      03-12-2022, 06:39 PM   #1
beachBmmr
beachBmmr's Avatar
Drives: 2023 F90 M5 SG/AB
Just installed new front brake ducting by speed engineering in Germany.
Tracking Tuesday with Cobalt friction pads recommended by Boomer 2019
Install took about 2 hours including my pad swap. 3d printed ducting mates to the intake scoop, and converts to 2.5" round to handle the silicone ducting. Then attached to their hun plate made from what seems like 040 sheet aluminum. Inlet hits right at the hub.
They claim 70c rotor temp improvement.
2023 F90 M5
Retired - 2021 G82, 2019 440xi, 2020 X7, 2019 X5, 2013 F10, 2010 F10
jabrax10.50
jmg18710.50
M4Tejas788.00
      03-12-2022, 06:48 PM   #2
moproblems
Beware of cheap bait!
moproblems's Avatar
709
Looks fantastic. You did ziptie the tubing to the lower control arm correct?
beachBmmr1447.00
      03-12-2022, 06:53 PM   #3
beachBmmr
beachBmmr's Avatar
No I used one large zip tie against the frame behind the plastic fender liner. I was concerned about having enough movement for lock to lock.
2023 F90 M5
      03-12-2022, 06:56 PM   #4
moproblems
moproblems's Avatar
709
I would do 2 on the lower wishbone to not allow it to drape when turning the wheel inboard. Really have to secure those bad boys or you will have a really bad day.
beachBmmr1447.00
      03-12-2022, 07:14 PM   #5
beachBmmr
beachBmmr's Avatar
Ill check it when underneath. It doesn't sag but rather retracts against the inside of the fender. But I see your point.
2023 F90 M5
      03-12-2022, 11:40 PM   #6
jmg
jmg's Avatar
18711
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.85]
2018 F80 M3 CS  [9.87]
2019 i3 BEV  [0.00]
This is fantastic! Link to buy? I can't find it on their site.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
IG: Raging_G82
g80z673.00
      03-13-2022, 07:27 AM   #7
beachBmmr
beachBmmr's Avatar
https://www.speedengineering.de/prod...2-komplettset/
The 3d printed duct is a little brittle. I broke a tab and had to plastic weld it back together, but otherwise ok.
2023 F90 M5
jmg18710.50
      03-13-2022, 10:46 AM   #8
jmg
jmg's Avatar
18711
2019 i3 BEV  [0.00]
Thanks! How long did it take to get stateside?
IG: Raging_G82
      03-13-2022, 12:15 PM   #9
beachBmmr
beachBmmr's Avatar
2 weeks
2023 F90 M5
      03-13-2022, 03:55 PM   #10
beachBmmr
beachBmmr's Avatar
Added a heavy cable tie on the control arm.
2023 F90 M5
_E90S65_736.00
M4Tejas788.00
      03-16-2022, 10:44 AM   #11
beachBmmr
beachBmmr's Avatar
These worked really well yesterday on track. No issues, and brakes performed well. No Smoking and no brake smell, even in the hot pits right off hot laps.
2023 F90 M5
ATX_G80841.00
ATX_M3185.50
jmg18710.50
Allerum315.50
      11-01-2022, 01:53 PM   #12
forumlurker
forumlurker's Avatar
780
Drives: almost every day
is there a mesh inside the duct? would be concerned about debris flying into the brake ducts.
      11-01-2022, 09:59 PM   #13
dirtyfreebooter
dirtyfreebooter's Avatar
Drives: Vespa
no it's just a 3d printed plastic cone that connects to the OEM duct in the front bumper
M4Tejas788.00
      11-01-2022, 10:51 PM   #14
forumlurker
780
Would this mod make sense on a daily? I might attend a track day 1-3 a year.
      11-02-2022, 09:41 AM   #15
dirtyfreebooter
Drives: Vespa
not sure. only put 2700 miles on mine since i picked it up last january. one could easily put a mesh liner at the end of the cone and then put the hose and clamp over the mesh to hold
or in place. but unclear if that would defeat the purpose, if the mesh was too restrictive. tracking 1-3 times per year i would just try the removing the stock covers and see if you are having brake heat issues.
where i track in the summer it's > 90F and i have had multiple heat issues, engine and brakes, so now i just limit it to 6-8 laps per session on top of the using this brake duct system
M4Tejas788.00
      11-02-2022, 12:51 PM   #16
forumlurker
780
Heat issues even with ducts, dang. Are you also running their rear brake cooling?
      11-02-2022, 02:44 PM   #17
dirtyfreebooter
Drives: Vespa
yea, in general, a car this heavy with this much power, pushing cup2s to max, plus i am amateur driver, few times it was 98F - 103F mid-day, so the track was 140F+ .. colorado bluebird day (not a cloud in the sky), sun melting external GPS and gopros suction cupped to windshield, etc.
but generally staying under 8 laps + 1 cool down lap per session things are fine. all in all tho, never experience brake fade.
i don't have any cooling on rear, nor do i have any real significant rear wear. not sure what i am going different, but ppl seem to always have excessive rear wear.
ppl also experiencing driving assistance systems coming on, etc. i have been on busy track, gone off track, never experience windows up, safety stuff, i have all the driving assistance packages, etc.
ATX_M3185.50
M4Tejas788.00
      11-02-2022, 03:32 PM   #18
DRLane
DRLane's Avatar
Drives: E92 M3
2008 m3  [6.63]
Your car doesn't care as much about you.
Not a Doctor, those are just my initials.
      11-02-2022, 07:56 PM   #19
dirtyfreebooter
Drives: Vespa
haha true, cars are such a-holes most of the time!
      11-03-2022, 11:23 PM   #20
TrackM4x
Drives: BMW M4 Comp xDrive
Dang I wonder how this will work with xDrive
      12-28-2022, 12:47 PM   #21
forumlurker
780
saw these up on their site
https://www.apmotorsport.co.uk/produ...ng-duct-plates
      01-05-2023, 09:52 PM   #22
M4Tejas
M4Tejas's Avatar
788
Drives: 22 G82 M4xDrive
Talking
It would be nice to see this one installed
2022 M4 Comp xDrive Aventurin Red Metallic
https://wieninger.de/ Seit 1666
