      07-07-2021, 11:49 AM   #23
fl1by
Drives: G80, Raptor, STI and C8
Originally Posted by pikcachu View Post
BMW Ultimate Care+
$700
Purchase this BMW Ultimate Care upgrade to add: *Replacement of specific wear-and-tear items such as brake pads, wiper blades and manual transmission clutch (for model year 2017 vehicles and newer).
Absolutely!!!! cheaper than a set of pads....
      03-26-2022, 02:16 AM   #24
jmg
jmg's Avatar
18711
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.85]
2018 F80 M3 CS  [9.87]
2019 i3 BEV  [0.00]
BUMP this thread. Any more info on running square, especially on an X-Drive to free up tire options? I can only run the MPS4S for so long before I get a new more track oriented set.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
IG: Raging_G82
      03-26-2022, 12:28 PM   #25
ATX_G80
ATX_G80's Avatar
841
Drives: 2021 G80 M3 Comp
I am currently on the fence between running squared 18s with a 285/40s or 19s with 285/35s. Either will work great and getting a set of front 824m's x2 looks to be about the same as Titan wheels or the Apex VS-5RS that will be released soon in a 19x10 squared.
Either option gives a us a great selection of some real track tires.
ATX_M3185.50
jmg18710.50
      03-28-2022, 11:36 AM   #26
jmg
jmg's Avatar
18711
2019 i3 BEV  [0.00]
What's the offset for the factory 19/20 setup?
IG: Raging_G82
      03-28-2022, 06:15 PM   #27
BIGW0RM
You got my money?
BIGW0RM's Avatar
Drives: Ice Cream Truck
2022 BMW M3  [9.50]
I believe it's ET 20 on the 826M wheel. 19x9.5 and 20x10.5
jmg18710.50
      03-28-2022, 09:11 PM   #28
Hendo741
Chief Petty Officer
Hendo741's Avatar
645
Drives: 22 M4CX / 22 X3MC
I am so trying to find a square set up for track/autox. Anyone know if yhe front will fit a 295/35 19 or 295/30 20? Would love to be able to fit the Yokohama A052s at all 4 corners in that size.
      07-10-2022, 06:45 PM   #29
ATX_M3
ATX_M3's Avatar
186
Drives: Current, G80 Comp - IOMG, Form
I just ordered a set of Apex VS5-RS square 19x10 et12 and Goodyear SCR3 285/35-19 - anyone else running a similar setup? Any issues with rubbing in the front?
      07-10-2022, 08:56 PM   #30
TrackM4x
Drives: BMW M4 Comp xDrive
Vivid Racing forged and the upcoming Apex forged wheels you can run the 19 or 20 inch front wheels as square. 285/35/19 or 285/30/20. You might get some rub up front when turning in reverse, but very easy fix with a heat gun and clips to roll and trim the fender liner pieces that are rubbing.
After having my xDrive on track twice, it's clear this car does not need more rear tire, it needs more front. I am looking to go square for my next set, performance wise and so I can rotate save some money on tires.
jmg18710.50
      03-11-2023, 09:33 AM   #31
Next Phase
Next Phase's Avatar
41
Drives: 2019 M5
Will running a square set up cause any issues with the Xdrive since it won't be staggered?
      03-11-2023, 10:38 AM   #32
forcefed
forcefed's Avatar
Drives: .
What size wheels you have is irrelevant as long as the height of the tire is the same.
      05-31-2023, 09:34 AM   #33
EatThatLunchBaby
EatThatLunchBaby's Avatar
Drives: ‘23 M3 Comp xDrive
Any new options here that anyone is liking? As I’m getting more and more addicted to tracking this thing, I’m thinking a dedicated set of track wheels would be worth it. Are there decent lightweight options that don’t break the bank? Not sure where to begin with track wheels and which brands hold up well to the abuse. Do most of you run squared? Or should I look at 19/18 staggered? Any help here would be appreciated
      05-31-2023, 02:32 PM   #34
arulm3cx
arulm3cx's Avatar
Drives: 2023 BMW M3 Comp Xdrive
I ran Square 285/35/19 GYSC3R and now running 265/35/19 F on 10" wheels and 305/30/19 R on 11" wheels GYSC3R. Just experimenting 285 in F with 305 in R seems to be the combination but not possible with xdrive. 265 on 10" wheels front end grip is not up to the point. Next gonna experiment 275/35/19 and 305/30/19. trying to keep the diameter close to 1%. Some one in FB ran Falken 660 275 and 295 and said xdrive worked flawlessly at track. Someone need to break down what is the tolerance %
somer966.00
      05-31-2023, 03:08 PM   #35
PLF69
PLF69's Avatar
3768
Drives: 2023 M3
My 275-35/19 set of BF Rival S 1.5 are pretty much done, maybe still one or two sessions in them.
