02-18-2024, 05:29 PM | #111 |
Learning to drive again
714
Rep 322
Drives: M3CS
Really appreciate the details m4ml . I consider myself a noob as well, so all of this helps. My first track day is next month, I'll give some feedback on my PS4S tires, it may help someone.
Thank you!
Cheers,
BoB |
m4ml1834.00 |
02-19-2024, 12:11 PM | #112 | |
Rep 633
GenXG87179.00 |
02-19-2024, 02:33 PM | #113 |
714
Rep 322
Drives: M3CS
Given your driving ability, I have an idea, but do not want to put unnecessary pressure
Cheers,
BoB |
02-19-2024, 03:55 PM | #114 |
Rep 127
Drives: 2023 M2 & 2018 M2
Awesome! Good luck.
2023 G87 ///M2 6MT - Ohlins R&T, Vorshlag Camber Plates, Fall-Line Rear Toe Arms, APEX VS-5RS, Conti Extreme Contact Force, JB4, IRL single mid-pipe
2018 F87 ///M2 DCT - MPE, BM3 stg1, MAD Intake, xHP stg2, M4GTS Diff/Steering, Euro MDM, Ferodo 3.12, APEX VS-5RS, Potenza RE-71RS, Cobra Nogaro IG: Follow ME: genXg87 |
lutfy253.50 |
02-21-2024, 10:47 AM | #115 | |
Rep 633
The car will be driven sensibly, flyer laps, and back in as tires/brakes are OEM. F80 Reference: Summit Point Main 1:21.842 poor-sha M3 6MT (Pirelli DH, DS1.11, Dinan) 1:23.84 JMac 274 M3 (AD08R, RS29, Dinan) 1:26.04 Wangspeed M2 6MT (RE71, PFC08, Ohlins) |
02-21-2024, 04:01 PM | #116 | |
714
Rep 322
Drives: M3CS
Given all is new with you and me, I am shooting for a comfortable 1:28 for the first event on PS4S. If I get to 1:27, I will surprised. I think you will hit 1:25 rather easily, may be low 26s if you are overly cautious. It takes me a while to adapt to new cars, I don't think you will have that problem.
Cheers,
BoB |
02-25-2024, 04:59 PM | #117 |
Rep 168
Drives: G80 M3 GTP 6MT
I really need to update my journal thread LOL. But nevertheless here is a lap at big willow. A LOT of time on the table, I just need to stop being a b*tch and my 4-6 is a work in progress.
Big Willow - CW - 1.33.17 - BrendanZ0402 - G80 M3 Base - RWD - Manual - (RE71RS, Endless ME 20, Full SPL, MCS 2 way remote) https://youtu.be/SiEW-x6163c?si=yv2Ek0zUxm25812h |
Hit_Apex2370.50 |
03-03-2024, 10:12 AM | #118 | |
Rep 633
Car pulls on C8. My closest competitor who is 10th off is in a current model GT4. Goal is 1:20s will share official SCCA time later. Brakes and tires are holding up extremely well (stock). Lutfy |
BackOnBlack714.00 |
03-03-2024, 10:47 AM | #119 | |
714
Rep 322
Drives: M3CS
I knew I was being conservative with my time suggestions, but I really wasn't expecting 22s Great driving, Lutfy, superb! I hope you'll give us more details. How did the tires behave? Starting and hot temps, etc. Cannot wait for the vid I am still going to stay very conservative with my first event, just getting to know the car, tires, the field, etc. I will be more than happy with 28s haha.
