09-04-2021, 06:47 AM | #1 |
Rep 80
How to replace rear brake pads
Apologies if the title is misleading!
I’m asking, has anyone created a how to on replacing the rear brake pads? I’m planning on as many track days as I can afford and all I’m reading about is how quickly the rear pads wear out. It’s encouraging to hear of options other than stock becoming available as well. Any advice / help is greatly appreciated!! |
09-06-2021, 06:32 PM | #2 |
Rep 80
Any chance someone can confirm that the rear brakes on this X3 are same / similar procedure to replace pads?
https://video.search.yahoo.com/searc...fe&action=view |
09-07-2021, 09:54 AM | #3 |
Track Rat
1699
Rep 395
Yes, the calipers are the same as those used on the G80/82. They are made by TRW, and the pad swap procedure is the same.
Yes to the broken sensor question too.
09-07-2021, 12:27 PM | #4 |
Rep 925
Have you broken a sensor yet?
2023 F90 M5
09-07-2021, 02:42 PM | #5 |
Rep 80
Thank you Boomer 2019 - I guess I didn't even know to ask. Are you saying I will need a new sensor every time I swap out the rear pads?
Any chance you can also confirm that the tooling and nut / bolt sizes are the same? I know I am asking a lot, sorry about that!! |
09-07-2021, 06:50 PM | #6 |
Track Rat
1699
Rep 395
Because I track my cars frequently, when I first break a pad sensor wire I just tie it up out of the way and don't bother to replace it until I am going to trade the car in. If I were to replace it, it would just break again at some point due to stress and strain, or heat. Waste of money since I know what the status of my pads are from frequent checking anyway. The BMW OEM rear pads for these cars come with new caliper clips and screws with each set. The EBC pads do not, and I have no knowledge of other companies products.
09-07-2021, 07:39 PM | #7 | |
Rep 5,262
09-11-2021, 05:09 PM | #8 | |
Rep 925
Also a 9v battery and wire to retract the motor by connecting it to the two contacts in the motor side plug. Saves a ton of time removing the electronic parking brake motor Some high temp anti-seize and a small flat screw driver to pull the sensor. Incidentally the EBCs had a spot to mount the wear sensor, so I reinstalled it. My pads wore harder in the outside
2023 F90 M5
09-19-2021, 07:12 AM | #10 | |
Rep 925
MDM set to zero Dust-o-rama
2023 F90 M5
12-19-2021, 03:25 AM | #11 | ||
Rep 14,085
Drives: G82 M4C X-Drive
Anyway, how did the EBC's hood up? I use PFC-08 on my F80. How do they compare?
12-19-2021, 06:51 AM | #12 | |||
Rep 925
Many tests have been done to show deflection is more effective than ducting. Vorshlag did some testing and makes some deflection kits. https://vorshlag-store.com/products/...-deflector-kit I do have a set of RP-1 I got delivered last week which have leas bite and better wear characteristics. Ill try them next, but heat is an issue - I have heat checking all my rotor face. Edit- btw, get bimmerlink to retract your rear calipers and reset your codes. If you move your pistons around and dont press your pedal before you start the car it freaks out the abs and thinks you have a brake line leak and throws a bunch of codes and makes the car undriveable. Brake by wire sucks…
2023 F90 M5
12-22-2021, 02:12 PM | #13 |
Rep 80
Thanks for the info! Interested to hear your results yet again. I will not be back on track until Feb and that's only if the weather cooperates.
Definitely thank you for the info on Bimmerlink! |
12-22-2021, 02:54 PM | #14 |
1885
Rep 1,854
Drives: E92 M3
ISTA+ works, might be the cheapest/best option.
12-22-2021, 04:41 PM | #15 | |
Rep 14,085
12-22-2021, 06:41 PM | #16 |
Rep 925
Windows 10 is a deal breaker for me.
2023 F90 M5
12-22-2021, 06:42 PM | #17 |
Rep 925
yes. Although bimmerlink wants the phone in airplane mode with all networks except the cable disabled...They are built by the same people.
2023 F90 M5
jmg18493.00 |
07-02-2022, 04:38 AM | #18 |
Rep 24
Bumping this.
I ran out of the rear pads yesturday on a trackday. Watched this video of replacement in rear and there is no mentioning of retracting the pistons electric or resetting by PC. I used the same tool as in the video and waiting for new pads. Will i get a problem when installed and starting the car up? |
Kaiz3n0.00 |
07-02-2022, 10:02 AM | #19 | |
Rep 190,172
Kaiz3n0.00 |
07-02-2022, 10:51 AM | #20 | ||
Rep 24
Seems to be different veiws on this. Some say push the piston back with a special tool. Some say rewind the electric handbrake engine with a battery and cables. Some release the handbrake engine and rewind manual with a hextool. Some that you need a PC with correct software to reset everything. Confusing |
Kaiz3n0.00 |
07-02-2022, 11:16 AM | #21 | |
Rep 190,172
07-03-2022, 09:09 AM | #22 |
Rep 2,023
Drives: G80 M3 Competition
When I swapped my rears a couple months ago, I invested in the bimmerlink app. Connected the app to my LX adapter, put the rear parking brake into "service mode", and was able to compress the rear pistons just a few mm's by hand. Worked well and bimmerlink made it quick.
Once done, just take the rears out of service mode. I've seen a couple owners mention fault codes from pistons being compressed and firing up the car. Good trick is to pump the pedal a few times before starting the car. Nice plus with bimmerlink is that you can read/clear codes. |
