method and a less so. Linear and firm application of the brakes on entry to keep weight transfer smooth. Helped me be faster and the windows don't go up. I used to do the slam and go and when I worked on modulation and application I picked up time in every corner. Smooth is usually faster except when it isn't.
10-24-2022, 09:15 PM | #15 | |
Rep 924
2023 F90 M5
04-09-2023, 01:11 PM | #16 |
Rep 95
Hello - I also have this issue on my G20, and as others have mentioned, I've had to change my braking technique to get to max brake pressure needed for a corner more smoothly rather than immediate to avoid triggering the precrash systems. I'm actually working with my shop and his coder in an attempt to disable it. No ETA yet, but I'll share our results whenever we get a chance to try it.
P.S. I google "bmw active protection" or "bmw precrash" every now and then to see if anyone has solved it lol. |
04-09-2023, 06:16 PM | #17 |
Rep 14,115
Drives: G82 M4C X-Drive
This happened again this past track day. I late braked, still threshold, into a chicane with a plastic barrier, and I think the front sensors saw the barrier, and thought it was an emergency situation. This only happened 2 other times, once when I was following another car and he broke early into a corner and I had to compensate, and another when a spun. This needs to be disabled in "TRACK MODE" or tracks need to let us start running windows up. It totally defeats the purpose of running windows down for extraction in case of an accident if the car automatically rolls them up in an accident. It makes no sense.
04-11-2023, 12:38 PM | #20 |
Rep 172
I've had it happen in my CCA skills day as well as my auto-x. Happened every time before I realized I wasn't in M Mode (I assumed hitting M2 automatically put it in M Mode). Once I did that, they rolled up less but still on occassion.
04-11-2023, 02:38 PM | #21 |
Rep 223
Yeah, the fact that they don't have a way to turn this off is pretty dumb. Happened to me multiples times last week at Buttonwillow. What's the point of having a track mode if it still thinks you're crashing when you push hard?
04-14-2023, 01:35 PM | #22 |
Rep 211
When you do PCD during the braking exercise they mention this feature for safety but they tell you it will only happen if you really stand on the pedal with max pressure. They almost try and make it a game to see who can hit the pedal the hardest by who makes their windows roll up.