Cheers,
BoB |
03-03-2024, 12:58 PM | #120 | |
Rep 633
Time on RaceHero under SCCA, will share details/writeup. Brakes hold up very well for a stock car. Weighed in 3950lbs with me in it. Lutfy |
BackOnBlack714.00 |
03-04-2024, 09:20 AM | #121 |
714
Rep 322
Drives: M3CS
lutfy not only you improved your time by 2 secs on Sunday, also beat the GT4 by more than 0.8 seconds
Cheers,
BoB Last edited by BackOnBlack; 03-04-2024 at 02:26 PM.. |
03-04-2024, 11:35 AM | #122 | |
Rep 633
G87 6 speed. OEM. Weight: 3968 full tank of petrol with driver (215 lbs helmet on). Summit Point Main: 1:20.6 Few takeaways: 1) Tire pressure best suited was 34-35 hot. 2) Driver setting: a) Power: Efficient (anything more than that, I felt the pedal gets too sensitive when you want to manage the rear). Sport Plus is good for the street b) Steering: Comfort. Anything more than that, its too sensitive. It takes time for car to take a set on stock springs. c) Brakes: Comfort (I have no idea what Sport does). d) Suspension: Sport Plus setting. I have not tried Sport but Sport Plus worked very well. BMWs are generally less rebounded but this setting worked very well on this somewhat smooth track. e) Traction and DSC Off and the bar (0-10) set at 5. Take a set (it is a big heavy car) on the front and post apex, do not hesitate to get on the throttle. It shoots out like a BAT out of hell (the rear diff is magic). Car had to be positioned and setup for a one lap flyer. First lap warmup then full send with enough gap between other cars (no traffic). OEM brakes were fairly good with minor hint of fade full boogie after 20 mins in Instructor group. They would rattle in the paddock (hot) with some smoke (my E90 brakes caught fire from tire booger once). Tires are great and falls off slightly after 3-4 hard runs but still manageable. Pad wear was not bad. 50% f/r two days running in multiple sessions. You "have" to drive this car at the limit of cohesion otherwise very easy to overdrive and burn the outside tire. Keep on the edge, no more, no less. Have pics of car on scale, tires etc. during impound. Lutfy PS: Video chasing C8 Z06 and GT3 coming soon. Last edited by lutfy; 03-04-2024 at 11:41 AM.. |
BackOnBlack714.00 |
03-04-2024, 02:24 PM | #123 |
714
Rep 322
Drives: M3CS
lutfy This is truly amazing, great driving!!!
Thank you for the tips and configuration information as well
Cheers,
BoB |
03-04-2024, 05:12 PM | #124 |
Rep 633
03-04-2024, 05:38 PM | #125 |
714
Rep 322
Drives: M3CS
I can watch this vid many times I can relate to the corners and speeds, so it is much fun.
You were really hustling through turns 3, 9 and 10 for sure. You also needed to feather the throttle and correct steering in T2, it appears, which is generally unusual for many cars, but these engines have so much torques, I felt the same during trackcross and I had to take very unusually wide arc. I hope I can drive with your confidence in a couple of weeks.
Cheers,
BoB |
03-05-2024, 07:24 AM | #126 | |
Rep 633
I was really impressed. Also dont push too hard in 6-9 as tires take a beating and heat up. I left a little bit of speed there and few tenths would wear the tire up a lot. I dont know what stock front camber is on these cars but unlike previous gen M cars, it doesnt understeer much at entry so take a set and bang, use the rear grip and M dynamic to power out. I tried to drive it in the rain with all traction everything off but realized in the rain setting it to 8/10 was much quicker. Kinda like ABS, use that system to your advantage. Love this vehicle. Super comfortable on the street, when you are done, remove the sticker, put your helmet/bag back, play some 80s music, wear your cap and drive back in comfort. For the money, I could not find a better $65K car (yours is CS and possibly a dream to drive!!). You always had the best engineered hardware At VIR, I think this is a 2:02-03 car as is. Stock it fits into NASA TT4, I'll try to get the dyno done for compliance. Lutfy |
