09-05-2021, 09:54 PM | #1 |
Rep 1,738
Battery maintainer for winter
Hey all,
Seeing that summer is over I wanted to get a battery maintainer for the winter. anyone have any recommendations? |
11-13-2021, 07:27 PM | #3 |
Rep 220
CTEK is often rebranded by many OEM. Porsche for sure but I'm guessing others as well. I have the 7002 but the MXS 5.0 is more common and a little bit cheaper. Be careful of knockoffs. I'm not sure if I'd fully trust one from Amazon.
11-16-2021, 09:56 AM | #5 |
Rep 630
Drives: 2021 G80 M3
My service advisor said I didn't need a dedicated lithium charger if I was going through the charge point in the engine bay - Reason being the car's 12v system handles the load properly. The only situation where you need a dedicated charger is if you are going directly to the battery which he said wasn't the recommended process on these newer cars.
Anyone else heard this advice? |
M4Tejas773.00 |
11-17-2021, 01:37 PM | #7 | |
1916
Rep 1,878
Drives: E92 M3
Battery chargers might charge at a constant voltage whereas battery maintainers do not. For the lead-acid batteries, sometimes those maintainers might go through the battery reconditioning steps with varying charge profiles which aren't ideal for a lithium battery. It's not going to destroy the battery, but might reduce battery capacity in extreme examples. So a constant voltage regular battery charger hooked up to the lithium battery through the engine bay would be fine, but only temporarily. The lithium battery maintainers would be the ones to get to safely keep attached to the car long term. Things I've read about lithium batteries in general is that long term storage of them should keep it charged to 50%, but I'm not sure if car lithium battery maintainers keep it that low.
12-28-2021, 04:03 PM | #8 |
Rep 571
Drives: '19 GLA45AMG(his) / '21 X3M40i
So the, "CTEK - 40-206 MXS 5.0 Fully Automatic 4.3 amp Battery Charger and Maintainer 12V", says it's compatible with lead and AGM batteries. Will a lithium battery fall under the AGM category?
Currently: '19 GLA45AMG grey (his) & '21 X3M40i DGM (hers) w/ JB4@Map1
Previous cars: 2022 M4 xDrive in Mexico Blue with Silverstone/Black interior 2014 BE GTR FBO/e85 |
12-28-2021, 04:17 PM | #9 |
1916
Rep 1,878
Drives: E92 M3
No, lithium batteries are not AGM. Compatible maintainers should say they're for "lithium (LiFePO4)" batteries.
GixY2K517.00 calbearz2434.00 |
12-31-2021, 03:47 PM | #10 |
Rep 571
So, after reading in the e-manual that it is a good idea to charge your Lithium battery if the car sits for a month or more, I went ahead and purchased the charger/maintainer from the dealership for $99 +tax.
Note: After not driving my M4 for 2-3 weeks, it took the charger 4hrs +/- before it reached 80% charge, and another 1-2hrs to reach 100%. Also, two things the parts guy mentioned. These batteries cost around $2K. But that they've only replaced 2 since 2014 (that he knows of). So, here's what you get in the charging kit:
Previous cars: 2022 M4 xDrive in Mexico Blue with Silverstone/Black interior 2014 BE GTR FBO/e85 Last edited by GixY2K; 01-18-2022 at 11:08 AM.. |
02-24-2022, 01:21 AM | #12 |
Rep 273
Drives: 2024 BMW M4 Competition xDrive
I use this one: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2024 Verde British Racing BMW M4 Competition xDrive
2024 Sapphire Black BMW iX xDrive50 2023 Vapor Blue Ford Mach-E GT Performance Edition |
M4Tejas773.00 |
03-04-2022, 02:33 AM | #13 |
Rep 1,140
Drives: 2022 M3X
