      09-21-2021, 03:05 PM   #89
F80SRT
Drives: '22 xM3C/'20 X3MComp
Originally Posted by eg80sc View Post
Confirmed fit for xdrive
They should post pics later. It drive great, I feel no difference from stock except not having to see ugly gap in the front
Very interested! Have any pictures? Is the drop the same, more, less ?
      09-21-2021, 03:08 PM   #90
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
2021 M3 Competition X-Drive AST install in the bag. M3 looks, drives and feels absolutely fantastic. Drop is identical to non X-Drive.
Vehicle: 2021 X-Drive BMW M3 Competition
Suspension: AST Lowering Springs
Tires: Pirelli P Zero, 275/35-19 (F), 295/20-20 (R)
Spacers: Macht Schnell Competition Spacers: 10mm (F), 12mm (R)
JTO245274.50
mattburks750.50
abrush32190.00
DS_BMW1603.00
T0RM3NT3633.00
T3CH46.50
      09-21-2021, 04:37 PM   #91
F80SRT
Thanks Tom! Looks great. Lmk when the new orders come in and I’ll get you payment !
BTW I already bought a 12.5/15 spacer setup. Looks like those may still work. I’m thoughts on that?
tom @ eas8158.00
      09-21-2021, 04:43 PM   #92
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
We'll have the BMC filters on Friday, I'll give you a ring what they arrive.
12.5/15 should be ok, but there may be a slight bit of running on full lock until it "autotrims" (rubs inner fender liner). Otherwise, step down to 10mm.
      09-21-2021, 10:55 PM   #93
jetbill
jetbill's Avatar
198
Drives: G80 M3
Any idea what the stock rates are vs AST rates ?
Stiffer or softer than H&R etc.
thanks.
      09-22-2021, 12:12 PM   #94
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
thanks.
H&R is known to have a very stiff ride on past applications, we typically avoid these unless there is no other option. No published spring rates for either H&R or AST, sorry.
      09-22-2021, 12:21 PM   #95
jetbill
jetbill's Avatar
198
Drives: G80 M3
thanks.
Thanks Tom!
As for H&R, I wonder if that's a byproduct of an actual stiffer spring rate of the coil or more contact with the bump stop, as a byproduct of increased lowering.
Springs and HAS on EDC is like a mouse trap for me. I like the car stock , wouldn't mind a slightly stiffer rate with a slightly lowered front.
All to often lowering springs are sitting on factory bump stops at static ride height.
Dinan's philosophy with the HAS on the F80 seemed to be spot on. The key here was following the suggested ride night in the manual and measuring the shock body to bump stop clearances with a tie wrap on the shock shaft.
If EAS can provide this data on the AST's that would be helpful for those who may be concerned with those clearances which could artificially induce more understeer or oversteer based on front to rear clearances.
      09-22-2021, 12:33 PM   #96
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Thanks Tom!
Typically, lowering springs will be slightly stiffer to account for the smaller travel amount. It's up to manufacturers to decide up on how much.
On E92/F80, the bump stop is used as part of the dampening process. There's some white papers online posted about this and most likely the same rule applies to G8x.
More on bump stops: https://www.m3post.com/forums/showthread.php?t=427147
      09-22-2021, 04:19 PM   #97
F80SRT
Anyone have a range for what this should cost to have someone install? My first quote was $1150.
Heck I'll rent a lift and do it myself at that rate.
'22 xM3C FDG, Fiona Red interior
      09-22-2021, 04:22 PM   #98
mattssi
Drives: 2019 X3
I've gotten 800-1100, its ridiculous. Best deal is Tom @ EAS which is why I'm considering making a 10 hour trip out of it. Plus he's done it before.
2021 ///M3
2019 X3
tom @ eas8158.00
      09-22-2021, 04:26 PM   #99
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Shops that are quoting those prices likely have not installed a set yet and are using book time to quote rates. Sometimes book time doesn't apply in the real world, but most times it's pretty close. Hopefully, real time is charged once all said and done.
