BMW 3-Series (E90 E92) Forum
Remove powered seats without power
11-11-2016, 11:12 PM | #1 |
Rep 35
I'm trying to remove a pair of front seats from a wrecked e90. I can unscrew the front bolts but can move the seat forward to get the rear bolts. Tried everything to provide power to the car but nothing seems to work. Any idea on how to get the seats out?
11-12-2016, 10:56 AM | #2 |
Rep 354
if it's a crashed car, the positive wire have a detonator on it, and i guess it got.. well.. detonated in the accident
in the trunk you need to provide power to the terminal after that wire.
135i N55 / KW V3 / MHD Flash / Tons of grip mods / CP-E charge pipe / CP-E 7" FMIC
11-14-2016, 10:41 AM | #4 |
Rep 354
not far
just follow the wire that connects to the battery back to the body you will find a double connector for the + wire, just connect to it your external battery i hope this image helps
11-15-2016, 10:03 AM | #6 |
Rep 354
you dont need to connect directly to the batt-
you can use any ground you like with external battery, this connection bypasses the blown + cable terminal. this is how i powered my car after an accident and a totally dead battery also i need to note, that after the battery dies the onboard CIC goes into transportation mode which limits car and stereo functions. this can be disabled via INPA
03-06-2024, 06:03 PM | #8 |
Rep 3,077
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.25]
2009 BMW 328i Touri ... [8.00] 2013 BMW X5 35i [7.80] 2011 BMW 528i [8.70] 2006 Mazda3 [5.50] |
lime Do you know what pins those go to? I like the idea of jumping them, but connecting at the pin in the connector would keep the connector intact.
03-09-2024, 03:06 AM | #9 |
Great Teacher
1138
Rep 1,319
Drives: 06 e91 325ix
Without watching it, I’m going to guess you used a 12-14v drill battery and a couple of jumper wires?
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
