09-14-2021, 10:14 AM | #1 |
Rep 10,888
IND | Fall-Line Motorsports G8X M3 / M4 Front Monoball Conversion
MADE IN THE USA. Fall Line’s monoball spherical bearing conversion kit transforms the front steering and suspension feel of the M3/M4. The factory rubber bushing is very large, and is prone to substantial deflection under load, as the car is put through its paces. Deflection of the bushing can create unwanted geometry change, steering wobble under braking, and even hysteresis of the thrust arm. The bearing’s housing is precision machined from aluminum, to create a rigid part that allows for the M3/M4’s thrust arm to move smoothly through its range of suspension travel. The improvement in steering and suspension feel is immediate and truly enhances the personality of the new G8x. Product Details:
The Fall-Line Motorsports G8X M3 / M4 Front Monoball Conversion may be viewed at the following link to our online store: https://ind-distribution.com/product...all-conversion Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
06-07-2022, 10:19 AM | #3 |
Rep 10,888
12-04-2022, 11:55 AM | #4 |
Rep 655
do these require a press to remove the old brushing? and install the new one?
Limegrntaln13538.00 Digitalfujjjrel186.00 |
12-05-2022, 09:06 AM | #5 |
Rep 202
12-05-2022, 10:50 AM | #6 |
Rep 655
videos like this ->
for F8x which uses basically the same arm, seem like you need a press to remove the stock one and even to insert the new monoball... i think if i go this route i will just buy new arms (they don't have brushing in) that way its easy to return to stock if its not working out. and maybe find a shop that will press them in for me if need be. seems like these are the arms, but i am not 100% sure |
01-18-2023, 01:37 AM | #7 |
Rep 941
I wonder if there are any plans on selling these pre installed in control arms?
Limegrntaln13538.00 |
01-18-2023, 02:04 AM | #8 |
Rep 6,998
This
YT: G Dubyou |
01-23-2023, 09:26 AM | #10 |
Rep 10,888
Not at the present moment.
05-08-2023, 01:44 PM | #12 |
Rep 283
I believe these are not sealed. You can see the Dinan ones have a sealed rubber boot in my pics below.
05-08-2023, 02:56 PM | #14 |
#Driver
374
Rep 419
I wonder what the concern is with debris getting in there?
2016 Focus RS - ende | 2017 718 Cayman - ende | 2007 911 C4S - ende | 2017 Macan - ende | 2015 Macan Turbo - ende
2023 M3xdrive | 2020 Macan insta: gtsdaddy |
05-08-2023, 04:55 PM | #15 |
Rep 283
Race cars don’t have the rubber boots because they don’t have to deal with the same longevity concerns Street cars have. The rubber boots/seal ensures longevity and minimizes the maintainence of the mono balls.
05-08-2023, 11:14 PM | #16 |
Rep 10,888
We do not have this product with dust boots currently. FLM has not incorporated them into their design.
