10-01-2021, 05:34 PM | #1 |
Rep 10,869
IND | Fall-Line Motorsports G8X M3 / M4 Tow Straps
MADE IN THE USA. The Fall Line Motorsports tow strap is the highest quality strap available for BMW M cars. Fall Line combines 5 axis CNC machined stainless steel hardware with a CNC sewn strap for an extremely robust piece that will withstand the rigors of repeated use. The high strength webbing is initially available in Black, Red, and Black with Tri-Color. Custom colors can be ordered for an additional charge. Each strap is designed to thread perfectly into the M3/M4’s bumper reinforcement for an easy install. NOTE: Slotted Covers are made to order; please allow 3-5 days Product Details:
The Fall-Line Motorsports G8X M3 / M4 Tow Straps may be viewed at the following links to our online store: Front: https://ind-distribution.com/product...3-m4-tow-strap Rear: https://ind-distribution.com/product...tow-strap-rear Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
01-13-2022, 01:55 PM | #2 |
Rep 10,869
bimmermann88309.50 |
01-31-2024, 02:37 PM | #3 |
Rep 179
IND-Distribution can you opine on whether this will fit a G20 M340? If the tow hook threads are the same between that and the G80 M3, which I have to think they are, I assume this will fit just fine, front and back. Thanks.
01-31-2024, 03:11 PM | #4 | |
Rep 10,869
We haven't test fit on a G2x, so if you place a ruler/measuring tape into your front and rear tow hook bumper receptacles, we can let you know if the shank head will still sit within the tow hook cavity.
01-31-2024, 03:38 PM | #5 | |
Rep 179
02-01-2024, 12:09 PM | #6 |
Rep 10,869
Perfect, so the G8x front and rear tow straps will definitely work for you (and they should fit behind the covers too).
