08-18-2021, 03:55 PM | #1 |
Rep 1,663
VSC 2 Valve Controller Quick Review
I am by no means handy around cars. I can do very simple things and the controller was beyond easy. I backed my car to the end of the garage and since my driveway quickly drops off this allowed plenty of room to work underneath. Install was less than 10 min tops. Running the cable through the heat shield took all of 2 min.
There is definitely a change in the exhaust note. It's not dramatic but it's a nice change. A touch louder and deeper. Haven't noticed any drone but only drove about 10 minutes with it so far. Super easy and worthwhile mod. |
08-19-2021, 08:11 AM | #2 |
Rep 897
08-19-2021, 09:26 AM | #4 |
Rep 190,805
Glad you like it OP
08-19-2021, 09:33 AM | #5 |
Rep 1,663
08-19-2021, 09:37 AM | #6 | |
Rep 1,663
For the cable to the other muffler, I taped the connectors together so they don't get stuck while snaking them and makes it a little stiffer then just worked the cable under the heat shield. The heat shield has a small opening in the middle so it was easy to redirect the cable to the other side. Again, even this took 2-3 minutes. |
JTO245274.50 |
08-19-2021, 11:06 AM | #7 |
Rep 706
08-19-2021, 11:51 AM | #8 |
Beware of cheap bait!
709
Rep 715
I ordered one last night, hopefully it doesn't take ages to get here as I'm excited to try it out.
meechy6ix0293.50 |
08-19-2021, 04:29 PM | #9 |
Rep 348
I just purchased one also- thanks Mike!
07 E92 MT RB Turbos(All options)/ VTT Inlets/ VRSF 7In IC/ VRSF DP/Vangaurd Exhaust/AFE intake/Stett CP with Tial BOV/BT CC/ Meth Dual CM10s/ E85 Walbro Pump(E50)/JB4 with BB "e85" flash
08-28-2021, 03:54 PM | #11 |
Rep 897
It doesn't seem to work on M3 Comps. Same issues as noted by Bimmercode - it takes control of the valves (and opens them) at rest but as soon as you start to drive the ECU takes back control and shuts them. I offered to work with the guy to try and solve it but never heard back (he has versions that interface with a pc via USB and I guess he can make coding changes). At this point I'm just going to ask for my money back.
08-29-2021, 06:40 AM | #12 |
Rep 284
I ordered one the other day and it is taking ages to get here via UPS. But I'll have it the day after I pick up the car so I can't complain too much.
2022 ///M3 COMP XD BKG
08-29-2021, 08:48 AM | #13 |
Rep 2,030
Drives: G80 M3 Competition
When ordering, any advice on selecting the activated/deactivated modes? Also, if you leave the valves in the open position does it maintain that for the cars next start after powering off?
08-29-2021, 09:03 AM | #14 | |
Rep 1,663
Default: Open - Valves are fully open at all times even after restart Activated: Auto - Valves are factory controlled even after restart. |
08-29-2021, 09:15 AM | #15 |
Rep 2,030
08-30-2021, 10:26 PM | #16 |
f82_s55
93
Rep 94
Ordered this valve controller as well. Attaching some pictures, and possibly a sound clip. Im sure everyone knows by now, the G8X valves from factory do not open all the way even in the most aggressive setting. The valve controller is a must if you really want to have full control over the valves. I chose the following configuration, similar to OP but reversed:
Activated: Open - Valves are fully open at all times even after restart Default: Auto - Valves are factory controlled(essentially a bypass) even after restart. Installation Guide: I had the liberty of using a lift, but this is totally doable on jackstands. There are 4 10mm screws holding the muffler heatshield in place. I have a valved exhaust installed on my car(will do a separate post on the exhaust ), so access to the screws were super easy as you can see in the pictures. (Side note: my valved exhaust uses a slightly different valve spring than the G8X OEM muffler, as you will also see in the pictures. You can ignore that if you are installing this on an OEM muffler, your valve spring area will look slightly different) Once the 4 bolts are off of the heatshield, it gives you just enough room to pull the heatshield down very slightly and snake the wires across both of the valves. I decided to mount the valve controller on the Driver side(Im not sure it matters where you mount the controller though, but lmk if this isnt true and I just got lucky). Plug the controller in on both sides. Once it's all plugged in, I'd give it a test to make sure it works. I found that you have to start the car fully to actually activate the valve on/off. Once everything is working, you will see the valves fully open in the open position. Not just the half open that the car does normally. Now you are ready to actually mount the controller. I found there are two E14 bolts that are above the muffler, almost right above the valves that don't seemingly hold anything in place(if this is in fact holding something in place, and I totally glanced over this, someone lmk). I used the one on the driver side, closest to the rear bumper, and it worked perfectly. I will also highlight this in the pictures. At first, it seems like the bolt doesnt go through the controller fitting, but with some slight finesse it goes through. Just use a power tool. Its pretty straight forward once you are looking at it, but you basically mount it so the bolt goes back into place where you took it out. This may be the most complicated step, but I hope this makes sense. Once the controller is mounted to the car, you can reinstall the heatshield. Just make sure you aren't crushing the wire as you put the heatshield back into place. The heat shield should go back into place pretty easily, it has some slight give. At this point, I zip tied some of the wires together, just to make sure nothing was hanging around under the car. I used regular plastic zip ties, but now that I think of it, Im probably going to go back in and use metal zip ties to make sure heat isn't an issue. All of this to say, it really shouldn't take you more than 10 minutes Thanks OP for the suggestion. The VSC2 Controller is awesome! Oh and btw, pro tip: The remotes they provide with the controller are pretty lackluster, especially given the price of the car, you probably dont want to install that onto your keychain lol. SOLUTION: You can very easily program your car's garage homelink to take the action of the on/off of the controller. It programs just like you would program a garage door opener. Bring the remote close to the mirror, hold an UNPROGRAMMED garage button under the mirror and simultaniously hold either the on or off button, whichever you want to program. After holding the mirror button AND the remote button for a few seconds, the garage homelink light will turn green, and that will mean success. I programmed my middle garage homelink to the Off button, and the rightmost garage homelink to the on button. Works perfectly, and now I never have to look at $3 plastic remote. But to each their own, maybe you like plastic. It's 2021, I shouldn't judge. Speaking of plastic, people who order their cars without the full extended leather should be considered criminals. Okay, rant over. Last edited by ashiifi; 08-30-2021 at 10:42 PM.. |
08-31-2021, 08:20 AM | #17 |
Rep 190,805
Thank you for the detailed review and install guide
09-03-2021, 12:01 PM | #19 |
709
Rep 715
Aand mine has already failed. Wamp womp.
Bimmerbros2.50 |
09-03-2021, 12:11 PM | #20 |
Rep 1,382
09-03-2021, 12:31 PM | #21 |
Rep 2,030
09-03-2021, 12:31 PM | #22 |
709
Rep 715
No idea. Trying to get ahold of somebody to get it replaced. No action when the button is pressed. Tempted to open it up...but I'll keep it closed for warranties sake.
