      04-16-2022, 01:30 PM   #89
jmg
jmg's Avatar
18711
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.85]
2018 F80 M3 CS  [9.87]
2019 i3 BEV  [0.00]
Originally Posted by docprechop View Post
Do aftermarket adjustable strut tops void the warranty?
Only for the suspension and the wire than attaches to the top to control the EDC. The wire is only $40.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
IG: Raging_G82
      04-16-2022, 08:38 PM   #90
jmg
jmg's Avatar
18711
2019 i3 BEV  [0.00]
Good news RE71R fans! The RE71RS is finally coming to the US!
https://grassrootsmotorsports.com/ne...t9LUcskvTEpHl0
IG: Raging_G82
tom @ eas8224.00
ATX_M3185.50
pinky_chi172.00
      04-19-2022, 07:06 PM   #91
mzcp
Drives: BMW M
My next tires
      04-19-2022, 08:44 PM   #92
beachBmmr
beachBmmr's Avatar
Drives: 2023 F90 M5 SG/AB
Just got my 2022 M3 Comp xDrive and would like to do some basic prep for my first track day.
1. What is the max camber one can get from stock configuration?
2. How do the stock brake pads and fluid hold up?
3. Any other adjustments or prep suggested?
Thanks
The stock front camber is not adjustable, but on a lowered car most people have 1.9 - 2.0 degrees, at a guess it's likely more like 1.5 - 1.6 on a non lowered car.
People who have bought adjustable strut tops (a few companies sell them now) are getting up to 3.4 degrees!
Most people seem to be doing fine with stock pads apart from the rears overheating. Read up some more on it, but it seems that when the rears get too hot they actually put the car into limp mode!
No idea if better fluid helps, but most people who hit the track run SRF or something similar before they head out.
There are quite a few track pad options now which solve the issue above and you'll get far more track days out of proper pads - again lots on the subject in this section of the forum.
Watch your tyre pressures would be the main tip otherwise. If you are running any of the road tyres you'll probably want to run these at around 36psi hot, but they will pump up to well over 40 after a run or two.
Drop pressure as soon as you come off the track, after a few times doing this you should be right. If its cold and you are off the track for an hour or more just watch they don't drop too low between sessions.
Great summary.
2023 F90 M5
Retired - 2021 G82, 2019 440xi, 2020 X7, 2019 X5, 2013 F10, 2010 F10
      04-19-2022, 08:45 PM   #93
beachBmmr
beachBmmr's Avatar
My next tires
I dont see rear sizes..only 285/35/20
2023 F90 M5
      04-19-2022, 08:51 PM   #94
jmg
jmg's Avatar
18711
2019 i3 BEV  [0.00]
Unfortunately, it's still a challenge finding them in the 30's.
Same with their previous RE71R.
Looks like going square or downsizing is the still the only way to open up track tire options.
IG: Raging_G82
      04-20-2022, 01:37 AM   #95
mzcp
Drives: BMW M
I went 19". That's another story
      04-20-2022, 06:26 AM   #96
beachBmmr
beachBmmr's Avatar
I just dont see the economy of doing another set of forged track wheels to get a square setup of 275s. Would think about if we could get 305 square to fit.
2023 F90 M5
      04-20-2022, 02:43 PM   #97
beachBmmr
beachBmmr's Avatar
Heres me trying to drive fast, and blowing a bunch of corner entries and brake zones all to still eek out a PR by 6 10ths...Talk about working harder not smarter...Theres at least another 3-5 seconds to pick up here with cleaner cornering..
2023 F90 M5
jmg18710.50
element561091.00
      04-20-2022, 08:39 PM   #98
Ximian
Ximian's Avatar
Drives: E92 M3
2011 BMW M3  [0.00]
2021 BMW M3  [0.00]
Smoother entries and unrolling is going to make the car's weight easier to manage. For the heavy braking zones, brake a bit earlier but with less pressure for the whole duration. You're braking pretty late and heavily which makes the transition pretty difficult to deal with.
