03-02-2022, 02:01 PM | #23 |
Rep 924
Heres my last time on track in December, finally uploaded laptimer footage. I like to use the g-meter to see if my corners are optimal or not (theyre not) by seeing if i hold max lateral Gs all the way through the corner, and not wobble back and forth.
This was first time after the camber plate install..fucked this lap up bad but still faster by 1 second. I think there is easily 2-3 seconds to get by not blowing 3 corner entries and holding a bit more speed through the higher speed sweepers.
2023 F90 M5
03-02-2022, 02:04 PM | #24 | |
Rep 14,115
Drives: G82 M4C X-Drive
I read about your problems running a smaller overall diameter wheel/tire combo in the rear. Has that been resolved?
03-02-2022, 04:09 PM | #25 | |||
Beware of cheap bait!
709
Rep 715
If that's still not what you want find a press in or pull in wheel stud from ARP or similar. Drill the hubs and do a permanent conversion. |
03-03-2022, 07:02 AM | #26 | ||
Rep 924
2023 F90 M5
mzcp2690.50 |
03-03-2022, 09:48 AM | #27 |
Rep 83
Not yet resolved but I am convinced the car can not deal with the different size dia for the tires. Still hoping to talk with someone from BMW about this soon.
03-03-2022, 09:58 AM | #28 | |
Rep 14,115
285/35/19 = 26.85in 295/30/20 = 26.97in Difference = 0.12/26.91 = 0.45% 285/35/19 = 26.85 305/30/20 = 27.20 Difference = 0.35/27.03 = 1.2% - NO GOOD 295/35/19 = 27.13 305/30/20 = 27.20 Difference = 0.07/27.16 = 0.26%
RUNSOK237.00 |
03-03-2022, 01:01 PM | #29 |
Rep 83
Is this 1% rule written somewhere. I haven't exactly read the manual but just wondering what I say when BMW, inevitably, tells me the same thing.
03-03-2022, 01:09 PM | #30 |
Rep 83
Also, if your 'good to go' sizes are real that means a lot more tire choices and I can probably salvage at least 2 of my wheels (and tires!).
Also, is it a 1% difference front to back or 1% difference from Stock? Not meaning even a little to hijack the thread here, sorry about that. |
03-03-2022, 01:51 PM | #31 | |
Rep 14,115
No worries, that's what the thread is for!
03-03-2022, 05:41 PM | #32 | |
1919
Rep 1,889
Drives: E92 M3
I haven't seen these numbers from BMW officially published anywhere though, but there a are a few examples of people running tires outside these limits and getting vibrations so sounds about right;
jmg18710.50 |
03-04-2022, 01:50 PM | #34 |
Rep 14,115
Awaiting my Millway Plates as well! Race uniball version was backordered. KW-HAS, EBC Bluestuff, and spacers are all waiting on the plates to arrive from Europe.
03-04-2022, 01:58 PM | #35 | |
709
Rep 715
jmg18710.50 |
03-04-2022, 06:19 PM | #36 |
///M Powered for Life
11495
Rep 10,331
Fortunately Girodisc is working on a rotor conversion, which I strongly suggest to serious trackers. You can do Ti shims as well.
For very serious use, the BimmerWorld-Alcon kit is being developed for the G8X already! |
jmg18710.50 |
03-04-2022, 06:51 PM | #37 |
Rep 14,115
I discovered at last weeks Time Attack that the G8X doors are aluminum!!! My magnetic door numbers will no longer work, so I ordered re-usable vinyl. My past experience with reusable vinyl hasn't been great. If there is any peeling whatsoever, dirt gets in there and they are no longer reusable.
The question is, I don't daily my car, but I do like driving occasionally, but I mostly drive it to and from the track or canyon runs etc. How ricey is it to just get a vinyl number and keep it on all the time?
03-04-2022, 09:26 PM | #38 |
709
Rep 715
I believe EBC has revealed their floating rotor kit as well... I don't know if you can buy them yet though.
SYT_Shadow11494.50 |
03-04-2022, 10:18 PM | #39 | |
Rep 14,115
https://ebcbrakes.com/racing/coming-...-m3-m4-models/
03-11-2022, 04:48 PM | #40 |
Rep 14,115
My plates are stuck in some port somewhere. I was expecting it today, but now I have to push my suspension and brake work another week for these plates.
Did you have any luck receiving these?
03-11-2022, 04:54 PM | #41 |
709
Rep 715
Did you get "something something delay at port" on your package? Based on my research it was based on the shipper not having transport to cologne to hop on the plane to be imported. Mine were like that until Monday this week, then they came in on Wednesday. I did pay the extra for expedited shipping.
jmg18710.50 |
03-12-2022, 11:29 AM | #42 |
Track Rat
1760
Rep 403
A source for real honest to God track pads (and damn good ones) has now become available.
https://g80.bimmerpost.com/forums/sh....php?t=1905305
03-12-2022, 02:14 PM | #43 |
709
Rep 715
For those of you going with with millways, an interesting thing I have done to drop some costs.
The factory hardware is about 4 bucks a pop and at the factory torque spec must be replaced every time they are removed. With the millways requiring you loosen the bolts mounting the strut to the car every time you adjust camber, every adjustment would be about 32 dollars. However, from many places online you can get M8x40 10.9 bolts for under a dollar a bolt. Will require a hardened washer as well, the factory hardware uses one integral to the bolt and makes the effective length between 38-39mm. Plus, dumping etorx in favor of a 13mm hex is always very appreciated. |
jmg18710.50 |
03-12-2022, 11:50 PM | #44 |
Rep 14,115
I signed up for a track day tomorrow at the last second. I'm still on factory brakes and fluid. I guess there will be lots of cool down laps, but it should be fun to see how a completely stock G8X will hold up!
destoyan521.50 kgelfen3602217.00 |
