06-28-2021, 09:59 AM | #24 | |
Rep 10,166
275x35x19 has a 26.6 diameter 275x30x20 has a 26.5 daimeter so you are spot on with your plus sizing...in the front.
06-28-2021, 02:22 PM | #25 | ||
Rep 200
TrentMeister2860.00 |
06-28-2021, 03:58 PM | #27 | |
Rep 679
06-28-2021, 04:41 PM | #28 | ||
Rep 2,067
So all in I'm looking at like 1800 to be low |
06-28-2021, 04:48 PM | #29 | |
Rep 10,166
Another great guy is Ben at RG Sport who has lowered my M8 GC and did the catless secondaries. He is a one man gang but hyper fair in labor rates and great for service too. Edit: Just saw Blue's post, well its probably due the fact they have not even done one yet. I was supposed to be their first but KW has delayed over and over again, their shipment. r33_RGSport aka Ben
06-28-2021, 05:00 PM | #30 | |
Rep 679
Front install is so damn easy. Remove the plastic shrouds that cover the strut nut(3 clips), removing the strut sensor and boot, undo the strut nut, remove sensors off the struts, remove drop link from Sturt and lower the assembly then reverse the steps. Rears is two bolts and a leveling sensor. If the shop is good and honest, they will adjust that quote. I do get that it would be their first time doing it but it really is that easy. |
06-28-2021, 05:56 PM | #31 | |
Rep 10,166
06-28-2021, 06:39 PM | #33 |
Rep 1,382
What's the hourly rate most places these days? I'm sure it varies but I'm guessing $120 ish?
I was hoping that it would cost less than $500 to install. If it's going to be more I may just buy the tools and do it myself. Haven't had car tools in years since relocating and may as well pull the band aid off It probably needs an alignment after tho so that would make me let someone else do it to save the hassle most likely… |
06-28-2021, 06:47 PM | #34 | ||
Rep 2,067
That would be a good day and a good drive. |
06-28-2021, 07:05 PM | #35 | |
Rep 10,166
But the RC and springs are a no brainer there for so many reasons: best priced, fast, and just a good guy that doesnt treat you like a number.
TrentMeister2860.00 mzcp2685.50 |
06-28-2021, 07:07 PM | #36 | ||
Rep 2,067
06-28-2021, 07:14 PM | #37 | |
Rep 10,166
Now you can go to Bro Muffler and they could just cut and weld pipes on but thats in HB.
mzcp2685.50 |
06-28-2021, 07:16 PM | #38 | ||
Rep 2,067
mzcp2685.50 |
06-28-2021, 07:20 PM | #39 |
Rep 10,166
Pleaseeeeeeeeeeeeeeeeeeeee do
then you can tell us/me your thoughts on the 2nds being cut.
06-29-2021, 10:17 AM | #40 |
Rep 1,286
Does anyone know if the front and rear fender gaps can be adjusted to be exactly the same? I personally don't like how the rear is lower than the front on some of these installs.
I have the KW HAS on order, hopefully the gaps are similarly adjustable
06-29-2021, 10:29 AM | #41 | |
Rep 2,163
Like you, I don't like that look. I will lower the front, and "barely" lower the rear, because I want the wheel arch gaps to match...and if anything, I want a little more space in the rear than the front. Don't want the rears tucked in the fenders or anywhere close. I need the slight forward lean. Thus, you and I are in the same boat. I have the MSS kit sitting in my garage....but waiting to install it. Likely in a month or so, as I want more drive time without it being lowered. |
06-29-2021, 10:38 AM | #42 | |
Rep 10,166
Edit: the reason you are seeing some installs here that are off is the MSS product, not the owners desires of course. My skyscraper:
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black Last edited by Vic55; 06-29-2021 at 10:50 AM.. |
///MeraldCity_G821143.00 |
06-29-2021, 11:36 AM | #43 | |
Rep 387
Hi, what does that mean? I am supposed to get the MSS install Thursday, it is a lot of money to lower it like 1/2 inch tops as I do not want a severe drop. But I have had the KW HAS and was pleased but have always heard great things on MSS. |
06-29-2021, 11:40 AM | #44 | |
Rep 10,166
BSM_G808 can chime in much better