Shops rates vary. Typical install time is ~3 hours, slightly longer for X-Drive and ensures all fasteners are torqued properly and not just air-ratcheted into place.
mattssi876.00
F80SRT695.50
JTO245274.50
Limegrntaln13449.50
      09-22-2021, 04:36 PM   #100
F80SRT
Tom is a bit out of my commute range. Ha.
I have a feeling I'm going to get a lot of quotes like this... I might try and DIY, even if I have to rent a lift myself. I've done springs on other cars, I was just was looking to hit the easy button.
tom @ eas8158.00
      09-22-2021, 04:39 PM   #101
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Here's the folder on our Flickr site for the X-Drive install, there's more pictures in there that wasn't posted - they will help in installing:
https://www.flickr.com/photos/europe...57719880413228
      09-22-2021, 04:46 PM   #102
F80SRT
Yeah, that did help me know that for AWD I'll have to pull the axle (do you recall the hub nut size?). Knowing that upfront saves some head scratching time for sure! I had to do this for a Jetta recently as well, so I get the drill. On that car it was rather easy once we did that.
Rears looks the same and besides the struggles I hear in getting the bolt and holes to line up it's very straight forward.
Thanks again for sharing those!
tom @ eas8158.00
      09-22-2021, 04:58 PM   #103
mattssi
Drives: 2019 X3
With the ASTs, do you do an alignment right away or should you wait a bit?
2021 ///M3
2019 X3
tom @ eas8158.00
      09-22-2021, 05:01 PM   #104
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
17mm HEX socket
Typically 1 week driving time is good to allow everything to settle properly, and in case you need to go back in that area again.
F80SRT695.50
mattssi876.00
      09-23-2021, 10:05 AM   #105
jetbill
jetbill's Avatar
198
Drives: G80 M3
Thanks Tom!
Correct. And the most important part of this process is "when" the engagement takes place.
BMW calls the bump stops "supplemental shocks absorbers".
Does the AST kit provide bump stops ?
Thanks Tom!
      09-23-2021, 12:27 PM   #106
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Thanks Tom!
Original bump stops are retained.
      09-23-2021, 01:01 PM   #107
///M ARMY
Drives: F90
this looks good! what the pricing on this?
2022 RAM TRX
2021 Ford Bronco
2022 BMW M3
      09-23-2021, 04:30 PM   #108
eg80sc
38
Drives: 2022 M3 Comp xDrive
Should be springs + 2.5 - 3 hour labor max
      09-24-2021, 08:15 AM   #109
JTO24
JTO24's Avatar
Drives: 2022 G80 M3 6MT
Man this makes waiting for my SG M3 even harder... got the AST springs and FC spacers just need the car LOL
2018 F87 M2 6MT | Alpine White (sold)
2016 981 Cayman 6MT | Jet Black (sold)
2015 F80 M3 DCT | Tanzanite Blue | Gold Brown (sold)
2013 E92 M3 6MT | Mineral White | Fox Red/Black (sold)
      09-24-2021, 03:54 PM   #110
CanesM4
CanesM4's Avatar
476
Drives: 24 Twilight Purple/Ivory
Rejoice - the first of the AST springs for G80 M3 are now on US soil.
AST Lowering Springs are manufactured from a premium high tensile chromium-silicone wire which is handpicked by AST engineers for its quality and metal consistency. Each spring is cold wound and then heat treated to increase hardness and reduce internal stresses present after winding. Each spring is then individually shot peened, phosphate treated and then powder coated to outlast even the life of the vehicle.
AST suspension lowering springs will lower that center of gravity without giving in a lot of the comfort you are used to with the OEM springs. The lowering springs are a direct replacement of the OEM springs and have been developed especially for each vehicle specific. Made out of the best material on the best Wafios coiling machines available.
Features
- Drop of 30mm up front, 15mm in rear
- Developed and tested to work flawless with stock dampers
- Progressive design for the best lowering vs performance
- Cold coiled
- Premium high tensile chromium-silicone wire
- Powdercoated finish
- Lifetime warranty
G82 M4 fitment coming soon.
Do you have the M4 Springs in stock?
Tags
ast, eas, g80, g82, lowering
