      12-29-2021, 08:30 PM   #1
ggelpi
ggelpi's Avatar
Puerto Rico
66
Drives: BMW M4 G82 Black Sapphire
Drag Strip Tires
I was wondering if any of you has taken your g8x to the drag strip and what tires and sizes are using for better time sheets. Currently using Nankangs ar1 305/30/20 not bad but could be better.
      12-30-2021, 08:43 AM   #2
MannyM5
MannyM5's Avatar
197
Drives: 2016 BMW M2, 2001 Honda S2000
Those ar1's are a road racing/track day tire with stiff sidewalls. Not really designed for drag racing. If you are more focused on drag racing you should check out nitto's drag radials.
The nt555rII's come in a variety of sizes that would work.
https://www.nittotire.com/competitio...g-radial-tire/
forza19763399.00
ggelpi66.00
RUNSOK237.00
      12-30-2021, 08:58 AM   #3
ggelpi
ggelpi's Avatar
Puerto Rico
66
The nt555II's come in a variety of sizes that would work.
Thanks, I will check them out!
      12-31-2021, 06:54 PM   #4
Okhan19
Jamaica
26
Drives: 328I 2015 ATM rktune downpipe
Hey@ggelpi did the 305/30/20 fit on the stock rims without issue? No rubbing etc?
      01-03-2022, 06:54 PM   #5
ggelpi
ggelpi's Avatar
Puerto Rico
66
I had to take out the 15mm spacers, without spacers the fit perfectly!
      01-04-2022, 08:18 PM   #6
Okhan19
Jamaica
26
Thanks
      01-05-2022, 02:36 PM   #7
corbs09
Drives: 09 335i
Like others have said, this is a sticky road tire. You'll want a softer sidewall for drag. Check out Mickey Thompson ET street S/S or Nitto drag radials.
      01-05-2022, 02:41 PM   #8
ggelpi
ggelpi's Avatar
Puerto Rico
66
I already checked but those tires are rarely on 295 or 305 for 20" inches wheels
      01-05-2022, 05:31 PM   #9
forza1976
forza1976's Avatar
2022 BMW M3X  [10.00]
https://www.jegs.com/i/Mickey-Thomps.../3402/10002/-1
https://www.summitracing.com/parts/mtt-3402
just sayin'
      01-05-2022, 05:41 PM   #10
ggelpi
ggelpi's Avatar
Puerto Rico
66
just sayin'
35 is too tall they will probably rubb a lot
      01-05-2022, 05:42 PM   #11
forza1976
forza1976's Avatar
Ah, probably so.
      01-09-2022, 09:22 PM   #12
moproblems
Beware of cheap bait!
moproblems's Avatar
709
What you will be looking for will be similar to 18158 from Hoosier. 18 inch 28 inches tall 10 inches wide. You are going to have to go down in diameter from 20's.
      01-10-2022, 12:42 AM   #13
Soylent
Soylent's Avatar
964
Drives: 2021 M4C
The nitto drag radials come in 285/35/19. You could run these on the stock 19" wheels that are used on the front. The overall height/diameter would be the same as the michelin's on the stock 20" wheels but you get a slightly taller side wall. I may give these a try.
ggelpi66.00
      01-10-2022, 01:22 AM   #14
GGG333
m
GGG333's Avatar
Drives: M
And these are the 826M?
I'm shocked 305's fit as on the 666's it's 295 max on the rears.
      01-10-2022, 05:09 PM   #15
ram9cc
Drives: -
Also getting a sized down rim and bigger sidewall and running some lower pressures will likely give you better grip
      01-14-2022, 11:54 AM   #16
moproblems
moproblems's Avatar
709
So I ordered 2 of these, dirt cheap worth it https://momo.com/en-us/momo-rf-serie...ara-black.html
Going to run a 20mm spacer with a set of m/t street s/s 285/35 19 just for this season. Will get me into rmrw.
      01-19-2022, 06:50 PM   #17
moproblems
moproblems's Avatar
709
Don't even need a 20mm spacer 12 works just fine. Barrel clearance is close but it'll be okay. Went with those tires as I got a good deal, now for the first passes.
ChrisM41627.50
      01-20-2022, 10:22 AM   #18
Soylent
Soylent's Avatar
964
Drives: 2021 M4C
Let's see a pic.
GixY2K517.00
      01-20-2022, 10:53 AM   #19
corbs09
Drives: 09 335i
How did you fit those wheels? the hub bore is smaller than the hub on the g80
      01-20-2022, 04:55 PM   #20
moproblems
moproblems's Avatar
709
Stock CB is 66.56.
      01-20-2022, 04:56 PM   #21
moproblems
moproblems's Avatar
709
Originally Posted by Soylent View Post
Let's see a pic.
Waiting for TPMS sensors to arrive and I will mount and balance them. Probably Monday or Tuesday.
      01-21-2022, 09:57 AM   #22
corbs09
Drives: 09 335i
Stock CB is 66.56.
Ah google is misleading. I went ahead and got some too thanks for the deal lol