There's also a few "throw away" corners at the track where you want to sacrifice your exit speed to have a more manageable entry into the next corner and faster exit. Are you working with any coaches? There's quite a few in TX that can help with these things.
beachBmmr1447.00
jmg18710.50
      04-21-2022, 06:36 AM   #99
beachBmmr
beachBmmr's Avatar
This is good advice. I do work with a coach and went a few weeks ago for the day with one. I transitioned off of stiff threshold braking to an earlier slower brake style over the last time out.
This video was from December.
Heres my last coaching session from March on the short course.
2023 F90 M5
Ximian1919.00
jmg18710.50
      04-21-2022, 11:31 AM   #100
Kinglagos
Drives: 2021 M4 G82
My 2nd track day with this car on a very questionable track surface with lots of rain, lots of puddles/standing water, just kept trying to keep a safe line, time was super slow but was fun and educating...
2021 M4 G82 Sao Paolo Yellow
2015 420i F36 Estoril Blue
      04-22-2022, 09:19 AM   #101
dirtyfreebooter
dirtyfreebooter's Avatar
Drives: Vespa
just ordered some track prep stuff.
cobalt brake pads
speed engineering brake duct cooling
millway street camber plates
cup2s on 963Ms
once the camber plates arrive, scheduling install of camber plates, track alignment, and brake fluid flush. first track day sometime in june for me, as scheduling and tires seem like i could be waiting for front tires until mid-may at the earliest.
      04-24-2022, 03:07 AM   #102
BulkBen
Drives: G80 M3, Mini x 2, Lotus x 4
cobalt brake pads
cup2s on 963Ms
Nice setup there.
Do you plan to do a day or two on the stock setup, as delivered from the factory?
My G80 hasn't arrived yet, but I think getting a base line in a completely stock car would be worth it to see what kind of difference the mods make.
      04-24-2022, 03:38 PM   #103
dirtyfreebooter
Drives: Vespa
Nice setup there.
no, given that is not a daily driven car for me and what i see here, its clear the front wear is going to be terrible on these stock. also friend with m4 gts, had the same issues until he got camber plates.
      05-01-2022, 06:56 PM   #104
beachBmmr
beachBmmr's Avatar
Fuck me…but I fixed it
2023 F90 M5
      05-01-2022, 07:08 PM   #105
dirtyfreebooter
Drives: Vespa
what happened?
      05-01-2022, 07:10 PM   #106
beachBmmr
beachBmmr's Avatar
what happened?
Stripped the adjustment screw and galled the female side. Had to retap it. Tightened them without enough load on the suspension so the upper strut wasn't seated all the way
2023 F90 M5
      05-01-2022, 08:40 PM   #107
ATX_G80
ATX_G80's Avatar
841
Drives: 2021 G80 M3 Comp
Anyone using a harness without a bar or cage?
      05-02-2022, 01:33 PM   #108
pinky_chi
Drives: G80 6mt
Saw this on Instagram, looks like he's anchored into the child seat mounts.
      05-02-2022, 02:46 PM   #109
Ximian
Ximian's Avatar
Drives: E92 M3
2011 BMW M3  [0.00]
2021 BMW M3  [0.00]
NEVER EVER USE THE BABY SEAT MOUNTS AS RESTRAINTS FOR ANYTHING THAN A BABY SEAT
The ISOFIX/Latch mounts do not have the capacity to restrain an adult in an accident.
Did you notice that as kids get bigger, their car seats switch from the latches to using seat belts? It's the weight.
There is no solution yet on the market that was tested to meet the safety standards when using the regular seat belt connections to attach a harness for the G80/82 and the bucket seats.
      05-03-2022, 07:30 PM   #110
beachBmmr
beachBmmr's Avatar
Was out again today after getting everything sorted. Really nice mid 60s and overcast after 6 inches of rain washed the track clean.
New tires were great after cycling them on the road (lots of 0-100-20 runs to get heat) and letting them sit for a day.
Spun hard at least around twice in one direction and halfway back the other, track was empty and kept it on the tarmac. But holy shit…thats what I get for chasing lap times late in the day and tired.
Cobalts are money in the bank.
Track gas was inly $6 a gallon
2023 F90 M5
jmg18710.50
element561091.00
PLF693767.50
ATX_M3185.50
