09-16-2021, 05:44 PM | #1 |
Rep 402
For those who have cut/modified fender lining for springs/spacers
I am dropping my G80 off for AST springs and a 15/12mm spacer install in a few days. I was hoping to gain some clarification from those of you who cut or heated the portion of the liner that is prone to rubbing on full lock? I'd like to take care of that as cleanly as possible.
If I were closer to you crazies out in Cali, I'd just go drop off to Ben and have him modify me an MSS, however no one seems to know whats going on in G80 world here in DFW currently. r33_RGSport Vic55 TrentMeister You gents mind sharing any of your findings? I tend to get a little saw-zall happy... Save me from myself, and thank you in advance. |
09-16-2021, 05:51 PM | #2 |
Rep 1,377
I didn't do anything. The rubbing is overblown honestly and I have 15mm spacers in the front on MSS. You only get a very mild rub in full lock on reverse that seems to have cured itself! I'm on PZeros too
There is one small rubber piece sticking out that is the culprit but I wouldn't worry and leave the heat gun/saw at home |
09-16-2021, 07:44 PM | #3 | |
Rep 18,682
But, the easiest way, wear it out until you see the rubbing mark, then cut those fins. Maybe TrentMeister can take a picture of his car with steering whee fully lock to the right.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com SPRING Sale!! 04/01 - 04/15 - Code: "SPRING2024" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
mattburks750.50 |
09-16-2021, 08:45 PM | #4 | |
Rep 402
09-16-2021, 09:07 PM | #5 | |
Rep 10,140
Apparently the sidewall on the Pzero is taller which causes that minute rubbing up front. With my 2021- I just endured the noise only on full reverse situations. The small cutting your shop probably will do is a non starter.
09-17-2021, 03:28 PM | #6 |
Rep 1,902
Are we now almost positive that any suspension setup for the RWD G80 will fit the AWD G80 (including HAS, Springs, etc.)?
I'm currently waiting for KW HAS but don't see any confirmation that it'll fit the AWD version...
2022 G80 M3 Comp M xDrive |
r33_RGSport12906.00 mattburks750.50 |
09-17-2021, 05:34 PM | #7 | |
Rep 18,682
KW HAS and MSS most likely will work perfectly fine on the drop. Not sure about H&R or AST. The drop probably going to be a little weird.
09-17-2021, 05:50 PM | #8 | |
Rep 18,796
09-17-2021, 06:48 PM | #9 | |
Rep 402
Bro.., that aventurine is Devine. Well done |
r33_RGSport12906.00 Vic5519207.00 |
09-18-2021, 09:35 AM | #10 | ||
Rep 2,067
But I'm sure it would have been fine before the mod. I'll have to bring it by to get it figured out. I actually think I need to go back to stock so I can take it back to the dealer to figure out my clicking sounds unfortunately. |
r33_RGSport12906.00 |
09-18-2021, 12:10 PM | #11 |
Rep 1,068
09-18-2021, 12:23 PM | #12 |
Rep 2,067
No, my research says it's either 2 bad bearings, or 2 bad rotors.
09-18-2021, 01:04 PM | #13 |
Rep 1,068
TrentMeister2854.00 |
10-02-2021, 05:49 PM | #15 | |
Rep 2,158
So I wouldn't worry about the rubbing, though at some point, all of this rubbing will wear out the liners and such, and none of us sure of what the long term affects of having warped or broken liners will have on our cars. |
10-02-2021, 06:00 PM | #16 | |
Rep 991
10-03-2021, 10:21 AM | #17 |
Rep 402
LukeM15
Hey man! Your set up will be killer! I’m running a 15 up front ans 12 in back on Pzeros. I can’t over emphasize how easy it was to achieve absolutely ZERO rubbing. We did so with a heat gun and a small rotary 3M shaver wheel thing. It’s 99% unchanged and unnoticeable unless you know what was done. Go at it with confidence! The aggressive stance really accents the aggressive body lines so well. You’ll be happy with your decision! |
RichJ1s4.50 |
10-03-2021, 10:24 AM | #18 | |
Rep 991
10-04-2021, 10:30 AM | #19 |
Rep 284
Interested as well!
2022 ///M3 COMP XD BKG