03-05-2024, 08:48 AM | #127 |
714
Rep 322
Drives: M3CS
In all of my previous cars, T1/2 has been the same, turn in, smash the throttle. With the M3, during trackcross, I had to wait almost until nearly past T2 to be at 100% throttle. Although, I had the wrong tire pressure, and it was cold and slippery, with these cars we have to take the fundamentals of driving more seriously, like being gentle with the throttle
I had an interesting experience this past weekend as well. I was at the Performance Center for 1-day M School. We drove M2, 4 and 5. All of the cars' tire temps went up to 145-150F and to 49-50 psi with starting pressures at 30-32. The cars still performed well with a little drop in braking and cornering performance. I say this because maybe we don't need to worry too much about tire performance through T6/9, and just let it be. Although, after I drove the M2 on the timed autox course, the front left had thread separation and they had to change the tires before the next exercise I also felt that the M2's front end bite was similar or same to that of the M5 for some reason. They gave so much confidence during turn-in, especially while trailing the brakes. However, at corner exits, they both struggled and required more steering input. I cannot compare it to the M4 as we used those only on the skidpads. The rat-race on skidpad with the M4 was a hoot
Cheers,
BoB |
lutfy253.50 |
03-31-2024, 10:13 PM | #128 |
Rep 728
Chuckwalla - CW
2:04.685 - m4ml - M4C - AWD - (Yokohama AD09 on Apex VS-5RS, iSweep 2000, KWv4, -2.25 F/-2.0 R camber, Fall-Line Monoballs, Carbahn Stage 2 ECU Tune) - video Best lap was my last lap of the day. Going into the day, I was hoping that I could manage a sub 2:00, but that's not happening with my current abilities. I think the car is capable of it in the right hands though. On to Buttonwillow next weekend (with some new rear suspension work and more aggressive alignment)!
Susp: Turner Skid Plate/Strut Brace, KW v4, F-L Monoball, MS: Camber Plates, Spacers, SPL Rear Cosmetic: MPerf: Splitter, Side Vents, Sill Plates, Door Projectors; IND CF Roundels/Float Center Caps, Vorsteiner Grill, Xpel: Stealth PPF, Fusion Plus Ceramic, XR Plus 5/20/70 Last edited by m4ml; 04-01-2024 at 12:23 PM.. |
BackOnBlack714.00 jmg18710.50 |
04-04-2024, 04:48 PM | #129 | |
Rep 14,115
Drives: G82 M4C X-Drive
04-04-2024, 08:09 PM | #130 | |
Rep 728
No squealing or brake noise at all on the streets. For Chuckwalla on the other hand... They actually performed really well. No fading, good solid feel when warm. But, after a couple of sessions, they were very slick cold. And then there's the wear...
04-09-2024, 02:43 AM | #131 |
Rep 728
Buttonwillow - #1CW with Star Mazda
02:09.4 - m4ml - M4C - AWD - (Yokohama AD09 on Apex VS-5RS, Pagid RSL29, KWv4, -3.2 camber 0" toe F : -2.5 camber 1/4" toe R, Fall-Line Monoballs, SPL Rear Camber Arms - Rear Toe Links - Rear Traction Links, Carbahn Stage 2 ECU Tune) - video Swapped out the iSweep 2000s for Pagid RSL29s. Upgraded the rear suspension to full SPL. Setup the alignment to be more aggressive and track oriented. The AD09s had 15 heat cycles on them going into day 2 at Buttonwillow, and just didn't have the same grip. Otherwise, a fantastic tire!
Susp: Turner Skid Plate/Strut Brace, KW v4, F-L Monoball, MS: Camber Plates, Spacers, SPL Rear Cosmetic: MPerf: Splitter, Side Vents, Sill Plates, Door Projectors; IND CF Roundels/Float Center Caps, Vorsteiner Grill, Xpel: Stealth PPF, Fusion Plus Ceramic, XR Plus 5/20/70 Last edited by m4ml; 04-09-2024 at 03:15 AM.. |
jmg18710.50 |
04-09-2024, 11:57 PM | #132 |
Rep 149
Roebling Road Raceway -
1:20.068- GT3M2 - G87 - ZF8 Speed- (295 square cr-s) - RBF600 - BMC Filters This is 4 laps between 1:20.028 and 1:20.463 G87 M2 RRR 1:20 x4 |
