      10-07-2021, 02:49 PM   #1
jpsimon
Team Zissou
jpsimon's Avatar
Drives: 2022 AWD M3 Comp - SMB
OEM tires on slightly wider rear wheel?
I may be getting aftermarket wheels that I'd like to swap the OEM tires on to (whatever tires end up coming with my 826m wheels). The only thing is the new rear wheels will be 20x11 instead of 20x10.5
Can I safely run the same 285/30 rear tires on the 11" wide wheels?
      10-07-2021, 04:56 PM   #2
HorsePower
Drives: '22 G80 6-speed
Tire manufacturers publish official specs for the range of rim widths approved for each tire and size. I think I recall the width for the OEM rear Michelins is 9.5-10.5 range. You could check for whatever tires are on your car (and that will be the "official" safe answer).
      10-07-2021, 05:27 PM   #3
beachBmmr
beachBmmr's Avatar
Drives: 2023 F90 M5 SG/AB
Michelins will fit on 11 in width
2023 F90 M5
Retired - 2021 G82, 2019 440xi, 2020 X7, 2019 X5, 2013 F10, 2010 F10
      10-07-2021, 06:10 PM   #4
HorsePower
That looks like it's for 275/35s. For some reason, the oem bmw star Michelin 285/30 shows 9.5-10.5 rim widths. Which is very odd, because the oem bmw star front - which is 10mm narrower - shows 9-11 rim width. Pasted below from Michelin's website:
285/30ZR20/XL (99Y) ★ BSW
Buy now
MSPN
66946
Mileage Warranty
30,000
Section Width on Measuring Rim Width
11.00" on 10.00"
Overall Diameter
26.82
Max Load, Single (LB @ PSI)
1709 @ 50
Sidewall
Black Sidewall
Revs/MI
777
Tire Weight
27.43
Rim Width Range (Min/Max)
9.50-10.50
Tread Depth (in 32nds)
9.5
275/35ZR19/XL (100Y) ★ BSW
Buy now
MSPN
21325
Mileage Warranty
30,000
10.00" on 9.50"
Overall Diameter
26.62
1764 @ 50
Sidewall
Black Sidewall
Revs/MI
783
Tire Weight
25.73
9.00-11.00
9.5