I am trying to source Nankang CR-S in 295-30/19 to run square on my 19x10 wheels. I know it's at the limit of the rims for these tires but I still want to try it out. The beauty of this setup is cross rotation when you have asymmetric tires, makes tire wear a breeze to manage for track duty.
Will get back with feeback
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp
Daily: 2023 X5 45e
Daily/Family: 2021 Atlas Cross Sport 3.6
      07-03-2023, 07:25 AM   #36
arulm3cx
arulm3cx's Avatar
Any feedback on 295/30 CR-S on 19x10 wheels ?
      07-03-2023, 09:02 AM   #37
PLF69
PLF69's Avatar
3768
Drives: 2023 M3
CRS got backordered when I was ready so I got Continental Extrême Force and I really like how they perform, they are very consistent and durable but are probably a bit slower than CRS.
Daily: 2023 X5 45e
      07-03-2023, 01:43 PM   #38
D_SheerDrivingPleasure
D_SheerDrivingPleasure's Avatar
Drives: F80
In case it helps, my F80 street setup uses a 315/30-18 on the rear (11 inch wheel). They run small. I bought them last year so they are v1. Assuming v2 is sized the same you should be ok.
They are very very grippy tires but are only good for a handful of hero laps. Fwiw, Phil's Tire Service, describes the v2 compound as designed for time trial and autoX applications.
Nankang should do a better job differentiating this tires. It used to be called the CR1, then it's CRS and now it's the CRS v2 but they still seem to be making the V1 so why not call it something different?
      07-04-2023, 03:54 PM   #39
arulm3cx
arulm3cx's Avatar
Excellent Thank you 🙏🏽
Family '21 Honda Passport EX-L AWD
Sold '23 M3 C Xdrive
Sold '18 Audi RS3 - stage 2
www.gowithaci.com
      07-12-2023, 09:00 AM   #40
R44 Performance
R44 Performance's Avatar
United Kingdom
1791
Drives: Part of the process%E2%80%A6
Yellow Stuff by EBC are a great option for track and fast road use. We have seen and heard great results for a hybrid road/track user.
Spacers we normally recommend 12mm at the front and 15mm at the rear.
Any one that was looking to get a set let me know.
      07-12-2023, 09:18 AM   #41
PLF69
PLF69's Avatar
3768
Drives: 2023 M3
If you don't run more than 6-7/10 pace maybe and even then, we are many who went trough sets of EBC blue pretty quick and these are even more track focused than the Yellow.
Daily: 2023 X5 45e
      07-31-2023, 11:04 AM   #42
Polo08816
Drives: 2014 335i M Sport
That seems like it would partially defeat the purpose of a square set up which is to be able to rotate tires all around.
https://support.apexraceparts.com/hc...-Fitment-Guide
Apex Race Part's fitment guide doesn't mention whether this would be detrimental to the drivetrain.
      02-05-2024, 06:01 AM   #43
apz
Drives: BMW m3
Any update please?
I intend on tracking in April and looking for a 19” square setup. People who are running 19 , are there rubbing issues and more importantly , how does x-drive handle a square setup?
      02-19-2024, 03:39 PM   #44
ember.m4
ember.m4's Avatar
Drives: G82 M4 Competition xDrive
How did your ECFs handle the weight of the car? What hot pressures did you run? I’ve heard they have pretty soft sidewalls (even softer than Michelins).
Also what offsets are you running in your 19x10? Any spacers? Front rubbing?
There aren’t many good options at 295, so I’m also considering doing a square ECF setup, but likely on 19x10.5s instead.
